03-04-2012, 07:11 | #62 (permalink) |
Freak Poster Join Date: Jan 2002 Location: Penang/Malaysia
Member: 8752 Status: Offline Thanks Meter: 26 | the most important is DONT downgrade or it will show no imei.. ALWAYS flash with higher version..problem will solve..after flash no read simcard ..also flash with higher version..that all |
03-06-2012, 10:53 | #63 (permalink) |
Cheater -Don't Deal with him- Join Date: Mar 2006 Location: ACCRA GHANA Age: 39
Member: 244250 Status: Offline Sonork: 100.160773 Thanks Meter: 196 | Core : v1.40 , FlashEngine : v1.23 Insert cable in to powered OFF phone! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RM-696 , HWRev : 1603 NOLO : 01/05/21 SWVer: DFL61_HARMATTAN_20.2011.40-4_PR_001 Device mode : Production mode Read info Ok Processing APE Boot... File : DFL61_HARMATTAN_30.2012.07-1_PR_LEGACY_005-OEM1-958_ARM.bin Processing : ape-algo APE Algorithm boot Ok Reopening the connection... RFS mode init Ok Device : RM-696 HW build : 1603 Bat.level : 76 SW release : (empty) Protocol : 108 UPDAPP ver : 1.7.2 Upd/Dev PT : 3 , 3 FL_images : cert-sw,xloader,secondary,rootfs,kernel,moslo,config,mm c,tar,cmt-2nd,cmt-algo,cmt-mcusw Last errors : bb5_rdc_cert_read failed Code Match Ok HW match Ok RFS : Performing SWAP WIPE... Starting Wipe... Bat.level : 76 Battery voltage is enough, starting wipe... Formatting... Can take up to 15 minutes, wait until process complete RFS : Swap format Ok -> Last errors : Could not read old secinfo RFS Set : Host Protocol set to 108 RFS Set : CMT Verify On RFS Set : Perform RFS On RFS Set : eMMC preserve On ---Processing MCU image--- Processing File : DFL61_HARMATTAN_30.2012.07-1_PR_LEGACY_005-OEM1-958_ARM.bin RFS : Sending config for [cert-sw] -> Ver T : RM-696 -> Ver H : 1507 , 1508 , 1509 , 1510 , 1601 , 1602 , 1603 , 1604 , 1605 , 1701 , 1702 , 1703 , 1704 , 1705 , 1801 , 1802 , 1803 , 1804 , 1805 RFS : Init pipe 00 RFS : Flashing... RFS : Finalizing... cert-sw Flash done RFS : Sending config for [kernel] -> Ver I : 2.6.32-20115101+0m7 RFS : Init pipe 01 RFS : Flashing... RFS : Finalizing... kernel Flash done RFS : Sending config for [rootfs] -> Ver I : DFL61_HARMATTAN_30.2012.07-1_PR_005 RFS : Init pipe 02 RFS : Flashing... RFS : Finalizing... rootfs Flash done RFS : Sending config for [cmt-2nd] -> Ver T : RM-696 RFS : Init pipe 03 RFS : Flashing... RFS : Finalizing... cmt-2nd Flash done RFS : Sending config for [cmt-algo] -> Ver T : RM-696 RFS : Init pipe 04 RFS : Flashing... RFS : Finalizing... RFS : ERROR_PIPE_FINAL_REQ FAILED Receiving error list... Last errors : Timeout while waiting for the HWBREAK Could not reboot into cold bootmode [Pipe 4] Finishing in error state with status 1 Flashing failed More info in Last Error Log Elapsed: 00:22:04 Connect phone on selected interface... what could be the problem pls help me get this phone flashed ..thx |
03-06-2012, 15:58 | #65 (permalink) |
Member: 244250 Status: Offline Sonork: 100.160773 Thanks Meter: 196 | hung on nokia only nokia and it give me some worning ...pls phonw was working b4 i flash it . plsi need help . |
03-19-2012, 08:11 | #67 (permalink) |
Freak Poster Join Date: Oct 2006
