11-22-2021, 16:36 | #6602 (permalink) |
Junior Member Join Date: May 2016 Age: 34
Member: 2579634 Status: Offline Sonork: salahell Thanks Meter: 0 | Hi all mombers please im need on litle help ihave problem , on my iphone 11 pro stck on dfu mode - after check flash give (error 6) sma eproblme with - itunes & 3utools |
04-08-2022, 08:39 | #6606 (permalink) |
Junior Member Join Date: Oct 2021 Location: HAZEBROUCK Age: 35
Member: 2998514 Status: Offline Sonork: Flandrmobile2.0 Thanks Meter: 0 | Bonjour à tous. Est-ce que quelqu'un pourrait me guider sur la suppression d'un compte cloud sur un iPad 2 svp. Merci d'avance ! Belle journée ! |
05-09-2022, 18:26 | #6608 (permalink) |
Junior Member Join Date: Mar 2020 Location: Europe
Member: 2950933 Status: Offline Thanks Meter: 0 | Hello, I have an ipad 6 wont turn on, if I push the button, the screen is black and the amperometer indicate an little current consumption up to 250mA and go 0mA. If i connect the power adapter and disconnect the battery the current consumption is variable from 10 mA to 70mA, contiously. |
06-08-2022, 14:57 | #6609 (permalink) |
Freak Poster Join Date: Dec 2016
Member: 2664243 Status: Offline Thanks Meter: 6 | Check here https://www.youtube.com/watch?v=nPGK37qG75Y |
08-09-2022, 07:36 | #6613 (permalink) |
Junior Member Join Date: Apr 2019 Location: S
Member: 2904736 Status: Offline Thanks Meter: 6 | Hello all, I need little help fixing my old iphone 6. I splahed it with water and it worked for a while but after the battery was dischraged I couldn't charge it and PC won't regonize it. I removed the battery out, cleaned board with alcohol, charge the battery on external charger and now I have a working iphone but chrarging doesn't work. PC regonize iphone, 3u tools can't see battery info, iphone also can't see battery health. I left it several hours on charger but it is still at 2% batt. Before I charged battery on external charger, the battery had only 2.45V Is this looks as tristar problem from your side or something else? Between + and - connector, on the board, for battery I had about 45-50kOhm, so it is not shorted. Best regards, Alex |
08-10-2022, 18:03 | #6615 (permalink) |
Member: 2904736 Status: Offline Thanks Meter: 6 | No, I didn’t. But it I don’t think it could be damaged by water. Secondly, now I have conection between phone and PC, phone also see charger even data transfer works. |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
