01-26-2020, 13:42 | #1052 (permalink) | |
No Life Poster Join Date: Apr 2014 Location: west java
Member: 2162000 Status: Offline Sonork: 100.1670061 Thanks Meter: 205 | cph 1803 remove lock CPH 1803 remove lock done Quote:
02-03-2020, 18:54 | #1053 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Oppo A1k Pattern Remove Code: Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : 20 MHz Connecting... Device : Samsung eMMC QD63MB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100514436334D420303CA06EF8675 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QD63MB Product revision : 0.3 Product serial number : (hex) 3CA06EF Manufacturing date : 08/2019 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QD63MB_03_02_2020_16_29_42.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.3; FW: 1.24. P00: GPT (00000000, 00000040) 32 KB P01: boot_para (00000040, 00000800) 1024 KB P02: recovery (00000840, 00010000) 32 MB P03: para (00010840, 00000400) 512 KB P04: opporeserve1 (00010C40, 00004000) 8 MB P05: opporeserve2 (00014C40, 00020000) 64 MB P06: opporeserve3 (00034C40, 00020000) 64 MB P07: oppo_custom (00054C40, 00000800) 1024 KB P08: expdb (00055440, 0000A000) 20 MB P09: frp (0005F440, 00000800) 1024 KB P10: vbmeta (0005FC40, 00004000) 8 MB P11: nvcfg (00063C40, 00010000) 32 MB P12: nvdata (00073C40, 00020000) 64 MB P13: metadata (00093C40, 00010000) 32 MB P14: protect1 (000A3C40, 00004000) 8 MB P15: protect2 (000A7C40, 000043C0) 8.469 MB P16: seccfg (000AC000, 00004000) 8 MB P17: persist (000B0000, 00018000) 48 MB P18: sec1 (000C8000, 00001000) 2048 KB P19: proinfo (000C9000, 00001800) 3072 KB P20: md1img (000CA800, 00032000) 100 MB P21: spmfw (000FC800, 00000800) 1024 KB P22: scp1 (000FD000, 00000800) 1024 KB P23: scp2 (000FD800, 00000800) 1024 KB P24: sspm_1 (000FE000, 00000800) 1024 KB P25: sspm_2 (000FE800, 00000800) 1024 KB P26: gz1 (000FF000, 00008000) 16 MB P27: gz2 (00107000, 00008000) 16 MB P28: nvram (0010F000, 00020000) 64 MB P29: lk (0012F000, 00000800) 1024 KB P30: lk2 (0012F800, 00000800) 1024 KB P31: boot (00130000, 00010000) 32 MB P32: logo (00140000, 00008000) 16 MB P33: dtbo (00148000, 00008000) 16 MB P34: tee1 (00150000, 00002800) 5 MB P35: tee2 (00152800, 00005800) 11 MB P36: odm (00158000, 00080000) 256 MB P37: vendor (001D8000, 001CC000) 920 MB P38: system (003A4000, 00960000) 4.688 GB P39: cache (00D04000, 000D8000) 432 MB P40: userdata (00DDC000, 02C447DF) 22.13 GB P41: otp (03A207DF, 00015800) 43 MB P42: flashinfo (03A35FDF, 00008000) 16 MB Backuping nvdata partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QD63MB_nvdata_0x73c40_0x20000_03_02_2020_16_29_42.bin file... Reading. Please wait... ERROR[011]: Read error. Attempting to read... Done. Elapsed time 00:02:16 SW: 2.0.3; FW: 1.24. Partition table has been found on device. Don't forget to reconnect the device after writing to see changes. Writting partitions. Please wait... Writing partition para from C:/Users/M FARHAN/Downloads/Pin pattren Remove/Pin pattren Remove/Factory reset keep Media.bin file... ERROR[012]: Write error. Attempting to read... Done. Writing is finished. SW: 2.0.3; FW: 1.24. Reconnect the device to see changes. Disconnected. |
The Following 2 Users Say Thank You to Tanha0321 For This Useful Post: |
03-10-2020, 19:01 | #1054 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Ukraine Age: 44
Member: 75408 Status: Offline Thanks Meter: 1,190 | Lenovo L38041 Repair by USB successfully done: Code: Welcome to Medusa Pro Software version 2.0.6. Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: Generic USB Smart Card Reader 0 Reader #3: USB CCID Smart Card Reader 0 Model Settings: Interface : USB Loading custom loader C:/1/L38041_ROW_OPEN_USER_Q00020.0_O_ZUI_5.0.117_ST_181225_qpst/prog_emmc_ufs_firehose_Sdm660_lite.elf file... Core : Custom Loader Loader : prog_emmc_ufs_firehose_Sdm660_lite.elf Connecting... Sending loader...OK. Loader successfully initialized. Device : CoreID_000CC0E1 Core : Custom Loader Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) Connect successful. --------------------------------------------------------------- SW: 2.0.6; FW: . P00: GPT (00000000, 00020000) 64 MB P01: xbl (00020000, 00001C00) 3584 KB P02: xblbak (00021C00, 00001C00) 3584 KB P03: tz (00023800, 00002000) 4 MB P04: tzbak (00025800, 00002000) 4 MB P05: rpm (00027800, 00000400) 512 KB P06: rpmbak (00027C00, 00000400) 512 KB P07: hyp (00028000, 00000400) 512 KB P08: hypbak (00028400, 00000400) 512 KB P09: pmic (00028800, 00000400) 512 KB P10: pmicbak (00028C00, 00000400) 512 KB P11: fsg (00029000, 00001000) 2048 KB P12: fsgall (0002A000, 00002000) 4 MB P13: boot (00040000, 00020000) 64 MB P14: recovery (00060000, 00020000) 64 MB P15: keymaster (00080000, 00000800) 1024 KB P16: keymasterbak (00080800, 00000800) 1024 KB P17: cmnlib (00081000, 00000800) 1024 KB P18: cmnlib64 (00081800, 00000800) 1024 KB P19: cmnlibbak (00082000, 00000800) 1024 KB P20: cmnlib64bak (00082800, 00000800) 1024 KB P21: mdtpsecapp (00083000, 00002000) 4 MB P22: mdtpsecappbak (00085000, 00002000) 4 MB P23: mdtp (00087000, 00010000) 32 MB P24: mdtpbak (00097000, 00010000) 32 MB P25: modem (000A7000, 00037000) 110 MB P26: dsp (000DE000, 00008000) 16 MB P27: abl (000E6000, 00000800) 1024 KB P28: ablbak (000E6800, 00000800) 1024 KB P29: dip (000E7000, 00000800) 1024 KB P30: devinfo (000E7800, 00000008) 4 KB P31: apdp (000E7808, 00000200) 256 KB P32: msadp (000E7A08, 00000200) 256 KB P33: dpo (000E7C08, 00000002) 1024 b P34: splash (000E7C10, 00010520) 32.64 MB P35: limits (000F8130, 00000008) 4 KB P36: toolsfv (000F8138, 00000800) 1024 KB P37: logfs (00100000, 00004000) 8 MB P38: ddr (00120000, 00000800) 1024 KB P39: sec (00120800, 00000020) 16 KB P40: bluetooth (00120820, 00000800) 1024 KB P41: bluetoothbak (00121020, 00000800) 1024 KB P42: fsc (00140000, 00000002) 1024 b P43: ssd (00140008, 00000010) 8 KB P44: modemst1 (00140018, 00001000) 2048 KB P45: modemst2 (00141018, 00001000) 2048 KB P46: persist (00142018, 00010000) 32 MB P47: misc (00152018, 00000800) 1024 KB P48: keystore (00152818, 00000400) 512 KB P49: devcfg (00152C18, 00000800) 1024 KB P50: devcfgbak (00153418, 00000800) 1024 KB P51: frp (00153C18, 00000400) 512 KB P52: logdump (00154018, 00020000) 64 MB P53: sti (00174018, 00001000) 2048 KB P54: storsec (00180000, 00000100) 128 KB P55: rawdump (001A0000, 00040000) 128 MB P56: vbmeta (001E0000, 00000080) 64 KB P57: cache (001E0080, 00080000) 256 MB P58: vendor (00260080, 00200000) 1024 MB P59: system (00480000, 00A00000) 5 GB P60: userdata (00E80000, 065FBFDF) 50.99 GB Backuping fsg partition... Opening C:/Program Files/Medusa Pro Software/Backups/_fsg_0x29000_0x1000_10_03_2020_19_36_41.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.0.6; FW: . Backuping modemst1 partition... Opening C:/Program Files/Medusa Pro Software/Backups/_modemst1_0x140018_0x1000_10_03_2020_19_36_41.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.0.6; FW: . Backuping modemst2 partition... Opening C:/Program Files/Medusa Pro Software/Backups/_modemst2_0x141018_0x1000_10_03_2020_19_36_41.