12-01-2014, 20:28 | #5041 (permalink) |
Freak Poster Join Date: Aug 2014 Location: Dhaka, Bangladesh
Member: 2238789 Status: Offline Thanks Meter: 20 | Iphone 4s touch not working HELP but it does not work after 2 to 3 days (everything working without touch screen) then i remove battery and apply battery and power on then touch working but 2 - 3 day later again same problem touch screen not working |
12-02-2014, 08:00 | #5042 (permalink) | |
Freak Poster Join Date: Feb 2007 Location: i amm livinig in tukrey
Member: 454060 Status: Offline Thanks Meter: 12 | 1.test another lcd 2.reball ic touch or replace it Quote:
12-02-2014, 14:50 | #5044 (permalink) |
Junior Member Join Date: Dec 2014
Member: 2303572 Status: Offline Thanks Meter: 0 | Hi everyone, I'm new to the forum and have an Italian boy . I did not know where to post this message and I hope not to have been wrong . I have a problem with an iphone 4s . I soldered the resistance of the battery but goes into continuous reboot . I want to know how to fix it I have pictures that I post . Thank you all . I translated with google translator . greetings. |
12-02-2014, 16:38 | #5045 (permalink) |
Junior Member Join Date: Dec 2008 Location: Tirana
Member: 924143 Status: Offline Thanks Meter: 0 | Iphone 5s Zebra lines , hard to see only with lights off , no vibrate , no turning on nothing , when i try to turn on , only the lines came on and goes off in secords, please tell me all the ic i have to change to get it fix Thnx |
12-04-2014, 17:46 | #5046 (permalink) |
No Life Poster Join Date: Feb 2008 Location: INDIA
Member: 697664 Status: Offline Sonork: 100.1602716 Thanks Meter: 267 | need iphone 5 ear speaker solution i have iphone 5 problem no sound in ear speaker while mic is working fine already replaced ear speaker speaker flex headphone flex cleaned pcb can help me to shoot out this problem |
12-05-2014, 04:59 | #5047 (permalink) |
Junior Member Join Date: Jun 2014
Member: 2198212 Status: Offline Thanks Meter: 3 | iPhone 5 reboots and fades lcd Hello guys i have this iphone 5 att it reboots and fades away i tested all the parts an everything works fine and i put new battery as well but nothing work seems l like a board problem. |
12-05-2014, 17:02 | #5048 (permalink) |
Junior Member Join Date: Jan 2011
Member: 1487037 Status: Offline Sonork: sumai Thanks Meter: 0 | Good evening please i really need your help. pls. post a diagram iphone A1203 my problem is the flex ribbon is snap/ torn my only solution is jumper, and my problem is where i coonect the power and the earphone jack and the volume button from the connector please i ow you please help me |
12-06-2014, 16:41 | #5049 (permalink) |
Junior Member Join Date: Jan 2010 Location: Turda
Member: 1202325 Status: Offline Thanks Meter: 1 | iphone 4s proximity sensor if someone had this problem in the past ,please help me, it is about the proximity sensor of an iphone 4s !, changed the display,changed the flex (3 pieces), put the gasket and no luck !! If i take out the flex with the sensor and put my hand on it works but the wrong way , in fact it works in revers !! when it's covered the screen appears and when it's not cover the screen is black . . when in case the screen is always on!! anyone have any idea? thanks |
12-11-2014, 13:07 | #5055 (permalink) |
Junior Member Join Date: Mar 2007 Location: Australia
Member: 465800 Status: Offline Thanks Meter: 0 | Hello experts, I bought an iphone 5s having water damage with the hope of fixing it. It went in a pool as per seller's description. 1. Opened the phone and found the battery control circuit was fully corroded. Threw it in the bin. 2. Removed the emi shields and thoroughly cleaned the board with isopropyl alcohol. Luckily the board didn't show any signs of corrosion except rust marks from the emi shield on inductor L9 and one corner of A7 chip near the screw hole. (board surface seems fully clean and corrosion free) 3. Put the shields back on and tried to power up the device from the usb cable without battery but got no signs of life. Suspected faulty parts- LCD and dock connector Your expert advise is required to proceed further for fixing this phone. Thanks |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
