01-18-2018, 13:18 | #6273 (permalink) | |
Major Poster Join Date: Dec 2007
Member: 657332 Status: Offline Thanks Meter: 16 | Quote:
replace the F shape wifi antenna Sent from my iPhone using Tapatalk | |
01-18-2018, 13:20 | #6274 (permalink) | |
the sensor misaligned, just pull out the LCD, take it apart and check the sensor, it should work. Sent from my iPhone using Tapatalk | |
01-19-2018, 05:46 | #6275 (permalink) |
Major Poster Join Date: Jan 2009
Member: 946970 Status: Offline Thanks Meter: 0 | iphone dead..not power on ..dead.. remove nand,,,not sot anymore..try to restore without nand ....result error 4014 it should be error 40 right? please help..where should i start to check ... tq |
01-19-2018, 05:46 | #6276 (permalink) |
Member: 946970 Status: Offline Thanks Meter: 0 | iphone 6 dead..not power on ..dead.. remove nand,,,not sot anymore..try to restore without nand ....result error 4014 it should be error 40 right? please help..where should i start to check ... tq |
01-19-2018, 05:53 | #6277 (permalink) |
Member: 946970 Status: Offline Thanks Meter: 0 | iphone 6 dead..not power on ..dead.. remove nand,,,not sot anymore..try to restore without nand ....result error 4014 it should be error 40 right? please help..where should i start to check ... tq check with psu before remove nand https://www.dropbox.com/s/rcrjes9d1n..._0250.MOV?dl=0 |
01-21-2018, 18:02 | #6281 (permalink) |
Junior Member Join Date: Jul 2017
Member: 2735667 Status: Offline Thanks Meter: 0 | I accidentally removed capacitor C1597 on iPhone 6 when removing black glue. My question is: which direction should I put back the capacitor? If I know correctly, then direction matters, but there is no marking on the capacitor as which side is plus and which is minus |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