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.0.6; FW: . Selected file: C:/1/L38041_ROW_OPEN_USER_Q00020.0_O_ZUI_5.0.117_ST_181225_qpst/rawprogram0.xml. Selected file: C:/1/L38041_ROW_OPEN_USER_Q00020.0_O_ZUI_5.0.117_ST_181225_qpst/patch0.xml. Backuping. Please wait... Reading partition modemst1... Done. Reading partition modemst2... Done. Backuping finished. #grenWriting. Please wait... Write data verification is enabled. Writing partition xbl... Done. Writing partition xblbak... Done. Writing partition tz... Done. Writing partition tzbak... Done. Writing partition rpm... Done. Writing partition rpmbak... Done. Writing partition hyp... Done. Writing partition hypbak... Done. Writing partition pmic... Done. Writing partition pmicbak... Done. Writing partition boot... Done. Writing partition recovery... Done. Writing partition keymaster... Done. Writing partition keymasterbak... Done. Writing partition cmnlib... Done. Writing partition cmnlib64... Done. Writing partition cmnlibbak... Done. Writing partition cmnlib64bak... Done. Writing partition mdtpsecapp... Done. Writing partition mdtpsecappbak... Done. Writing partition mdtp... Done. Writing partition mdtpbak... Done. Writing partition modem... Done. Writing partition dsp... Done. Writing partition abl... Done. Writing partition ablbak... Done. Writing partition apdp... Done. Writing partition msadp... Done. Writing partition splash... Done. Writing partition bluetooth... Done. Writing partition bluetoothbak... Done. Writing partition devcfg... Done. Writing partition devcfgbak... Done. Writing partition storsec... Done. Writing partition cache... Done. Writing partition cache... Done. Writing partition cache... Done. Writing partition vendor... Done. Writing partition vendor... Done. Writing partition vendor... Done. Writing partition vendor... Done. Writing partition vendor... Done. Writing partition vendor... Done. Writing partition vendor... Done. Writing partition vendor... Done. Writing partition vendor... Done. Writing partition vendor... Done. Writing partition vendor... Done. Writing partition vendor... Done. Writing partition vendor... Done. Writing partition vendor... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing MBR...Done. Writing primary GPT...Done. Writing partition PrimaryGPT... Done. Writing partition BackupGPT... Done. Writing finished. SW: 2.0.6; FW: . Disconnected. |
04-21-2020, 20:46 | #1055 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,104 | ASUS Zenfone WW ZD551KL srf USB created done Code: Brand : asus ProdName : WW_Z00T ProdModel : ASUS_Z00TD Device : Z00T AndroidVer: 6.0.1 Manufact. : asus Code: Welcome to Medusa Pro Software version 2.0.8. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Alcor Micro USB Smart Card Reader 1 Reader #2: NXP NXP's Proximity based PCSC Reader 0 Model Settings: Interface : USB Core : Auto Detect Loader : Auto Detect Connecting... Finished calculating Searching loader... Loader found: Core : Qualcomm MSM8939 Loader : QLoader_MSM8939_V1 Sending loader...OK. Loader successfully initialized. Device : CoreID_0090B0E1 Core : Auto Detect Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) Connect successful. --------------------------------------------------------------- SW: 2.0.8; FW: . P00: GPT (00000000, 00004400) 17 KB P01: sbl1 (00004400, 00140000) 1280 KB P02: sbl1bak (00144400, 00140000) 1280 KB P03: rpm (00284400, 00080000) 512 KB P04: rpmbak (00304400, 00080000) 512 KB P05: tz (00384400, 00080000) 512 KB P06: tzbak (00404400, 00080000) 512 KB P07: hyp (00484400, 00080000) 512 KB P08: hypbak (00504400, 00080000) 512 KB P09: DDR (00584400, 00008000) 32 KB P10: ssd (0058C400, 00002000) 8 KB P11: sec (0058E400, 00004000) 16 KB P12: aboot (00592400, 00500000) 5 MB P13: abootbak (01000000, 00500000) 5 MB P14: splash (01500000, 00500000) 5 MB P15: devinfo (01A00000, 00100000) 1024 KB P16: fsg (02000000, 00180000) 1536 KB P17: fsc (02180000, 00000400) 1024 b P18: modemst1 (02180400, 00180000) 1536 KB P19: modemst2 (02300400, 00180000) 1536 KB P20: factory (02480400, 00A00000) 10 MB P21: factorybak (02E80400, 00A00000) 10 MB P22: asuskey (03880400, 00100000) 1024 KB P23: asuskey2 (03980400, 00100000) 1024 KB P24: asuskey3 (03A80400, 00100000) 1024 KB P25: asuskey4 (03B80400, 00100000) 1024 KB P26: asuskey5 (03C80400, 00100000) 1024 KB P27: asusgpt (03D80400, 00100000) 1024 KB P28: asusgpt1 (03E80400, 00100000) 1024 KB P29: asusgpt2 (03F80400, 00100000) 1024 KB P30: misc (04080400, 00100000) 1024 KB P31: keystore (04180400, 00080000) 512 KB P32: config (04200400, 00008000) 32 KB P33: asdf (04208400, 02000000) 32 MB P34: abootdebug (06208400, 00200000) 2048 KB P35: persistent (06408400, 00100000) 1024 KB P36: oem (07000000, 02000000) 32 MB P37: boot (09000000, 02000000) 32 MB P38: recovery (0B000000, 02000000) 32 MB P39: persist (0D000000, 02000000) 32 MB P40: asusfw (0F000000, 01000000) 16 MB P41: modem (10000000, 04000000) 64 MB P42: ADF (14000000, 02000000) 32 MB P43: APD (16000000, 0D000000) 208 MB P44: cache (23000000, 02000000) 32 MB P45: system (25000000, C0000000) 3072 MB P46: userdata (E5000000, 662BFBE00) 25.54 GB Backuping fsg partition... Opening C:/Program Files (x86)/Octoplus Pro JTAG Software/Backups/_fsg_0x10000_0xc00_21_04_2020_20_29_15.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.0.8; FW: . Backuping modemst1 partition... Opening C:/Program Files (x86)/Octoplus Pro JTAG Software/Backups/_modemst1_0x10c02_0xc00_21_04_2020_20_29_15.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.0.8; FW: . Backuping modemst2 partition... Opening C:/Program Files (x86)/Octoplus Pro JTAG Software/Backups/_modemst2_0x11802_0xc00_21_04_2020_20_29_15.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.0.8; FW: . Added partition GPT to constructor file. Added partition sbl1 to constructor file. Added partition sbl1bak to constructor file. Added partition rpm to constructor file. Added partition rpmbak to constructor file. Added partition tz to constructor file. Added partition tzbak to constructor file. Added partition hyp to constructor file. Added partition hypbak to constructor file. Added partition DDR to constructor file. Added partition ssd to constructor file. Added partition sec to constructor file. Added partition aboot to constructor file. Added partition abootbak to constructor file. Added partition splash to constructor file. Added partition devinfo to constructor file. Added partition misc to constructor file. Added partition asdf to constructor file. Added partition abootdebug to constructor file. Added partition persistent to constructor file. Added partition boot to constructor file. Added partition recovery to constructor file. Added partition persist to constructor file. Added partition asusfw to constructor file. Added partition modem to constructor file. SRF "C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/Asus_ZD551KL (WW_Z00T)_USB_TP.srf" has been installed successfully. Save to file... Reading partition GPT... Done. Reading is finished. SW: 2.0.8; FW: . Save to C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder file... Reading partition GPT... Done. Reading is finished. SW: 2.0.8; FW: . Disconnected. |
05-01-2020, 15:02 | #1056 (permalink) |
Insane Poster Join Date: Nov 2017 Location: Ukraine Age: 29
