01-13-2012, 13:10 | #47 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Peshawar,Pakistan
Member: 1251758 Status: Offline Sonork: 100.1614930 Thanks Meter: 94 | Amazing... when i flash by 43925734_RX-51_2009SE_1.2009.42-11.203.2_PR_F5_203_ARM.bin n Menu ok Sim not work.. when i flash by RX-51_2009SE_21.2011.38-1.003_PR_COMBINED_003_ARM.bin. then sim work. menu not upone. |
01-13-2012, 13:29 | #48 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Sure sim will not work. Try this - After flashing SW 21 - Select ONLY RootFs and flash other sw. ONLY RootFs. Should help. |
The Following User Says Thank You to Dzirt For This Useful Post: |
01-13-2012, 14:36 | #49 (permalink) |
Member: 1251758 Status: Offline Sonork: 100.1614930 Thanks Meter: 94 | yes before flash by other verion only click rootfs. phone normal on but menu give eorr. after flash by 21 sw so now phone ok. sim and menu both work. Thanks DZirt |
The Following User Says Thank You to star1989 For This Useful Post: |
01-13-2012, 17:11 | #50 (permalink) |
Freak Poster Join Date: Dec 2011 Location: Poland
Member: 1709265 Status: Offline Thanks Meter: 41 | I have N900, it vibrate, show Nokia logo and restart and so on. I don't know history of this phone, I get it in this condition. Tried to flash but program doesn't "see" the phone. In devices manager is some reaction but don't know how and where it should be listed. Below is video of all procedure. n900.avi - YouTube Notice that program react in some way on connecting phone bcos counter stop at 168 when phone is connectd. What can I do else? BR |
01-13-2012, 18:21 | #51 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2008 Location: at work
Member: 770863 Status: Offline Sonork: 100.1597188 Thanks Meter: 123 | HI @rastogsm Did u follow all these instructions from DZIRT? Need Select Maemo in generation (selected by default) Need select MCU file Press Check Files Press Flash Connect phone holding U button. All is done, waiting till process finish. Also use minimum 50% charge bettery and put usb cable direct to pc dnt use any hub |
01-13-2012, 20:44 | #52 (permalink) | |
Member: 1709265 Status: Offline Thanks Meter: 41 | Quote:
01-14-2012, 04:52 | #53 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | I was aeen only black screen, not video. Anyway - Reinsert battery. Select Maemo Press Connect/info Press and hold U button on phone. Insert cable. It should works Ok. Use cable directly to motherboard. Use short cable. Try different USB port on PC. |
02-29-2012, 23:01 | #56 (permalink) |
No Life Poster Join Date: Nov 2005 Location: USA
Member: 197538 Status: Offline Thanks Meter: 97 | Never mind about drivers .. phone successfully flashed and security code resetted Logs here : Insert cable in to powered OFF phone! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RM-696 , HWRev : 1507 NOLO : 01/05/21 SWVer: DFL61_HARMATTAN_22.2011.44-2.468.4_PR_468 Device mode : Production mode Read info Ok Processing APE Boot... File : DFL61_HARMATTAN_22.2011.44-2.468.4_PR_LEGACY_468_ARM_RM-696_PRD_signed.bin Processing : ape-algo APE Algorithm boot Ok Reopening the connection... RFS mode init Ok Device : RM-696 HW build : 1507 Bat.level : 84 SW release : (empty) Protocol : 108 UPDAPP ver : 1.6.3 Upd/Dev PT : 3 , 3 FL_images : cert-sw,xloader,secondary,rootfs,kernel,moslo,config,mm c,tar,cmt-2nd,cmt-algo,cmt-mcusw Last errors : bb5_rdc_cert_read failed Code Match Ok HW match Ok RFS : Performing SWAP WIPE... Starting Wipe... Bat.level : 84 Battery voltage is enough, starting wipe... Formatting... Can take up to 15 minutes, wait until process complete RFS : Swap format Ok RFS : No any errors RFS Set : Host Protocol set to 108 RFS Set : CMT Verify On RFS Set : Perform RFS On RFS Set : eMMC preserve On ---Processing MCU image--- Processing File : DFL61_HARMATTAN_22.2011.44-2.468.4_PR_LEGACY_468_ARM_RM-696_PRD_signed.bin RFS : Sending config for [cert-sw] -> Ver T : RM-696 -> Ver H : 1507 , 1508 , 1509 , 1510 , 1601 , 1602 , 1603 , 1604 , 1605 , 1701 , 1702 , 1703 , 1704 , 1705 , 1801 , 1802 , 1803 , 1804 , 1805 RFS : Init pipe 00 RFS : Flashing... RFS : Finalizing... cert-sw Flash done RFS : Sending config for [kernel] -> Ver I : 2.6.32-20113720+0m6 RFS : Init pipe 01 RFS : Flashing... RFS : Finalizing... kernel Flash done RFS : Sending config for [rootfs] -> Ver I : DFL61_HARMATTAN_22.2011.44-2.468.4_PR_468 RFS : Init pipe 02 RFS : Flashing... RFS : Finalizing... rootfs Flash done RFS : Sending config for [cmt-2nd] -> Ver T : RM-696 RFS : Init