Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 01-22-2019, 23:10   #6466 (permalink)
toni_85's Avatar
Member: 2070856
Thanks Meter: 62
Originally Posted by junhoe1989 View Post
guys, having issue within 2 of these model. iPad random reboot. Stuck iTunes error 6,9,4013. Change a brand new Nand with programmed original serial but still same. Any idea ?
iPad Pro 10.5 A1701 random reboot. Error 6,9,4013.
Happens that points on surface looks ok but lines under are disconnected only one needs to miss to cause this trouble. Check lines that comes directly to CPU especially.
Sent from my SM-G950F using Tapatalk
Old 01-28-2019, 17:26   #6467 (permalink)
Member: 2386121
Btw bro I don’t have any diagram for this iPad 10.5 yet.
Old 01-29-2019, 11:03   #6468 (permalink)
bobo bokota's Avatar
Member: 2148606
Sonork: Bobobokota
Thanks Meter: 496
Originally Posted by highlights2010 View Post
hi can you help me out with this 6s plus restart for 3 minutes or 5 minutes when using.
Check line bat swi
Envoyé de mon iPhone en utilisant Tapatalk
Old 02-17-2019, 20:46   #6469 (permalink)
Member: 2556868
Originally Posted by panicos778 View Post
Hi I have an iPhone 5se I change the battery
And after that the phone stuck on 1% and reboots all time
I put the old one but it’s the same help please
Thankss
Check this SWI line, either its missing or broken. If its fine then it tigris(usb ic).Good Luck,
Old 02-21-2019, 14:56   #6470 (permalink)
Member: 2254818
Thanks Meter: 5
Hello everyone
I have problem with iphone X was no imei and baseband firmware so i repair it but i have problem now speaker and vibration not working (2 speaker in the lcd and in the housing) so how can i repair it please
تم الإرسال من RNE-L21 باستخدام Tapatalk
Old 02-23-2019, 10:14   #6471 (permalink)
Member: 1823864
apple ipad a1430 restore error -1 itunes error solution plese.
Old 02-23-2019, 20:45   #6472 (permalink)
Crazy Poster
Member: 2025909
Sonork: csandaruwan
Thanks Meter: 10
hello
i have 5s mobile, iphone 5s logo only so i'm replace u2 ic after read screen now 4013 error, how to fix it brothers,
Old 02-23-2019, 23:14   #6473 (permalink)
Member: 2601612
Thanks Meter: 14
Originally Posted by milan@kv View Post
Hello, I have iPad mini 3 icloud unlocked, won't rotate screen, nand is formatted and restored. Any idea?
I noticed that fpc also cause rotate problem. There is gyro line. If Nand is no problem, Check fpc.
Sent from my iPhone using Tapatalk
Old 02-23-2019, 23:15   #6474 (permalink)
Member: 2601612
Thanks Meter: 14
Originally Posted by csandaruwan2012 View Post
hello
Did you check Nand?
The Following User Says Thank You to jiiko2361 For This Useful Post:
Old 02-25-2019, 06:36   #6475 (permalink)
Member: 2612722
hi everyone
i have iPhone 6s won't exit in dfu mode
I've try to exit through 3u tools but was
return in dfu mode, also try to restore using itunes but theres's an error 3094
can anyone give me a solution to fix this issue.
thank you
Old 02-26-2019, 01:12   #6476 (permalink)
Member: 2602379
Originally Posted by vagner.phillipe View Post
I'm with trouble trying to repair an iPhone 6 touch IC, changed Cumulus and Meson IC 3 times but the touch still have a line that doesnt work... Any Solution?
Have you checked M2 Pad underneath Meson? Second row from top, second pin from left.
Old 02-26-2019, 07:41   #6477 (permalink)
Member: 2254818
Thanks Meter: 5
Hello my friends
I have iphone 6 plus charging problem when turn on show me 1%
I check swi Lan its ok and i change u2 and tigers but same problem
Old 02-28-2019, 01:35   #6478 (permalink)
Member: 2474430
Thanks Meter: 3
There is a relatively rare problem that can occur with the SWI line between Tigris and the CPU (AP_TO_TIGRIS_SWI). Basically the pullup on that line is too weak. It's typically solved with a 2.2k resistor to vcc_main and another 2.2k resistor to ground (which acts like a 1.1k resistor to vcc_main/2). I'm assuming of course you've verified it's not the battery_swi filter, the battery or the battery connector.
Old 02-28-2019, 09:10   #6479 (permalink)
Member: 2556868
Originally Posted by yousef agha View Post
Hello everyone
If you disassembled the board then most likely you have successfully connected the board back. Try to test with ibridge
Old 02-28-2019, 09:13   #6480 (permalink)
Member: 2556868
Hello my friends
Have you checked voltage on SWI line should be around 1v. Also check check Q2, the reverse line is located there.
All Blackberry Hardware and Software Solution youssef01 BlackBerry (RIM) 34 11-01-2012 17:31
I need DVD player hardware and software solution site ..::MOBILES::.. GSM Mobile Links 0 04-05-2009 15:49
O2 Hardware and Software solutions Eagle7 Various 2 04-14-2006 12:47
Page generated in 0.23786 seconds with 10 queries