Member: 2783598 Status: Offline Sonork: not have Thanks Meter: 23 | OPPO CPH1903 Remove pasword Succesfully DONE isphttps://ibb.co/6y0XvWM Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC RH64AB Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 150100524836344142055D879A02B5E9 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : RH64AB Product revision : 0.5 Product serial number : (hex) 5D879A02 Manufacturing date : 11/2018 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30531584 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 8f800000 bytes Device sector size : 512 bytes Partition offset : 2048000 Number of sectors : 8323072 Build ID : OPM1.171019.026 Release ID : 8.1.0 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20191116.143618 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/RH64AB_01_05_2020_15_50_19.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.9; FW: 1.24. P00: GPT (00000000, 00000028) 20 KB P01: oppodycnvbk (00000028, 00005000) 10 MB P02: oppostanvbk (00005028, 00005000) 10 MB P03: modemst1 (0000A028, 00000C00) 1536 KB P04: modemst2 (0000AC28, 00000C00) 1536 KB P05: persist (0000B828, 00010000) 32 MB P06: opporeserve1 (0001B828, 00004000) 8 MB P07: opporeserve2 (0001F828, 00020000) 64 MB P08: fsc (0003F828, 00000002) 1024 b P09: ssd (0003F830, 00000010) 8 KB P10: sbl1 (0003F840, 00000400) 512 KB P11: rpm (0003FC40, 00000400) 512 KB P12: tz (00040040, 00001000) 2048 KB P13: devcfg (00041040, 00000200) 256 KB P14: sbl1bak (00041240, 00000400) 512 KB P15: rpmbak (00041640, 00000400) 512 KB P16: tzbak (00041A40, 00001000) 2048 KB P17: devcfgbak (00042A40, 00000200) 256 KB P18: dsp (00042C40, 00008000) 16 MB P19: DDR (0004C000, 00000040) 32 KB P20: fsg (0004C040, 00000C00) 1536 KB P21: sec (0004CC40, 00000020) 16 KB P22: aboot (0004CC60, 00000800) 1024 KB P23: abootbak (0004D460, 00000800) 1024 KB P24: modem (0004DC60, 00040000) 128 MB P25: dtbo (0008DC60, 00004000) 8 MB P26: vbmeta (00091C60, 00000080) 64 KB P27: boot (00091CE0, 00020000) 64 MB P28: recovery (000B1CE0, 00020000) 64 MB P29: devinfo (000D1CE0, 00000800) 1024 KB P30: splash (000D4000, 00005800) 11 MB P31: LOGO (000D9800, 00010000) 32 MB P32: DRIVER (000E9800, 00010000) 32 MB P33: cache (000F9800, 00080000) 256 MB P34: misc (00179800, 00000800) 1024 KB P35: keystore (0017A000, 00000400) 512 KB P36: config (0017A400, 00000040) 32 KB P37: oem (0017A440, 00000800) 1024 KB P38: limits (0017C000, 00000040) 32 KB P39: mota (00180000, 00000400) 512 KB P40: dip (00180400, 00000800) 1024 KB P41: mdtp (00180C00, 00010000) 32 MB P42: syscfg (00190C00, 00000400) 512 KB P43: mcfg (00191000, 00002000) 4 MB P44: lksecapp (00194000, 00000100) 128 KB P45: cmnlib (00194100, 00000800) 1024 KB P46: cmnlib64 (00194900, 00000800) 1024 KB P47: keymaster (00195100, 00000800) 1024 KB P48: lksecappbak (00195900, 00000100) 128 KB P49: cmnlibbak (00195A00, 00000800) 1024 KB P50: cmnlib64bak (00196200, 00000800) 1024 KB P51: keymasterbak (00196A00, 00000800) 1024 KB P52: apdp (00198000, 00000200) 256 KB P53: msadp (00198200, 00000200) 256 KB P54: dpo (00198400, 00000010) 8 KB P55: logdump (00198410, 00020000) 64 MB P56: vm-kystore (001B8410, 00000800) 1024 KB P57: vm-data (001B8C10, 00005000) 10 MB P58: hyp (001C0000, 00004000) 8 MB P59: vm-system (001C4000, 00020000) 64 MB P60: vm-linux (001E4000, 00010000) 32 MB P61: system (001F4000, 007F0000) 4064 MB P62: vendor (009E4000, 0020FB00) 1055 MB P63: userdata (00BF4000, 06887FDF) 52.27 GB Backuping modemst1 partition... Opening C:/Program Files/Medusa Pro Software/Backups/RH64AB_modemst1_0xa028_0xc00_01_05_2020_15_50_19.b in file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.0.9; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files/Medusa Pro Software/Backups/RH64AB_modemst2_0xac28_0xc00_01_05_2020_15_50_19.b in file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.0.9; FW: 1.24. Backuping fsg partition... Opening C:/Program Files/Medusa Pro Software/Backups/RH64AB_fsg_0x4c040_0xc00_01_05_2020_15_50_19.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.0.9; FW: 1.24. Partition table has been found on device. Reset operation finished Backuping FRP data... Opening C:/Program Files/Medusa Pro Software/Backups/FRP_0x17a400_0x40_01_05_2020_15_59_04.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.0.9; FW: 1.24. Removing FRP. Please wait... Done. SW: 2.0.9; FW: 1.24. Disconnected. |
The Following User Says Thank You to pavlosupruniuk1 For This Useful Post: |
05-13-2020, 06:27 | #1057 (permalink) |
Member: 2162000 Status: Offline Sonork: 100.1670061 Thanks Meter: 205 | rmx 1941 remove lock new update Code: Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC GD6BMB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100474436424D4201353A9063566D Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : GD6BMB Product revision : 0.1 Product serial number : (hex) 353A9063 Manufacturing date : 05/2019 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 3145728 Number of sectors : 7553024 Build ID : PPR1.180610.011 Release ID : 9 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : full_oppo6762_18540-user 9 PPR1.180610.011 eng.root.20200109.000921 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/GD6BMB_13_05_2020_12_22_21.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.9; FW: 1.24. P00: GPT (00000000, 00000040) 32 KB P01: boot_para (00000040, 00000800) 1024 KB P02: recovery (00000840, 00010000) 32 MB P03: para (00010840, 00000400) 512 KB P04: opporeserve1 (00010C40, 00004000) 8 MB P05: opporeserve2 (00014C40, 00020000) 64 MB P06: opporeserve3 (00034C40, 00020000) 64 MB P07: oppo_custom (00054C40, 00000800) 1024 KB P08: expdb (00055440, 0000A000) 20 MB P09: frp (0005F440, 00000800) 1024 KB P10: vbmeta (0005FC40, 00004000) 8 MB P11: nvcfg (00063C40, 00010000) 32 MB P12: nvdata (00073C40, 00020000) 64 MB P13: metadata (00093C40, 00010000) 32 MB P14: protect1 (000A3C40, 00004000) 8 MB P15: protect2 (000A7C40, 000043C0) 8.469 MB P16: seccfg (000AC000, 00004000) 8 MB P17: persist (000B0000, 00018000) 48 MB P18: sec1 (000C8000, 00001000) 2048 KB P19: proinfo (000C9000, 00001800) 3072 KB P20: md1img (000CA800, 00032000) 100 MB P21: spmfw (000FC800, 00000800) 1024 KB P22: scp1 (000FD000, 00000800) 1024 KB P23: scp2 (000FD800, 00000800) 1024 KB P24: sspm_1 (000FE000, 00000800) 1024 KB P25: sspm_2 (000FE800, 00000800) 1024 KB P26: gz1 (000FF000, 00008000) 16 MB P27: gz2 (00107000, 00008000) 16 MB P28: nvram (0010F000, 00020000) 64 MB P29: lk (0012F000, 00000800) 1024 KB P30: lk2 (0012F800, 00000800) 1024 KB P31: boot (00130000, 00010000) 32 MB P32: logo (00140000, 00008000) 16 MB P33: dtbo (00148000, 00008000) 16 MB P34: tee1 (00150000, 00002800) 5 MB P35: tee2 (00152800, 00005800) 11 MB P36: odm (00158000, 00010000) 32 MB P37: vendor (00168000, 00198000) 816 MB P38: system (00300000, 00734000) 3688 MB P39: cache (00A34000, 000A4000) 328 MB P40: userdata (00AD8000, 02F487DF) 23.64 GB P41: otp (03A207DF, 00015800) 43 MB P42: flashinfo (03A35FDF, 00008000) 16 MB Reset operation finished |
The Following User Says Thank You to solusi hp For This Useful Post: |
05-13-2020, 11:03 | #1058 (permalink) |
No Life Poster Join Date: Aug 2012 Location: under pross
Member: 1798174 Status: Offline Sonork: 100.114149 Thanks Meter: 1,048 | samsung j100H dead boot repaired with medusa pro Welcome to Medusa Pro Software version 2.0.9. Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: Generic EMV Smartcard Reader 0 Reader #3: Generic EMV Smartcard Reader 1 Please, power phone OFF (press and hold "Vol+" or "Vol-" button) and connect USB cable. Connecting... Can not find com port! Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J100H SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J100H_EMMC_H4G2B.srf Voltage : 2.2V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J100H SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J100H_EMMC_H4G2B.srf Voltage : 2.2V Bus Mode : 1 bit Bus speed : 20 MHz Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J100H SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J100H_EMMC_H4G2B.srf Voltage : 2.2V Bus Mode : 1 bit Bus speed : 20 MHz Connecting... Device : Hynix eMMC H4G2b Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A48344732621101CEC2C9FB52D5 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G2b Product revision : 0.1 Product serial number : (hex) CEC2C9FB Manufacturing date : 05/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A4040DB CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x1 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/H4G2b_13_05_2020_10_53_23.