Member: 366714 Status: Offline Thanks Meter: 21 | N900 after flash Nokia startup logo only..then Restart. Please Help. Here is the log.... Press and hold "U" button and insert cable! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RX-51 , HWRev : 2204 NOLO : 01/0E/14 SWVer: RX-51_2009SE_21.2011.38-1_PR_MR0 Device mode : Production mode Read info Ok Press and hold "U" button and insert cable! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RX-51 , HWRev : 2204 NOLO : 01/0E/14 SWVer: RX-51_2009SE_21.2011.38-1_PR_MR0 Device mode : Production mode Read info Ok ---Processing MCU image--- Processing NOL part File : RX-51_2009SE_21.2011.38-1_PR_COMBINED_MR0_ARM.bin Processing : xloader , 1.4.14.9+0m5 Processing : secondary , 1.4.14.9+0m5 NOL part Ok, boot flash done Processing APE part File : RX-51_2009SE_21.2011.38-1_PR_COMBINED_MR0_ARM.bin Processing : kernel , 2.6.28-20103103+0m5 Kernel flash Ok Processing APE part File : RX-51_2009SE_21.2011.38-1_PR_COMBINED_MR0_ARM.bin Processing : rootfs , RX-51_2009SE_21.2011.38-1_PR_MR0 RootFs flash Ok Processing CMT part File : RX-51_2009SE_21.2011.38-1_PR_COMBINED_MR0_ARM.bin Processing : cmt-2nd , BB5_09.36 Processing : cmt-algo , BB5_09.36 Processing : cmt-mcusw , rx51_ICPR82_10w08 CMT part prepare Ok, files are sent Program CMT request Ok Switch : OSSO UART+USB Version : RX-51_2009SE_21.2011.38-1_PR_MR0 Switch CMT request Ok CMT : Erasing... CMT : Program... CMT : Program Finished! ---Processing eMMC image--- Setting RFS ... Reopening the connection... RFS : Init Ok Processing File : RX-51_2009SE_10.2010.13-2.VANILLA_PR_EMMC_MR0_ARM.bin RFS : Sending config for [mmc] -> Ver I : RX-51_2009SE_10.2010.13-2.VANILLA RFS : Flashing... RFS : Finalizing... mmc Flash done Executing PostFlash : Reboot Done! |
03-19-2012, 19:39 | #70 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Flashing is fully done - so - need check HW part. Seems phone can be water damaged or broken. |
The Following User Says Thank You to Dzirt For This Useful Post: |
03-24-2012, 11:21 | #71 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | Quote:
Sir, Dzirt is there any choice of backip up RPL for security pirpose incase of damaged security or imei purpose ? Bcoz it cannot read RPL backup like other NOKIA models. BR | |
03-26-2012, 11:48 | #72 (permalink) |
No Life Poster Join Date: Mar 2008 Location: City of Temples
Member: 729381 Status: Offline Thanks Meter: 248 | hello, how to type these letters (red marked) coz i didn't see in keypad echo root:$(grep -A 13 lock_code /dev/mtd1|tail -1): > /home/user/MyDocs/lock |
03-26-2012, 12:00 | #73 (permalink) | |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
Press button - Blue arrow - in left side, second from up. After it press upper button in left side - Sym/Ctrl - you will see additional symbols. | |
04-11-2012, 13:45 | #74 (permalink) |
No Life Poster Join Date: Jan 2005 Location: EVERYWHERE U GO Age: 46
Member: 106026 Status: Offline Sonork: 100.77890 Thanks Meter: 127 | hello pls i have n900 after nokia logo bring loading display n stayin in loading always...i flash it with higher 21 firmware still same>>> pls which file is for emmc??? i will still post logs br...urgent help needed |
04-11-2012, 13:57 | #75 (permalink) |
