03-17-2016, 09:53 | #5642 (permalink) |
Insane Poster Join Date: Apr 2012 Location: Germany
Member: 1752885 Status: Offline Thanks Meter: 4 | A Customer brought me an iPhone 6 with no Picture and damaged Screen. After opening i found two missing Screws from LCD and Touch Frame. And too long Screw in the middle of LCD and Touch Frame installed. I installed a new Screen to test. no Picture a look on Scope shows the long screw has damaged LogicBoard. So i desoldered the Screw Mounting Hole and scraped gently to second Layer. I found no damaged Line. What i found: FL2024 is missing. I shortened it cause i donīt have a Part here. No Picture anyway Any Ideaīs ??? I couldnīt upload Pics here |
03-19-2016, 15:16 | #5645 (permalink) |
Junior Member Join Date: Aug 2014 Location: Bangalore, Inida
Member: 2234487 Status: Offline Thanks Meter: 0 | I have a Iphone 5s with a back light problem. even after changing the LCD with the Touch i can see the display. Please let me know what can be done |
03-20-2016, 01:40 | #5646 (permalink) |
Junior Member Join Date: Mar 2016
Member: 2545718 Status: Offline Thanks Meter: 0 | Why why why ??? Hi guys.....any ideas why this is happening? phone words perfectly except every time i move the phone while being on homescreen, it rotates.....all the icons move in a cicrular motion. in settings or browsing internet phone is working perfectly. if phone is still, it doesnt move.......check video for better understanding.... **** just saw i cant post a video link **** thanks in advance |
03-21-2016, 07:52 | #5648 (permalink) |
Junior Member Join Date: May 2010
Member: 1300486 Status: Offline Sonork: 123456 Thanks Meter: 0 | i try to update iphone 5s its updated but shown connect to itunes, wen connected it shows "to allow access respond in the phone" i didnt take my backup to plz help |
03-22-2016, 11:36 | #5649 (permalink) |
Member: 2234487 Status: Offline Thanks Meter: 0 | I have a Iphone 5s with a back light problem. even after changing the LCD with the Touch i cant see the display. Please let me know what can be done |
03-22-2016, 12:06 | #5650 (permalink) | |
Member: 1752885 Status: Offline Thanks Meter: 4 | Quote:
as for deactivated Search use Google "gsm hosting iphone 5s backlight" There is a Thread called "iphone 5s no backlight" with a good Picture | |
03-24-2016, 19:47 | #5652 (permalink) |
Member: 2550563 Status: Offline Thanks Meter: 0 | My iPhone 5s proximity sensor wasn't working, so I tried replacing the proximity/camera/etc sensor assembly. The proximity still didn't work and I also lost the automatic brightness adjustment. I later cracked the screen, so bought a complete replacement screen from Amazon (SAVFY brand) which has a new set of sensors pre-assembled. After fitting this, I still don't have a working proximity sensor or ambient light. I've reset the phone back to factory, still no better. The Automatic brightness option doesn't even appear under the brightness slider under settings. Any suggestion as to whether there's anything I can do in settings? ... or could I have screwed up a connector when I had the case open? |
03-25-2016, 16:13 | #5653 (permalink) |
Major Poster Join Date: Jan 2011 Location: germany
Member: 1501319 Status: Offline Thanks Meter: 2 | iphone 4s repeatly bong sound and no picture Hi guys I have a customer's iphone 4s when i plug in the charging cable it does the bong sound every 5 seconds, doesnt turn on and shows no picture on display. i connected other display but same problem. it becomes pretty warm on mlb. Is there a known solution forthis problem? |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