pipe 03 RFS : Flashing... RFS : Finalizing... cmt-2nd Flash done RFS : Sending config for [cmt-algo] -> Ver T : RM-696 RFS : Init pipe 04 RFS : Flashing... RFS : Finalizing... cmt-algo Flash done RFS : Sending config for [cmt-mcusw] -> Ver I : 9.2.2011.21 -> Ver T : RM-696 RFS : Init pipe 05 RFS : Flashing... RFS : Finalizing... cmt-mcusw Flash done RFS : Sending config for [xloader] -> Ver I : 2.1.5+0m6 -> Ver T : RM-696 -> Ver H : 1507 , 1508 , 1509 , 1510 , 1601 , 1602 , 1603 , 1604 , 1605 , 1701 , 1702 , 1703 , 1704 , 1705 , 1801 , 1802 , 1803 , 1804 , 1805 RFS : Init pipe 06 RFS : Flashing... RFS : Finalizing... xloader Flash done RFS : Sending config for [secondary] -> Ver I : 2.1.5+0m6 -> Ver T : RM-696 -> Ver H : 1507 , 1508 , 1509 , 1510 , 1601 , 1602 , 1603 , 1604 , 1605 , 1701 , 1702 , 1703 , 1704 , 1705 , 1801 , 1802 , 1803 , 1804 , 1805 RFS : Init pipe 07 RFS : Flashing... RFS : Finalizing... secondary Flash done Done! Elapsed: 00:18:00 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
03-03-2012, 11:37 | #57 (permalink) |
Member: 1251758 Status: Offline Sonork: 100.1614930 Thanks Meter: 94 | Hi Guys! There is Nokia N900. only Nokia log and then Restart. i have flashed by low and last verion. but problem same.any sualtion about this. thanks |
03-03-2012, 11:47 | #58 (permalink) |
Freak Poster Join Date: Jan 2002 Location: Penang/Malaysia
Member: 8752 Status: Offline Thanks Meter: 26 | card found: S/N 1206:0118 registered to: stboon Connect phone on selected interface... Press and hold "U" button and insert cable! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RX-51 , HWRev : 2204 NOLO : 01/0E/14 SWVer: RX-51_2009SE_20.2010.36-2.204.1_PR_204 Device mode : Production mode Read info Ok Press and hold "U" button and insert cable! (Ignore if phone Connected) Waiting for NOLO... Phone disconected! Connect phone on selected interface... Press and hold "U" button and insert cable! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RX-51 , HWRev : 2204 NOLO : 01/0E/14 SWVer: RX-51_2009SE_20.2010.36-2.204.1_PR_204 Device mode : Production mode Read info Ok ---Processing MCU image--- Executing PostFlash : Reset RD Flags Executing PostFlash : Reboot Done! Elapsed: 00:00:03 Connect phone on selected interface... Press and hold "U" button and insert cable! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RX-51 , HWRev : 2204 NOLO : 01/0E/14 SWVer: RX-51_2009SE_20.2010.36-2.204.1_PR_204 Device mode : Production mode Read info Ok ---Processing MCU image--- Executing PostFlash : Reset RD Flags Executing PostFlash : Reboot Done! Elapsed: 00:00:03 Connect phone on selected interface... Press and hold "U" button and insert cable! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RX-51 , HWRev : 2204 NOLO : 01/0E/14 SWVer: RX-51_2009SE_20.2010.36-2.204.1_PR_204 Device mode : Production mode Read info Ok ---Processing MCU image--- Processing NOL part File : RX-51_2009SE_20.2010.36-2.204.1_PR_COMBINED_204_ARM.bin Processing : xloader , 1.4.14.9+0m5 Processing : secondary , 1.4.14.9+0m5 NOL part Ok, boot flash done Processing APE part File : RX-51_2009SE_20.2010.36-2.204.1_PR_COMBINED_204_ARM.bin Processing : kernel , 2.6.28-20103103+0m5 Kernel flash Ok Processing APE part File : RX-51_2009SE_20.2010.36-2.204.1_PR_COMBINED_204_ARM.bin Processing : rootfs , RX-51_2009SE_20.2010.36-2.204.1_PR_204 RootFs flash Ok Processing CMT part File : RX-51_2009SE_20.2010.36-2.204.1_PR_COMBINED_204_ARM.bin Processing : cmt-2nd , BB5_09.36 Processing : cmt-algo , BB5_09.36 Processing : cmt-mcusw , rx51_ICPR82_10w08 CMT part prepare Ok, files are sent Program CMT request Ok Switch : OSSO UART+USB Version : RX-51_2009SE_20.2010.36-2.204.1_PR_204 Switch CMT request Ok CMT : Erasing... CMT : Program... CMT : Program Finished! Executing PostFlash : Reset RD Flags Executing PostFlash : Reboot Done! Elapsed: 00:01:47 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
The Following User Says Thank You to stboon For This Useful Post: |
Guide to Rolis Flasher! | davieb | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 01-29-2002 16:53 |
Unlocking & Repair Guide | guruguide | GSM Mobile Links | 1 | 12-13-2001 15:23 |
Free SMSc's and Flashing Guides | davieb | GSM Mobile Links | 0 | 12-05-2001 15:51 |
Idiots guide to unlocking Nokia 3210 V6.00 NSE - 8/9 (03-10-00) req. | belker | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-23-2001 11:26 |
I mean pc guide for nokia 8210 | linda | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-18-2000 20:49 |