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.9; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: SBOOT (00002000, 00001000) 2048 KB P02: SBOOT2 (00003000, 00001000) 2048 KB P03: wfixnv1 (00004000, 00000800) 1024 KB P04: wfixnv2 (00004800, 00000800) 1024 KB P05: tdfixnv1 (00005000, 00000800) 1024 KB P06: tdfixnv2 (00005800, 00000800) 1024 KB P07: WDSP (00006000, 00002000) 4 MB P08: MODEM (00008000, 00004000) 8 MB P09: MODEM2 (0000C000, 00004000) 8 MB P10: TDDSP (00010000, 00002000) 4 MB P11: FOTA_SIG (00012000, 00000800) 1024 KB P12: wruntimenv1 (00012800, 00000800) 1024 KB P13: wruntimenv2 (00013000, 00000800) 1024 KB P14: tdruntimenv1 (00013800, 00000800) 1024 KB P15: tdruntimenv2 (00014000, 00000800) 1024 KB P16: PARAM (00014800, 00001000) 2048 KB P17: efs (00015800, 0000A000) 20 MB P18: prodnv (0001F800, 00002800) 5 MB P19: RESERVED2 (00022000, 00000800) 1024 KB P20: KERNEL (00022800, 00008000) 16 MB P21: RECOVERY (0002A800, 00008000) 16 MB P22: CSC (00032800, 00064000) 200 MB P23: system (00096800, 00208000) 1040 MB P24: HIDDEN (0029E800, 00014000) 40 MB P25: userdata (002B2800, 0048E000) 2332 MB Backuping efs partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/H4G2b_efs_0x15800_0xa000_13_05_2020_10_53_23.bin file... Reading. Please wait... Done. Elapsed time 00:00:11 SW: 2.0.9; FW: 1.24. Erasing partition GPT... Done. Erasing partition SBOOT... Done. Erasing partition SBOOT2... Done. Erasing partition wfixnv1... Done. Erasing partition wfixnv2... Done. Erasing partition tdfixnv1... Done. Erasing partition tdfixnv2... Done. Erasing partition WDSP... Done. Erasing partition MODEM... Done. Erasing partition MODEM2... Done. Erasing partition TDDSP... Done. Erasing partition FOTA_SIG... Done. Erasing partition wruntimenv1... Done. Erasing partition wruntimenv2... Done. Erasing partition tdruntimenv1... Done. Erasing partition tdruntimenv2... Done. Erasing partition PARAM... Done. Erasing partition efs... Done. Erasing partition prodnv... Done. Erasing partition RESERVED2... Done. Erasing partition KERNEL... Done. Erasing partition RECOVERY... Done. Erasing partition CSC... Done. Erasing partition system... Done. Erasing partition HIDDEN... Done. Erasing partition userdata... Done. Erasing is finished. SW: 2.0.9; FW: 1.24. Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J100H_EMMC_H4G2B.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to user area. Writing GPT partition... Done. Writing SBOOT partition... Done. Writing SBOOT2 partition... Done. Writing wfixnv1 partition... Done. Writing wfixnv2 partition... Done. Writing tdfixnv1 partition... Done. Writing tdfixnv2 partition... Done. Writing WDSP partition... Done. Writing MODEM partition... Done. Writing MODEM2 partition... Done. Writing TDDSP partition... Done. Writing wruntimenv1 partition... Done. Writing wruntimenv2 partition... Done. Writing tdruntimenv1 partition... Done. Writing tdruntimenv2 partition... Done. Writing PARAM partition... Done. Writing efs partition... Done. Smart Repair is successfully complete. SW: 2.0.9; FW: 1.24. Disconnected. |
The Following User Says Thank You to Pastime_GSM For This Useful Post: |
05-21-2020, 06:20 | #1059 (permalink) |
No Life Poster Join Date: Mar 2006 Location: PAKISTAN/MULTAN
Member: 242838 Status: Offline Thanks Meter: 83 | Huawei ALE-L21 DONE Welcome to Medusa Pro Software version 2.0.2. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Reader #2: FT SCR2000 1 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Huawei Model : ALE-L21 SRF : E:/JTAGS/MEDUSA PRO/HUAWEI_ALE-L21_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC HAG2e Page size : 512 B Block size : 512 B Block count : 30785536 Size : 14.68 GB (15032.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484147326505070AC6692D7357 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HAG2e Product revision : 0.7 Product serial number : (hex) AC6692D Manufacturing date : 07/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab800000 bytes Device sector size : 512 bytes Partition offset : 1826816 Number of sectors : 5242880 Device Manufacturer : hi6210sft Device Platform : hi6210sft Build ID : LRX21M Display Build ID : BalongC50B311 Release ID : 5.0.1 Device Model : hi6210sft Device Name : hi6210sft Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : hi6210sft-user 5.0 LRX21M eng.jenkins.20160525.160948 test-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/HAG2e_02_02_2020_16_35_03.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.2; FW: 1.24. P00: GPT (00000000, 00000400) 512 KB P01: vrl (00000400, 00000200) 256 KB P02: vrl_bkup (00000600, 00000200) 256 KB P03: mcuimage (00000800, 00000200) 256 KB P04: reserved0 (00000A00, 00000600) 768 KB P05: fastboot (00001000, 00002000) 4 MB P06: modemnvbkup (00003000, 00003000) 6 MB P07: nvme (00006000, 00002000) 4 MB P08: oeminfo (00008000, 00010000) 32 MB P09: splash (00018000, 00004000) 8 MB P10: modemnvm1 (0001C000, 00008000) 16 MB P11: modemnvm2 (00024000, 00008000) 16 MB P12: modemnvm3 (0002C000, 00008000) 16 MB P13: securetystorage (00034000, 00010000) 32 MB P14: 3rdmodemnvm (00044000, 00008000) 16 MB P15: 3rdmodemnvmback (0004C000, 00008000) 16 MB P16: reserved1 (00054000, 00006000) 12 MB P17: modemlog (0005A000, 00008000) 16 MB P18: splash2 (00062000, 00020000) 64 MB P19: misc (00082000, 00001000) 2048 KB P20: modemnvreserved (00083000, 0000C000) 24 MB P21: recovery2 (0008F000, 00020000) 64 MB P22: reserved2 (000AF000, 00010000) 32 MB P23: teeos (000BF000, 00002000) 4 MB P24: trustfirmware (000C1000, 00001000) 2048 KB P25: sensorhub (000C2000, 00008000) 16 MB P26: hifi (000CA000, 00006000) 12 MB P27: boot (000D0000, 0000C000) 24 MB P28: recovery (000DC000, 00020000) 64 MB P29: dtimage (000FC000, 00010000) 32 MB P30: modemimage (0010C000, 00020000) 64 MB P31: dsp (0012C000, 00004000) 8 MB P32: dfx (00130000, 00008000) 16 MB P33: 3rdmodem (00138000, 00002000) 4 MB P34: cache (0013A000, 00080000) 256 MB P35: hisitest0 (001BA000, 00001000) 2048 KB P36: hisitest1 (001BB000, 00001000) 2048 KB P37: hisitest2 (001BC000, 00002000) 4 MB P38: system (001BE000, 00500000) 2560 MB P39: cust (006BE000, 00100000) 512 MB P40: userdata (007BE000, 0159E000) 10.81 GB Changing CID to 90014A4841473265050742A3388E8287. Write CID succesfully completed. Disconnected. |
The Following User Says Thank You to crazygenius3 For This Useful Post: |
05-21-2020, 06:22 | #1060 (permalink) |
Member: 242838 Status: Offline Thanks Meter: 83 | Oppo a1k_cph1923 lock done Welcome to Medusa Pro Software version 2.0.9. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Reader #2: FT SCR2000 1 SRF "F:/All Files/JTAG/MEDUSA PRO/Oppo_A1K_CPH1923_RESET_ISP.srf" has been installed successfully. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : A1K_CPH1923 SRF : F:/All Files/JTAG/MEDUSA PRO/Oppo_A1K_CPH1923_RESET_ISP.srf Voltage : 2.2V Bus Mode : 1 bit Bus speed : 13 MHz Connecting... Device : Samsung eMMC QD63MB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100514436334D4203727990AB8693 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QD63MB Product revision : 0.3 Product serial number : (hex) 727990AB Manufacturing date : 08/2019 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 3817472 Number of sectors : 9830400 Build ID : PPR1.180610.011 Release ID : 9 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : full_oppo6762_18540-user 9 PPR1.180610.011 eng.root.20200319.175516 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QD63MB_03_05_2020_15_53_03.