02-22-2011, 02:13 | #931 (permalink) |
Junior Member Join Date: Feb 2011
Member: 1521906 Status: Offline Thanks Meter: 0 | infinite apple logo/frozen I am a newbie to the i phone4 and had a buddy of mine jailbreak it last month. Today I clicked a link on Cydia I believe, and it asked me if I wanted to upgrade some of my apps. I clicked yes. Everything downloaded fine and than I was prompted to reboot which I did. Well I was never able to fully reboot and got stuck on the "white apple logo" screen. At times it will show the circle bar in front of the apple sign as if it's loading but nothing ever happens. After 5-10 minutes the screen goes black and than turns back on with the apple logo & repeats the same process. I tried turning it off and on but had no luck. I held the power & home key down until it turned off again, waitied, than tried turning it back on with no preveil. Still doing the same thing.... Can someone please help me! Again I'm not real tech savy but I believe I had 4.0 or 4.1 OS with an I4 phone. And I don't want to lose any of my saved information or apps. I tried tiny umbrella to "kick out of recovery" but that didn't work either. Any information would be greatly appreciated! |
02-22-2011, 11:20 | #933 (permalink) |
Junior Member Join Date: Jan 2010
Member: 1206672 Status: Offline Thanks Meter: 0 | Heeelooo i want one help ! i got jailbreaked iphone 3g version 3.0 (7A341) firmware 04.26.08 and i got some problems with my wi fi ! it goes down on let say 5-10 minutes and shoult turn on and off several times to get on the network ! i whant to ask you what should i do i try reseting network settings it wont helped! if you got suggestion pls tell me i will own you a bier when i see you in live and if is update needed should i go with snowbreeze like in your video and not loosing old firmware !!! tnx for help !!! |
02-22-2011, 21:04 | #934 (permalink) |
Junior Member Join Date: Dec 2008
Member: 922340 Status: Offline Thanks Meter: 0 | Hi, i have an iphone 3GS 16GB who falled from the second floor, nothing broken but the phone won't start and overheating, i changed the pm ic, but the problem is still the same, any help please, i really need a help |
02-24-2011, 10:37 | #939 (permalink) | |
Freak Poster Join Date: Nov 2010 Location: Earth and around
Member: 1442842 Status: Offline Thanks Meter: 103 | Quote:
i see this problem with a falling phone. There was a little bit of solder tin or tin balls laying on the PCB and make shortcut in a hided place. or give it to a reflow oven. Maybe this is a solution if you haved changed the pmic before. BR | |
02-25-2011, 11:47 | #940 (permalink) |
Freak Poster Join Date: Oct 2005
Member: 194873 Status: Offline Thanks Meter: 4 | I have iphone 3gs with 4.1 firmware.....i have jailbreaked my iphone.. nowadays while i connect to itunes..its not backup my iphone...I get some error.how to overcome this error... |
02-25-2011, 22:22 | #941 (permalink) |
Junior Member Join Date: Mar 2007
Member: 477086 Status: Offline Thanks Meter: 0 | I have a iphone 3g, I passed it on itunes firmware correctly, then I put in redsnow, I had the flash of 3gs, and the mobile will not enter in boot more, no way in itunes. someone help me please ... if there is like a jumper or something like that |
02-26-2011, 00:22 | #942 (permalink) |
Crazy Poster Join Date: Jun 2010
Member: 1330514 Status: Offline Thanks Meter: 4 | Hi. Anyone knows how to fix the backlight in iPhone 4? It was waterdamaged but it synch's with itunes, everything works but no backlight. i've changed the board to a working iPhone 4 but still the same. So i need to replace the coil but i don't know where it is.. Any help will be appreciated |
02-27-2011, 08:40 | #945 (permalink) |
Junior Member Join Date: Jul 2009
Member: 1071255 Status: Offline Thanks Meter: 0 | Dear Brother's I need Help.. I have Iphone 3g 16gb my display colours are not pure white im getting yellowish color i thought might be lcd problem but i checkd and change it but its still showing same colors init. sum othr hardware repair ppl said its Ic Problem i want to know what to do kindly help me out.. pls sms or email me [email protected] +923332772252 Shahryar |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
