03-13-2015, 05:53 | #5193 (permalink) |
Junior Member Join Date: Mar 2011
Member: 1541788 Status: Offline Thanks Meter: 4 | goodday please assist front n back camera dont work on my iphone 4G camera app opens but remains black it appears to be frozen any assistance at all? i still have not been able to resolve this |
03-13-2015, 12:58 | #5194 (permalink) | |
Freak Poster Join Date: Nov 2010 Location: uk
Member: 1434392 Status: Offline Thanks Meter: 10 | Quote:
Reset software, set date and time (fully activate it ) 100% will work its seems to have problem with iOS 8+ when battery disconnect, date time wrong camera will not work. Regards | |
03-13-2015, 15:24 | #5195 (permalink) |
Junior Member Join Date: Mar 2015
Member: 2361943 Status: Offline Thanks Meter: 0 | Hi got an iPhone 5s, with a signal problem. It constantly shows no signal on the signal strength indicator, but it shows 3G/gprs etc as it changes between the different types of signal. I have a sim cut down to fit. Could that be the problem or is t something else? It does not show searching/no sim |
03-14-2015, 17:05 | #5196 (permalink) |
Junior Member Join Date: Feb 2015
Member: 2354472 Status: Offline Thanks Meter: 0 | hi i have a problem, i have e iphone 4s. my phone received water damage. does not display the image, does not respond to the charge iTunes does not respond when connected battery , but with new batteries "found a device in recovery mode " gives a response as I wonder what the problem |
03-18-2015, 22:03 | #5198 (permalink) |
Member: 2358714 Status: Offline Thanks Meter: 3 | hello this is the first time i post anything i have an iphone 5 which is locked to vodafone contract in Germany and i was wondering if there is any way to unlock it.. thank you in advance |
03-20-2015, 11:37 | #5199 (permalink) |
Member: 2349828 Status: Offline Thanks Meter: 0 | Hi, without any reason my iphone 5s have a error 1 on restore Itunes. a lot a person said that the pb come from the IC U1_RF (baseband component) or the IC U501 (power of baseband). I've test to restore with all IOS, new itunes version What do u thing about reheat or reflow the IC Do you have the process ? thanks a lot |
03-22-2015, 17:00 | #5200 (permalink) |
Member: 2366872 Status: Offline Thanks Meter: 0 | iPhone 4s Boot Problem... hello, i need your help... here is the problem...when i turn on my iPhone 4S it is stick at the apple logo for 10 seconds...and then the display turn of ( but still the screen backlight on ) and then it is go into the home screen... anyway when i pull the notification center down the iPhone restart... what would be the problem plz? may you help me? thanks |
03-27-2015, 22:17 | #5204 (permalink) |
Junior Member Join Date: Oct 2014
Member: 2278041 Status: Offline Thanks Meter: 1 | Hi. I've got a problem with an iPhone 5, headphone jack wouldn't work, sound is ok through the main speaker but when you plug the headphone in it still carries to play through the speaker. Tried 4 different charging port cables - no difference, must be hardware fault - what should I look for? |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
