Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 08-10-2022, 21:22   #6616 (permalink)
Member: 2474430
Thanks Meter: 3
In the 6, battery Data (battery_swi) comes from the battery, through the connector, through a filter, and then to the charging chip (Tigris). It does NOT go through Tristar (or the charge port).
Best guess you either have a bad battery or it's the pins on the battery connector. They have a way of getting pushed under the plastic.
Old 08-11-2022, 06:04   #6617 (permalink)
Member: 2904736
Thanks Meter: 6
Hi,
iPhone works whole day with several percent of battery, but after discharge it now doesn't won't to turn on (battery is charged in external charger).
Probably oxidation from water doing his thing...
Eldavies, I will try to replace battery with another one to check that.
Thanks.
Old 08-11-2022, 20:13   #6618 (permalink)
Member: 2904736
Thanks Meter: 6
Last update. I put old dead battery inside iphone and it have charged the battery on 4.25V but iphone won’t turn on. I will check if the PC see it.
Old 08-22-2022, 16:01   #6619 (permalink)
sm-shahzada's Avatar
Member: 2130293
Sonork: 100.1637594
Thanks Meter: 68
Unhappy iPhone 12 pro dead but no short
Hi
i have iPhone 12 pro arrive in dead condition i try to find shortage
but nothing when i connect with power supply its show nothing short
i press power button than its take 200 amp and turn back to zero 0 than
again show 200 again back to zero so where is problem any one solved
thanks help me
Old 09-01-2022, 12:59   #6620 (permalink)
iyass's Avatar
Member: 23534
Thanks Meter: 17
iPhone 12 t mobile watter damage,
i clean it, change the housing with a good phone, the phone now deos not pickup a signal
i checked all the antena and replace the housing with another phone, not working
i cant switch to manual to search for a network(the option is not there)
any help ?
thanks
Old 09-01-2022, 20:19   #6621 (permalink)
Member: 2474430
Thanks Meter: 3
any help ?
thanks
Water can seep into the sandwich of the motherboard and corrode the connections between the two halves- or simply damage the bottom board which has the cellular. If you are lucky maybe it's just the antenna connector- need to examine it very closely.
The Following User Says Thank You to eldavies For This Useful Post:
Old 09-22-2022, 20:02   #6622 (permalink)
Member: 1549859
Thanks Meter: 13
Hello, I have apple watch s5 40mm. It was icloud locked I purchased new mother from cracked device. Touch worked on old device but after motherboard install touch stopped worging. Bought new touch and changed it but still same. Touch not working anymore. Can anyone help me what can be wrong?
Old 10-03-2022, 09:08   #6623 (permalink)
Member: 1277279
Sonork: trix
Iphone 8 plus weak network signal. anyone has a solution?
Old 11-02-2022, 19:12   #6624 (permalink)
Member: 1312710
Schematic diagrama iPhone XR
Old 11-10-2022, 04:20   #6625 (permalink)
samithashiva's Avatar
Member: 1356665
Sonork: 123
Thanks Meter: 31
ipad a1432 after unlock wifi not working
Old 11-22-2022, 07:53   #6626 (permalink)
Member: 634596
Thanks Meter: 25
iphone 12 mic so noise for recording. all flexible mic has pull out but still noise.
Old 11-22-2022, 11:18   #6627 (permalink)
Member: 3009116
Thanks Meter: 4
What is the difference between soldering station and soldering iron?
https://taoyuanparts.com/blogs/news/...soldering-iron
Old 12-06-2022, 17:18   #6628 (permalink)
Member: 3026866
Hi, how are you? I choose my iPhone
Old 12-06-2022, 17:34   #6629 (permalink)
Member: 3026866
Old 12-07-2022, 10:17   #6630 (permalink)
Member: 3026866
Hi guys,
are you know something about crypto trading?
All Blackberry Hardware and Software Solution youssef01 BlackBerry (RIM) 34 11-01-2012 17:31
I need DVD player hardware and software solution site ..::MOBILES::.. GSM Mobile Links 0 04-05-2009 15:49
O2 Hardware and Software solutions Eagle7 Various 2 04-14-2006 12:47
Page generated in 0.29327 seconds with 10 queries
