05-05-2014, 21:31 | #4756 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2078526 Status: Offline Thanks Meter: 0 | |
05-06-2014, 10:39 | #4758 (permalink) | |
Banned Join Date: Apr 2014
Member: 2176390 Status: Offline Thanks Meter: 2 | Quote:
05-06-2014, 19:36 | #4760 (permalink) |
Junior Member Join Date: May 2014
Member: 2180153 Status: Offline Thanks Meter: 1 | Missing iPhone 5 logic board items Hi , another question for the guru's here .. On a iPhone 5 logic board I have some missing parts ... C364, c365, c366, c367 and c9 When restoring the logic board just hangs at ' waiting for iPhone ' There is quite some heat build up on U201_RF but too excessive Can anyone help ? Regards Steve |
05-06-2014, 19:48 | #4761 (permalink) |
Member: 2180153 Status: Offline Thanks Meter: 1 | Not connected with my previous post Reflow or replace IC Digitizer Controller Repair Part 343S0628 Hi .. I have a iPhone 5 64gb logic board that won't swipe on the screen .. The digitiser fpc connector is clean and corrosion free .. It's been in the ultrasonic bath with 99.9% alcohol and has updated perfectly, now before I proceed I would like your input as to the best way forward , I have a LY - IR-pro-SC BGA Machine and a hot air SMD station ... A small milling machine for chip removal too .. Your thoughts would be greatly appreciated Regards Stevepcb |
05-07-2014, 02:23 | #4762 (permalink) |
Member: 2180842 Status: Offline Thanks Meter: 0 | Hey, i have an Iphone 4 which is laggy about 5sec to open anything on the phone that requires access to it's memory ie. settings, calendar etc (not camera or sth else) if you have the application opened from before it works like a charm. So i am guessing the issue is that it very slow to retrieve the data from memory It's not a software issue. The phone is from a client, and has also grey wifi, but my my main problem is that, and i don't have any other info such as a water damage etc. Any suggestions welcome! Thanks!! |
05-09-2014, 15:21 | #4766 (permalink) |
No Life Poster Join Date: Dec 2010 Location: [pujab haryana]
Member: 1481018 Status: Offline Sonork: 100.165460 Thanks Meter: 222 | i phone 4s stuck on recovery mode i phone 4s stuck on recovery mode and do not attach with pc i change usb jack complete but same problme plz help master |
05-10-2014, 10:27 | #4769 (permalink) |
Freak Poster Join Date: Jan 2012 Location: On Earth
Member: 1716439 Status: Offline Thanks Meter: 38 | Iphone 5 no light but with dark image hello, i´ve change many lcd but like this one, no. This is about changing a complete stock original lcd to a iphone 5 16GB. Original lcd was chashed but was working ok. After change to new one have only image but no light, is just very dark acurate image like you dont have turn on the light. The original crashe lcd is not working anymore, so what is wrong? New lcd working and responding ok, but can use it only on darkness or in the night cause otherwise you can not see a ****. BR. |
05-11-2014, 06:44 | #4770 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Nepal
Member: 622060 Status: Offline Thanks Meter: 37 | Iphone 5 home button and power button not working, chanfed both flex switch but still same problem can any one help me again and again phone stuck in recovery mode tried to restore but same |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