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.9; FW: 1.24. P00: GPT (00000000, 00000040) 32 KB P01: boot_para (00000040, 00000800) 1024 KB P02: recovery (00000840, 00010000) 32 MB P03: para (00010840, 00000400) 512 KB P04: opporeserve1 (00010C40, 00004000) 8 MB P05: opporeserve2 (00014C40, 00020000) 64 MB P06: opporeserve3 (00034C40, 00020000) 64 MB P07: oppo_custom (00054C40, 00000800) 1024 KB P08: expdb (00055440, 0000A000) 20 MB P09: frp (0005F440, 00000800) 1024 KB P10: vbmeta (0005FC40, 00004000) 8 MB P11: nvcfg (00063C40, 00010000) 32 MB P12: nvdata (00073C40, 00020000) 64 MB P13: metadata (00093C40, 00010000) 32 MB P14: protect1 (000A3C40, 00004000) 8 MB P15: protect2 (000A7C40, 000043C0) 8.469 MB P16: seccfg (000AC000, 00004000) 8 MB P17: persist (000B0000, 00018000) 48 MB P18: sec1 (000C8000, 00001000) 2048 KB P19: proinfo (000C9000, 00001800) 3072 KB P20: md1img (000CA800, 00032000) 100 MB P21: spmfw (000FC800, 00000800) 1024 KB P22: scp1 (000FD000, 00000800) 1024 KB P23: scp2 (000FD800, 00000800) 1024 KB P24: sspm_1 (000FE000, 00000800) 1024 KB P25: sspm_2 (000FE800, 00000800) 1024 KB P26: gz1 (000FF000, 00008000) 16 MB P27: gz2 (00107000, 00008000) 16 MB P28: nvram (0010F000, 00020000) 64 MB P29: lk (0012F000, 00000800) 1024 KB P30: lk2 (0012F800, 00000800) 1024 KB P31: boot (00130000, 00010000) 32 MB P32: logo (00140000, 00008000) 16 MB P33: dtbo (00148000, 00008000) 16 MB P34: tee1 (00150000, 00002800) 5 MB P35: tee2 (00152800, 00005800) 11 MB P36: odm (00158000, 00080000) 256 MB P37: vendor (001D8000, 001CC000) 920 MB P38: system (003A4000, 00960000) 4.688 GB P39: cache (00D04000, 000D8000) 432 MB P40: userdata (00DDC000, 02C447DF) 22.13 GB P41: otp (03A207DF, 00015800) 43 MB P42: flashinfo (03A35FDF, 00008000) 16 MB Backuping nvdata partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QD63MB_nvdata_0x73c40_0x20000_03_05_2020_15_53_03. bin file... Reading. Please wait... ERROR[011]: Read error. Attempting to read... ERROR[011]: Read error. Attempting to read... Backuping security partitions. Please wait... ERROR[011]: Read error. Attempting to read... Done. Elapsed time 00:01:29 SW: 2.0.9; FW: 1.24. Repairing from file "F:/All Files/JTAG/MEDUSA PRO/Oppo_A1K_CPH1923_RESET_ISP.srf". Write data verification is enabled. Writing para partition... Done. Writing frp partition... Done. Smart Repair is successfully complete. SW: 2.0.9; FW: 1.24. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : A1K_CPH1923 SRF : F:/All Files/JTAG/MEDUSA PRO/Oppo_A1K_CPH1923_RESET_ISP.srf Voltage : 2.2V Bus Mode : 1 bit Bus speed : 13 MHz Connecting... Device : Samsung eMMC QD63MB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100514436334D4203727990AB8693 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QD63MB Product revision : 0.3 Product serial number : (hex) 727990AB Manufacturing date : 08/2019 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 3817472 Number of sectors : 9830400 Build ID : PPR1.180610.011 Release ID : 9 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : full_oppo6762_18540-user 9 PPR1.180610.011 eng.root.20200319.175516 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QD63MB_03_05_2020_15_54_53.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.9; FW: 1.24. P00: GPT (00000000, 00000040) 32 KB P01: boot_para (00000040, 00000800) 1024 KB P02: recovery (00000840, 00010000) 32 MB P03: para (00010840, 00000400) 512 KB P04: opporeserve1 (00010C40, 00004000) 8 MB P05: opporeserve2 (00014C40, 00020000) 64 MB P06: opporeserve3 (00034C40, 00020000) 64 MB P07: oppo_custom (00054C40, 00000800) 1024 KB P08: expdb (00055440, 0000A000) 20 MB P09: frp (0005F440, 00000800) 1024 KB P10: vbmeta (0005FC40, 00004000) 8 MB P11: nvcfg (00063C40, 00010000) 32 MB P12: nvdata (00073C40, 00020000) 64 MB P13: metadata (00093C40, 00010000) 32 MB P14: protect1 (000A3C40, 00004000) 8 MB P15: protect2 (000A7C40, 000043C0) 8.469 MB P16: seccfg (000AC000, 00004000) 8 MB P17: persist (000B0000, 00018000) 48 MB P18: sec1 (000C8000, 00001000) 2048 KB P19: proinfo (000C9000, 00001800) 3072 KB P20: md1img (000CA800, 00032000) 100 MB P21: spmfw (000FC800, 00000800) 1024 KB P22: scp1 (000FD000, 00000800) 1024 KB P23: scp2 (000FD800, 00000800) 1024 KB P24: sspm_1 (000FE000, 00000800) 1024 KB P25: sspm_2 (000FE800, 00000800) 1024 KB P26: gz1 (000FF000, 00008000) 16 MB P27: gz2 (00107000, 00008000) 16 MB P28: nvram (0010F000, 00020000) 64 MB P29: lk (0012F000, 00000800) 1024 KB P30: lk2 (0012F800, 00000800) 1024 KB P31: boot (00130000, 00010000) 32 MB P32: logo (00140000, 00008000) 16 MB P33: dtbo (00148000, 00008000) 16 MB P34: tee1 (00150000, 00002800) 5 MB P35: tee2 (00152800, 00005800) 11 MB P36: odm (00158000, 00080000) 256 MB P37: vendor (001D8000, 001CC000) 920 MB P38: system (003A4000, 00960000) 4.688 GB P39: cache (00D04000, 000D8000) 432 MB P40: userdata (00DDC000, 02C447DF) 22.13 GB P41: otp (03A207DF, 00015800) 43 MB P42: flashinfo (03A35FDF, 00008000) 16 MB Backuping nvdata partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QD63MB_nvdata_0x73c40_0x20000_03_05_2020_15_54_53. bin file... Reading. Please wait... Done. Elapsed time 00:00:49 SW: 2.0.9; FW: 1.24. Disconnected. |
05-21-2020, 09:57 | #1061 (permalink) |
Member: 242838 Status: Offline Thanks Meter: 83 | Realme C2 RMX1941 Lock DONE Welcome to Medusa Pro Software version 2.0.9. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Alcor Micro USB Smart Card Reader 1 Reader #2: FT SCR2000 0 Reader #3: FT SCR2000 1 SRF "F:/All Files/JTAG/MEDUSA PRO/Realme_C2_RMX1941_RESET_ISP.srf" has been installed successfully. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Realme Model : C2_RMX1941 SRF : F:/All Files/JTAG/MEDUSA PRO/Realme_C2_RMX1941_RESET_ISP.srf Voltage : 2.2V Bus Mode : 1 bit Bus speed : 13 MHz Connecting... Device : Samsung eMMC QE63MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100514536334D4203E1149AC756DB Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE63MB Product revision : 0.3 Product serial number : (hex) E1149AC7 Manufacturing date : 05/2019 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : a3e00000 bytes Device sector size : 512 bytes Partition offset : 3145728 Number of sectors : 7553024 Build ID : PPR1.180610.011 Release ID : 9 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : full_oppo6762_18540-user 9 PPR1.180610.011 eng.root.20190617.165850 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QE63MB_21_05_2020_13_20_23.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.9; FW: 1.24. P00: GPT (00000000, 00000040) 32 KB P01: boot_para (00000040, 00000800) 1024 KB P02: recovery (00000840, 00010000) 32 MB P03: para (00010840, 00000400) 512 KB P04: opporeserve1 (00010C40, 00004000) 8 MB P05: opporeserve2 (00014C40, 00020000) 64 MB P06: opporeserve3 (00034C40, 00020000) 64 MB P07: oppo_custom (00054C40, 00000800) 1024 KB P08: expdb (00055440, 0000A000) 20 MB P09: frp (0005F440, 00000800) 1024 KB P10: vbmeta (0005FC40, 00004000) 8 MB P11: nvcfg (00063C40, 00010000) 32 MB P12: nvdata (00073C40, 00020000) 64 MB P13: metadata (00093C40, 00010000) 32 MB P14: protect1 (000A3C40, 00004000) 8 MB P15: protect2 (000A7C40, 000043C0) 8.469 MB P16: seccfg (000AC000, 00004000) 8 MB P17: persist (000B0000, 00018000) 48 MB P18: sec1 (000C8000, 00001000) 2048 KB P19: proinfo (000C9000, 00001800) 3072 KB P20: md1img (000CA800, 00032000) 100 MB P21: spmfw (000FC800, 00000800) 1024 KB P22: scp1 (000FD000, 00000800) 1024 KB P23: scp2 (000FD800, 00000800) 1024 KB P24: sspm_1 (000FE000, 00000800) 1024 KB P25: sspm_2 (000FE800, 00000800) 1024 KB P26: gz1 (000FF000, 00008000) 16 MB P27: gz2 (00107000, 00008000) 16 MB P28: nvram (0010F000, 00020000) 64 MB P29: lk (0012F000, 00000800) 1024 KB P30: lk2 (0012F800, 00000800) 1024 KB P31: boot (00130000, 00010000) 32 MB P32: logo (00140000, 00008000) 16 MB P33: dtbo (00148000, 00008000) 16 MB P34: tee1 (00150000, 00002800) 5 MB P35: tee2 (00152800, 00005800) 11 MB P36: odm (00158000, 00010000) 32 MB P37: vendor (00168000, 00198000) 816 MB P38: system (00300000, 00734000) 3688 MB P39: cache (00A34000, 000A4000) 328 MB P40: userdata (00AD8000, 012297DF) 9.081 GB P41: otp (01D017DF, 00015800) 43 MB P42: flashinfo (01D16FDF, 00008000) 16 MB Backuping nvdata partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QE63MB_nvdata_0x73c40_0x20000_21_05_2020_13_20_23. bin file... Reading. Please wait... Done. Elapsed time 00:00:49 SW: 2.0.9; FW: 1.24. Repairing from file "F:/All Files/JTAG/MEDUSA PRO/Realme_C2_RMX1941_RESET_ISP.srf". Write data verification is enabled. Writing para partition... Done. Writing frp partition... Done. Smart Repair is successfully complete. SW: 2.0.9; FW: 1.24. Disconnected. |