Member: 106026 Status: Offline Sonork: 100.77890 Thanks Meter: 127 | card found: S/N registered to: damabib Connect phone on selected interface... Check : Processing RX-51_2009SE_21.2011.38-1_PR_COMBINED_MR0_ARM.bin BLK_INF : kernel BLK_VER : 2.6.28-20103103+0m5 ========== BLK_INF : rootfs BLK_VER : RX-51_2009SE_21.2011.38-1_PR_MR0 ========== BLK_INF : cmt-2nd BLK_VER : BB5_09.36 ========== BLK_INF : cmt-algo BLK_VER : BB5_09.36 ========== BLK_INF : cmt-mcusw BLK_VER : rx51_ICPR82_10w08 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== Check : File Is Ok ! Check : Processing RX-51_2009SE_21.2011.38-1_PR_COMBINED_MR0_ARM.bin BLK_INF : kernel BLK_VER : 2.6.28-20103103+0m5 ========== BLK_INF : rootfs BLK_VER : RX-51_2009SE_21.2011.38-1_PR_MR0 ========== BLK_INF : cmt-2nd BLK_VER : BB5_09.36 ========== BLK_INF : cmt-algo BLK_VER : BB5_09.36 ========== BLK_INF : cmt-mcusw BLK_VER : rx51_ICPR82_10w08 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 ========== Check : File Is Ok ! Check : Processing ~RX-51_2009SE_21.2011.38-1.003_PR_COMBINED_003_ARM.bin.!ecl BLK_INF : kernel BLK_VER : 2.6.28-20103103+0m5 ========== BLK_INF : rootfs BLK_VER : RX-51_2009SE_21.2011.38-1.003_PR_003 ========== Check : File Is Ok ! Core : v1.42 , FlashEngine : v1.25 Press and hold "U" button and insert cable! (Ignore if phone Connected) Waiting for NOLO... Maemo Phone not found Core : v1.42 , FlashEngine : v1.25 Press and hold "U" button and insert cable! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RX-51 , HWRev : 2101 NOLO : 01/0E/14 SWVer: RX-51_2009SE_21.2011.38-1_PR_MR0 Device mode : Production mode Read info Ok ---Processing MCU image--- Processing NOL part File : RX-51_2009SE_21.2011.38-1_PR_COMBINED_MR0_ARM.bin Processing : xloader , 1.4.14.9+0m5 Processing : secondary , 1.4.14.9+0m5 NOL part Ok, boot flash done Processing APE part File : RX-51_2009SE_21.2011.38-1_PR_COMBINED_MR0_ARM.bin Processing : kernel , 2.6.28-20103103+0m5 Kernel flash Ok Processing APE part File : RX-51_2009SE_21.2011.38-1_PR_COMBINED_MR0_ARM.bin Processing : rootfs , RX-51_2009SE_21.2011.38-1_PR_MR0 RootFs flash Ok Processing CMT part File : RX-51_2009SE_21.2011.38-1_PR_COMBINED_MR0_ARM.bin Processing : cmt-2nd , BB5_09.36 Processing : cmt-algo , BB5_09.36 Processing : cmt-mcusw , rx51_ICPR82_10w08 CMT part prepare Ok, files are sent Program CMT request Ok Switch : OSSO UART+USB Version : RX-51_2009SE_21.2011.38-1_PR_MR0 Switch CMT request Ok CMT : Erasing... CMT : Program... CMT : Program Finished! ---Processing eMMC image--- Setting RFS ... Reopening the connection... RFS : Init Ok Processing File : ~RX-51_2009SE_21.2011.38-1.003_PR_COMBINED_003_ARM.bin.!ecl |
Guide to Rolis Flasher! | davieb | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 01-29-2002 16:53 |
Unlocking & Repair Guide | guruguide | GSM Mobile Links | 1 | 12-13-2001 15:23 |
Free SMSc's and Flashing Guides | davieb | GSM Mobile Links | 0 | 12-05-2001 15:51 |
Idiots guide to unlocking Nokia 3210 V6.00 NSE - 8/9 (03-10-00) req. | belker | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-23-2001 11:26 |
I mean pc guide for nokia 8210 | linda | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-18-2000 20:49 |