05-27-2020, 12:02 | #1062 (permalink) |
Member: 242838 Status: Offline Thanks Meter: 83 | OPPO A7 CPH1901 LOck DONE Welcome to Medusa Pro Software version 2.0.9. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Reader #2: FT SCR2000 1 SRF "F:/All Files/JTAG/MEDUSA PRO/OPPO_A7_CPH1901_RESET_ISP.srf" has been installed successfully. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : A7_CPH1901 SRF : F:/All Files/JTAG/MEDUSA PRO/OPPO_A7_CPH1901_RESET_ISP.srf Voltage : 2.2V Bus Mode : 1 bit Bus speed : 13 MHz Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : A7_CPH1901 SRF : F:/All Files/JTAG/MEDUSA PRO/OPPO_A7_CPH1901_RESET_ISP.srf Voltage : 2.2V Bus Mode : 1 bit Bus speed : 13 MHz Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : A7_CPH1901 SRF : F:/All Files/JTAG/MEDUSA PRO/OPPO_A7_CPH1901_RESET_ISP.srf Voltage : 2.2V Bus Mode : 1 bit Bus speed : 13 MHz Connecting... Device : Hynix eMMC HCG8a4 Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484347386134A54CE198769573 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HCG8a4 Product revision : 10.5 Product serial number : (hex) 4CE19876 Manufacturing date : 09/2018 --------------------------------------------------------------- CSD Info CSD : D02701328F5903FFFFFFFFEF8A400027 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30531584 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 8f800000 bytes Device sector size : 512 bytes Partition offset : 2048000 Number of sectors : 8323072 Build ID : OPM1.171019.026 Release ID : 8.1.0 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20200430.055753 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/HCG8a4_27_05_2020_15_59_18.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.9; FW: 1.24. P00: GPT (00000000, 00000028) 20 KB P01: oppodycnvbk (00000028, 00005000) 10 MB P02: oppostanvbk (00005028, 00005000) 10 MB P03: modemst1 (0000A028, 00000C00) 1536 KB P04: modemst2 (0000AC28, 00000C00) 1536 KB P05: persist (0000B828, 00010000) 32 MB P06: opporeserve1 (0001B828, 00004000) 8 MB P07: opporeserve2 (0001F828, 00020000) 64 MB P08: fsc (0003F828, 00000002) 1024 b P09: ssd (0003F830, 00000010) 8 KB P10: sbl1 (0003F840, 00000400) 512 KB P11: rpm (0003FC40, 00000400) 512 KB P12: tz (00040040, 00001000) 2048 KB P13: devcfg (00041040, 00000200) 256 KB P14: sbl1bak (00041240, 00000400) 512 KB P15: rpmbak (00041640, 00000400) 512 KB P16: tzbak (00041A40, 00001000) 2048 KB P17: devcfgbak (00042A40, 00000200) 256 KB P18: dsp (00042C40, 00008000) 16 MB P19: DDR (0004C000, 00000040) 32 KB P20: fsg (0004C040, 00000C00) 1536 KB P21: sec (0004CC40, 00000020) 16 KB P22: aboot (0004CC60, 00000800) 1024 KB P23: abootbak (0004D460, 00000800) 1024 KB P24: modem (0004DC60, 00040000) 128 MB P25: dtbo (0008DC60, 00004000) 8 MB P26: vbmeta (00091C60, 00000080) 64 KB P27: boot (00091CE0, 00020000) 64 MB P28: recovery (000B1CE0, 00020000) 64 MB P29: devinfo (000D1CE0, 00000800) 1024 KB P30: splash (000D4000, 00005800) 11 MB P31: LOGO (000D9800, 00010000) 32 MB P32: DRIVER (000E9800, 00010000) 32 MB P33: cache (000F9800, 00080000) 256 MB P34: misc (00179800, 00000800) 1024 KB P35: keystore (0017A000, 00000400) 512 KB P36: config (0017A400, 00000040) 32 KB P37: oem (0017A440, 00000800) 1024 KB P38: limits (0017C000, 00000040) 32 KB P39: mota (00180000, 00000400) 512 KB P40: dip (00180400, 00000800) 1024 KB P41: mdtp (00180C00, 00010000) 32 MB P42: syscfg (00190C00, 00000400) 512 KB P43: mcfg (00191000, 00002000) 4 MB P44: lksecapp (00194000, 00000100) 128 KB P45: cmnlib (00194100, 00000800) 1024 KB P46: cmnlib64 (00194900, 00000800) 1024 KB P47: keymaster (00195100, 00000800) 1024 KB P48: lksecappbak (00195900, 00000100) 128 KB P49: cmnlibbak (00195A00, 00000800) 1024 KB P50: cmnlib64bak (00196200, 00000800) 1024 KB P51: keymasterbak (00196A00, 00000800) 1024 KB P52: apdp (00198000, 00000200) 256 KB P53: msadp (00198200, 00000200) 256 KB P54: dpo (00198400, 00000010) 8 KB P55: logdump (00198410, 00020000) 64 MB P56: vm-kystore (001B8410, 00000800) 1024 KB P57: vm-data (001B8C10, 00005000) 10 MB P58: hyp (001C0000, 00004000) 8 MB P59: vm-system (001C4000, 00020000) 64 MB P60: vm-linux (001E4000, 00010000) 32 MB P61: system (001F4000, 007F0000) 4064 MB P62: vendor (009E4000, 0020FB00) 1055 MB P63: userdata (00BF4000, 06887FDF) 52.27 GB Repairing from file "F:/All Files/JTAG/MEDUSA PRO/OPPO_A7_CPH1901_RESET_ISP.srf". Write data verification is enabled. Writing misc partition... Done. Writing config partition... Done. Smart Repair is successfully complete. SW: 2.0.9; FW: 1.24. Disconnected. |
05-27-2020, 16:56 | #1063 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | OPPO A3S Pattern Remove Code: Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : 20 MHz Connecting... Device : Hynix eMMC HAG4a2 Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484147346132A5C75ABADE26B3 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HAG4a2 Product revision : 10.5 Product serial number : (hex) C75ABADE Manufacturing date : 02/2019 --------------------------------------------------------------- CSD Info CSD : D02701328F5903FFFFFFFFE78A400017 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 2179072 Number of sectors : 7030784 Build ID : OPM1.171019.026 Release ID : 8.1.0 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : S88051AA1-user 8.1.0 OPM1.171019.026 eng.root.20200229.175806 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/HAG4a2_27_05_2020_20_53_20.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.9; FW: 1.24. P00: GPT (00000000, 00000028) 20 KB P01: oppodycnvbk (00000028, 00005000) 10 MB P02: oppostanvbk (00005028, 00005000) 10 MB P03: modemst1 (0000A028, 00000C00) 1536 KB P04: modemst2 (0000AC28, 00000C00) 1536 KB P05: persist (0000B828, 00010000) 32 MB P06: opporeserve1 (0001B828, 00004000) 8 MB P07: opporeserve2 (0001F828, 00020000) 64 MB P08: fsc (0003F828, 00000002) 1024 b P09: ssd (0003F830, 00000010) 8 KB P10: sbl1 (0003F840, 00000400) 512 KB P11: rpm (0003FC40, 00000400) 512 KB P12: tz (00040040, 00001000) 2048 KB P13: devcfg (00041040, 00000200) 256 KB P14: sbl1bak (00041240, 00000400) 512 KB P15: rpmbak (00041640, 00000400) 512 KB P16: tzbak (00041A40, 00001000) 2048 KB P17: devcfgbak (00042A40, 00000200) 256 KB P18: dsp (00042C40, 00008000) 16 MB P19: DDR (0004C000, 00000040) 32 KB P20: fsg (0004C040, 00002000) 4 MB P21: sec (0004E040, 00000020) 16 KB P22: aboot (0004E060, 00000800) 1024 KB P23: abootbak (0004E860, 00000800) 1024 KB P24: modem (0004F060, 00040000) 128 MB P25: dtbo (0008F060, 00004000) 8 MB P26: vbmeta (00093060, 00000080) 64 KB P27: boot (000930E0, 00020000) 64 MB P28: recovery (000B30E0, 00020000) 64 MB P29: devinfo (000D30E0, 00000800) 1024 KB P30: splash (000D4000, 00005800) 11 MB P31: LOGO (000D9800, 00010000) 32 MB P32: DRIVER (000E9800, 00010000) 32 MB P33: cache (000F9800, 00080000) 256 MB P34: misc (00179800, 00000800) 1024 KB P35: keystore (0017A000, 00000400) 512 KB P36: config (0017A400, 00000040) 32 KB P37: log (0017A440, 00020000) 64 MB P38: oem (0019A440, 00000800) 1024 KB P39: limits (0019C000, 00000040) 32 KB P40: mota (001A0000, 00000400) 512 KB P41: dip (001A0400, 00000800) 1024 KB P42: mdtp (001A0C00, 00010000) 32 MB P43: syscfg (001B0C00, 00000400) 512 KB P44: mcfg (001B1000, 00002000) 4 MB P45: lksecapp (001B4000, 00000100) 128 KB P46: cmnlib (001B4100, 00000800) 1024 KB P47: cmnlib64 (001B4900, 00000800) 1024 KB P48: keymaster (001B5100, 00000800) 1024 KB P49: lksecappbak (001B5900, 00000100) 128 KB P50: cmnlibbak (001B5A00, 00000800) 1024 KB P51: cmnlib64bak (001B6200, 00000800) 1024 KB P52: keymasterbak (001B6A00, 00000800) 1024 KB P53: apdp (001B8000, 00000200) 256 KB P54: msadp (001B8200, 00000200) 256 KB P55: dpo (001B8400, 00000010) 8 KB P56: logdump (001B8410, 00020000) 64 MB P57: vm-kystore (001D8410, 00000800) 1024 KB P58: vm-data (001D8C10, 00005000) 10 MB P59: hyp (001E0000, 00004000) 8 MB P60: vm-system (001E4000, 00020000) 64 MB P61: vm-linux (00204000, 00010000) 32 MB P62: system (00214000, 006B4800) 3433 MB P63: vendor (008C8800, 0020FB00) 1055 MB P64: userdata (00ADC000, 0127DFDF) 9.246 GB Backuping modemst1 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/HAG4a2_modemst1_0xa028_0xc00_27_05_2020_20_53_20.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.0.9; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/HAG4a2_modemst2_0xac28_0xc00_27_05_2020_20_53_20.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.0.9; FW: 1.24. Backuping fsg partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/HAG4a2_fsg_0x4c040_0x2000_27_05_2020_20_53_20.bin file... Reading. Please wait... Done. Elapsed time 00:00:02 SW: 2.0.9; FW: 1.24. Reset operation finished Disconnected. |
The Following User Says Thank You to Tanha0321 For This Useful Post: |
06-05-2020, 14:51 | #1064 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Ukraine Age: 44
Member: 75408 Status: Offline Thanks Meter: 1,190 | Programming KMQN1000SM-B316 for Samsung SM-G360H successfully done using Medusa Pro II with BGA221 socket. First connect: Code: Welcome to Medusa Pro Software version 2.1.0. Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: Generic USB Smart Card Reader 0 Reader #3: USB CCID Smart Card Reader 0 Loading firmware. Please wait... Done. Selected eMMC interface. Selected BGA 221 socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QN1SMB Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 150100514E31534D42009C1CB61652AD Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QN1SMB Product revision : 0.0 Product serial number : (hex) 9C1CB616 Manufacturing date : 05/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/QN1SMB_05_06_2020_15_52_46.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.0; FW: 2.00. P00: GPT (00000000, 00002000) 4 MB P01: SBOOT (00002000, 00001000) 2048 KB P02: SBOOT2 (00003000, 00001000) 2048 KB P03: wfixnv1 (00004000, 00000800) 1024 KB P04: wfixnv2 (00004800, 00000800) 1024 KB P05: tdfixnv1 (00005000, 00000800) 1024 KB P06: tdfixnv2 (00005800, 00000800) 1024 KB P07: WDSP (00006000, 00002000) 4 MB P08: MODEM (00008000, 00004000) 8 MB P09: MODEM2 (0000C000, 00004000) 8 MB P10: TDDSP (00010000, 00002000) 4 MB P11: FOTA_SIG (00012000, 00000800) 1024 KB P12: wruntimenv1 (00012800, 00000800) 1024 KB P13: wruntimenv2 (00013000, 00000800) 1024 KB P14: tdruntimenv1 (00013800, 00000800) 1024 KB P15: tdruntimenv2 (00014000, 00000800) 1024 KB P16: PARAM (00014800, 00001000) 2048 KB P17: efs (00015800, 0000A000) 20 MB P18: prodnv (0001F800, 00002800) 5 MB P19: RESERVED2 (00022000, 00001000) 2048 KB P20: KERNEL (00023000, 00008000) 16 MB P21: RECOVERY (0002B000, 00008000) 16 MB P22: PERSISTENT (00033000, 00000800) 1024 KB P23: persdata (00033800, 00004800) 9 MB P24: CACHE (00038000, 00064000) 200 MB P25: SYSTEM (0009C000, 002EE000) 1500 MB P26: HIDDEN (0038A000, 0000F000) 30 MB P27: userdata (00399000, 00AF0000) 5.469 GB Backuping efs partition... Opening C:/Program Files/Medusa Pro Software/Backups/QN1SMB_efs_0x15800_0xa000_05_06_2020_15_52_46.bin file... Reading. Please wait... Done. Elapsed time 00:00:06 SW: 2.1.0; FW: 2.00. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 638976 Number of sectors : 3072000 Device Manufacturer : samsung Device Platform : sc8830 Build ID : LMY48B Display Build ID : LMY48B.G361HXXU0AQB1 Release ID : 5.1.1 Device Model : SM-G361H Device Name : coreprimeve3gxx Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : coreprimeve3gxx-user 5.1.1 LMY48B G361HXXU0AQB1 release-keys --------------------------------------------------------------- RPMB: Authentication Key not yet programmed. Code: Smart report info: Hash code: 8812A1C6B2964CB83FABF0B0E0F854B4D0168228716B7B30F39DDA49018B5E0F Super block size : 0x00800000 Bytes Super page size : 0x00008000 Bytes Optima write size : 0x00008000 Bytes Number of banks : 1 Bank0 init bad block : 6 Bank0 runtime bad block : 0 Bank0 remain reserved block : 22 Max erase count : 8468 Min erase count : 125 Avg erase count : 610 Read reclaim count : 0 Optimal trim size : 0x00001000 Bytes Max erase count (SCL) : 8468 Min erase count (SCL) : 8012 Avg erase count (SCL) : 8402 Max erase count (MLC) : 1669 Min erase count (MLC) : 125 Avg erase count (MLC) : 453 DEVICE_LIFE_TIME_EST_TYP_B : 20% - 30% device life time used DEVICE_LIFE_TIME_EST_TYP_A : 20% - 30% device life time used PRE_EOL_INFO : Normal SW: 2.1.0; FW: 2.00. Code: Factory Format will erase all eMMC data! Do you want to continue? Yes. Formating...Done. SW: 2.1.0; FW: 2.00. Disconnected. Code: Selected BGA 221 socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QN1SMB Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 150100514E31534D42009C1CB61652AD Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QN1SMB Product revision : 0.0 Product serial number : (hex) 9C1CB616 Manufacturing date : 05/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/QN1SMB_05_06_2020_15_55_25.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.0; FW: 2.00. --------------------------------------------------------------- Searching Android build info... Not found --------------------------------------------------------------- RPMB: Authentication Key not yet programmed. Code: Flash geometry successfully changed. Boot1, Boot2 size changed to 4 MB. RPMB size changed to 512 KB. Disconnected. Code: Writing EXT_CSD succesfully complete! Disconnected. Code: Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G360H_EMMC_QNW00M_BY_PIJUSH_DAS.SRF". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to boot area partition 2. Writing BOOT2 partition... Done. Switched to user area. Writing GPT partition... Done. Writing SBOOT partition... Done. Writing SBOOT2 partition... Done. Writing wfixnv1 partition... Done. Writing wfixnv2 partition... Done. Writing tdfixnv1 partition... Done. Writing tdfixnv2 partition... Done. Writing WDSP partition... Done. Writing MODEM partition... Done. Writing MODEM2 partition... Done. Writing TDDSP partition... Done. Writing FOTA_SIG partition... Done. Writing wruntimenv1 partition... Done. Writing wruntimenv2 partition... Done. Writing tdruntimenv1 partition... Done. Writing tdruntimenv2 partition... Done. Writing PARAM partition... Done. Writing efs partition... Done. Writing prodnv partition... Done. Writing RESERVED2 partition... Done. Writing KERNEL partition... Done. Writing RECOVERY partition... Done. Writing CSC partition... Done. Writing HIDDEN partition... Done. Smart Repair is successfully complete. SW: 2.1.0; FW: 2.00. Disconnected. Code: Selected pit file: C:/1/SM-G360H_1_20170119190913_9yyc3eoynn_fac/CORE33G.pit Open file "C:/1/SM-G360H_1_20170119190913_9yyc3eoynn_fac/CSC_OXE_G360HOXE0APF1_CL1063127_QB10148571_REV04_user_low_ship.tar.md5". Open file "C:/1/SM-G360H_1_20170119190913_9yyc3eoynn_fac/CP_G360HXXU0APF1_CL1063127_QB10148571_REV04_user_low_ship.tar.md5". Open file "C:/1/SM-G360H_1_20170119190913_9yyc3eoynn_fac/BL_G360HXXS0AQA1_CL1063127_QB12148384_REV04_user_low_ship.tar.md5". Open file "C:/1/SM-G360H_1_20170119190913_9yyc3eoynn_fac/AP_G360HXXS0AQA1_CL1063127_QB12148384_REV04_user_low_ship.tar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Switched to boot area partition 1. Writing partition BOOT... from 0 to 40 Done. Switched to user area. Writing partition SBOOT... from 2000 to C02 Done. Writing partition SBOOT2... from 3000 to C02 Done. Writing partition wfixnv2... from 4800 to 156 Done. Writing partition WDSP... from 6000 to F02 Done. Writing partition MODEM... from 8000 to 393A Done. Writing partition PARAM... from 14800 to 4D8 Done. Writing partition KERNEL... from 22800 to 2C5A Done. Writing partition RECOVERY... from 2A800 to 3672 Done. Writing partition CSC... from 32800 to 93E1 Done. Writing partition system... from 96800 to 1B0BF4 Done. Writing partition HIDDEN... from 2EE800 to 4639 Done. Writing is finished. SW: 2.1.0; FW: 2.00. Code: Selected BGA 221 socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QN1SMB Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 150100514E31534D42009C1CB61652AD Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QN1SMB Product revision : 0.0 Product serial number : (hex) 9C1CB616 Manufacturing date : 05/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/QN1SMB_05_06_2020_16_48_41.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.0; FW: 2.00. P00: GPT (00000000, 00002000) 4 MB P01: sboot (00002000, 00001000) 2048 KB P02: sboot2 (00003000, 00001000) 2048 KB P03: wfixnv1 (00004000, 00000800) 1024 KB P04: wfixnv2 (00004800, 00000800) 1024 KB P05: tdfixnv1 (00005000, 00000800) 1024 KB P06: tdfixnv2 (00005800, 00000800) 1024 KB P07: wdsp (00006000, 00002000) 4 MB P08: modem (00008000, 00004000) 8 MB P09: modem2 (0000C000, 00004000) 8 MB P10: tddsp (00010000, 00002000) 4 MB P11: fota_sig (00012000, 00000800) 1024 KB P12: wruntimenv1 (00012800, 00000800) 1024 KB P13: wruntimenv2 (00013000, 00000800) 1024 KB P14: tdruntimenv1 (00013800, 00000800) 1024 KB P15: tdruntimenv2 (00014000, 00000800) 1024 KB P16: param (00014800, 00001000) 2048 KB P17: efs (00015800, 0000A000) 20 MB P18: prodnv (0001F800, 00002800) 5 MB P19: reserved2 (00022000, 00000800) 1024 KB P20: kernel (00022800, 00008000) 16 MB P21: recovery (0002A800, 00008000) 16 MB P22: csc (00032800, 00064000) 200 MB P23: system (00096800, 00258000) 1200 MB P24: hidden (002EE800, 00040000) 128 MB P25: userdata (0032E800, 00B5F800) 5.687 GB Backuping efs partition... Opening C:/Program Files/Medusa Pro Software/Backups/QN1SMB_efs_0x15800_0xa000_05_06_2020_16_48_41.bin file... Reading. Please wait... Done. Elapsed time 00:00:06 SW: 2.1.0; FW: 2.00. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 616448 Number of sectors : 2457600 Device Manufacturer : samsung Device Platform : sc8830 Build ID : KTU84P Display Build ID : KTU84P.G360HXXS0AQA1 Release ID : 4.4.4 Device Model : SM-G360H Device Name : core33gxx Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Build Description : core33gxx-user 4.4.4 KTU84P G360HXXS0AQA1 release-keys --------------------------------------------------------------- RPMB: Authentication Key not yet programmed. |
The Following User Says Thank You to Dr_Wolodya For This Useful Post: |
06-18-2020, 13:20 | #1065 (permalink) |
Member: 75408 Status: Offline Thanks Meter: 1,190 | Unbrick Huawei Y625-U32 successfully done: Code: Welcome to Medusa Pro Software version 2.1.1. Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: Generic USB Smart Card Reader 0 Reader #3: Generic USB Smart Card Reader 1 Reader #4: USB CCID Smart Card Reader 0 Model Settings: Interface : USB Brand : Huawei Model : Y625-U32 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/HUAWEI_Y625-U32_USB_BY_REBAINOOR.srf Core : Qualcomm MSM8x10 Loader : QLoader_v1 Connecting... Sending loader...OK. Loader successfully initialized. Device : CoreID_008140E1 Core : Qualcomm MSM8x10 Page size : 512 B Block size : 512 B Block count : 7569408 Size : 3696.00 MB Connect successful. --------------------------------------------------------------- SW: 2.1.1; FW: . P00: GPT (00000000, 00000022) 17 KB P01: sbl1 (00000022, 00000400) 512 KB P02: sdi (00000422, 00000100) 128 KB P03: aboot (00000522, 00000400) 512 KB P04: rpm (00000922, 000003E8) 500 KB P05: tz (00000D0A, 000003E8) 500 KB P06: pad (000010F2, 00000800) 1024 KB P07: modemst1 (000018F2, 00000C00) 1536 KB P08: modemst2 (000024F2, 00000C00) 1536 KB P09: misc (000030F2, 00000800) 1024 KB P10: fsc (000038F2, 00000002) 1024 b P11: ssd (000038F4, 00000010) 8 KB P12: modem (00020000, 00020000) 64 MB P13: DDR (00040000, 00000040) 32 KB P14: boot (00040040, 00005000) 10 MB P15: system (00045040, 002BC000) 1400 MB P16: persist (00301040, 00010000) 32 MB P17: cache (00311040, 00032CCC) 101.6 MB P18: recovery (00343D0C, 00005000) 10 MB P19: logo (00348D0C, 00003000) 6 MB P20: fsg (0034BD0C, 00000C00) 1536 KB P21: userdata (0034C90C, 003FB6D3) 2039 MB Backuping modemst1 partition... Opening C:/Program Files/Medusa Pro Software/Backups/_modemst1_0x18f2_0xc00_18_06_2020_15_08_11.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.1; FW: . Backuping modemst2 partition... Opening C:/Program Files/Medusa Pro Software/Backups/_modemst2_0x24f2_0xc00_18_06_2020_15_08_11.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.1; FW: . Backuping fsg partition... Opening C:/Program Files/Medusa Pro Software/Backups/_fsg_0x34bd0c_0xc00_18_06_2020_15_08_11.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.1; FW: . --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : e7000000 bytes Device sector size : 512 bytes Partition offset : 282688 Number of sectors : 2867200 Device Manufacturer : HUAWEI Device Platform : msm8610 Build ID : HUAWEIY625-U32 Display Build ID : Y625-U32V100R001C479B107 Release ID : 4.4.2 Device Model : HUAWEI Y625-U32 Device Name : Y625-U32 Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Build Description : 8212-user 4.4.2 HUAWEIY625-U32 C479B107 ota-rel-keys,release-keys --------------------------------------------------------------- Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/HUAWEI_Y625-U32_USB_BY_REBAINOOR.srf". Write data verification is enabled. Writing GPT partition... Done. Writing sbl1 partition... Done. Writing sdi partition... Done. Writing aboot partition... Done. Writing rpm partition... Done. Writing tz partition... Done. Writing pad partition... Done. Writing modemst1 partition... Done. Writing modemst2 partition... Done. Writing misc partition... Done. Writing fsc partition... Done. Writing ssd partition... Done. Writing modem partition... Done. Writing DDR partition... Done. Writing boot partition... Done. Writing persist partition... Done. Writing recovery partition... Done. Writing logo partition... Done. Writing fsg partition... Done. Smart Repair is successfully complete. SW: 2.1.1; FW: . Disconnected. |
NHE_8 wont work with NHEK5689.dll v3 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-23-1999 15:48 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
