Old 10-16-2019, 15:53   #196 (permalink)
rimiaafif's Avatar
Member: 1326433
Sonork: yahoo
Thanks Meter: 23
easy jtag plus
Originally Posted by layder View Post
if ISP not work at this device - desolder eMMC and check it at socket
"CMD level is to low" - you see at log (may be chort-cuted to GND)
if something doesn’t work, you need to use other methods. ISP is a non-substantiated connection to the board. sometimes it doesn't work
lyf jio F120B tested pinout
http://postimg.cc/hJ2c5MMC
but my box not detected
http://postimg.cc/3WRCVRr9
only this messag (Can't init device, Reason: CMD Timeout Error )
tri to-HiPower mode is off/on
tri to all methods but not success
this handset 100% ok no problem,jast for test
tri to all set but
pls help sir
Old 10-16-2019, 19:50   #197 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
tri to all set but
pls help sir
you need use 1,8, like as PCB, and more faster FREQ (14-21Mhz) also try to use Hi-Power CLK
I wrote to you about this before
Old 10-20-2019, 16:42   #198 (permalink)
hm.faizan's Avatar
Member: 1082907
Sonork: 100.1606954
Thanks Meter: 342
any reseller in pakistan i want upgrade kit i already have z3x easy jtag v1
Old 11-08-2019, 12:12   #199 (permalink)
Member: 1042338
Thanks Meter: 8
emmc from huawei mate 20 lite
hi ALL
i have a emmc from huawei mate 20 lite and i need read thhe emmc chip, but the sw see like a dead emmc.
i tried with a different vendor but the answer is the same
eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019)
Microsoft Windows 7 (32 bit) build 7601 (6.1.7601.18015)
Looking for EasyJTAG box...
EasyJTAG API ver. 3307
EasyJTAG Box Serial = 42062D4361FF9492
Card Serial = AAAA220E
EasyJTAG Box Firmware = 2.44
Changelog:
30.06.2019 (ver 1.6.1.0)
Fix: Bugs that have been found through your crash report
Setting interface to EasyJtag2/E-Socket
Setting bus width to 4 Bit
Setting frequence to 14 MHz
Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD]
Can't init device. Reason: CMD Timeout Error
Canceled
Canceled
Canceled
Canceled
Old 11-12-2019, 00:58   #200 (permalink)
Member: 926043
Sonork: jjgg
Is there someone working in there?? I have writen thousands of emails and none of then have been answerd by you . i need to activate my Easy Jtag card sn: AA6F-2D17 that i bought on Aliexpress and is from GPG Industries China reseller,, at least answer this email
please
Old 11-12-2019, 10:20   #201 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
please
All questions of activation is responsibility if box sellers
If you seller is bad - change seller
when you buy a phone in a store, you do not write to the factory about the fact that the store sold you a damaged device or sold, for example, a fake
Old 11-12-2019, 12:57   #202 (permalink)
Member: 1898289
Thanks Meter: 39
Hi, I was decided to buy this tool, which seller or kit you recommend for take it? I saw different packages, like with MOORC E-MATE already included, or some sockets, I wish to have as full as possible for no troubles in short and go for any adaptor/socket etc.
Thanks in advance.
Old 11-12-2019, 20:05   #203 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
I recomended https://gsmserver.com/z3x-easy-jtag-...l-upgrade-set/ and native sockets (https://gsmserver.com/z3x-easy-jtag-...ocket-adapter/)
For BGA254 wait few time
The Following User Says Thank You to layder For This Useful Post:
Old 11-16-2019, 12:15   #204 (permalink)
Member: 1898289
Thanks Meter: 39
And then be possible to recover data from newer models like Samsung S9? For UFS is fully working now or not if data are crypted?
Enviado desde mi SM-G960F mediante Tapatalk
Old 11-16-2019, 16:51   #205 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
Google has a security requirement - data encryption is mandatory starting from android 7.0
Old 11-19-2019, 14:03   #206 (permalink)
Member: 1898289
Thanks Meter: 39
So for newer devices for data recovery not worth it? Just for boot repair?
Old 11-21-2019, 10:03   #207 (permalink)
Member: 1582098
Thanks Meter: 17
Hello is it possible to upgrade from normal Z3x to easyjtag plus i found easyjtag plus and sockets but without simcard , can i buy it and activate it with my current z3x box ?
Old 11-21-2019, 10:18   #208 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
http://forum.gsmhosting.com/vbb/f672...l#post13900991
Old 11-21-2019, 11:44   #209 (permalink)
Member: 1582098
Thanks Meter: 17
Hi this tells about easyjtag old users , i'm not an old easy jtag user but a new z3x box user
Old 11-21-2019, 15:08   #210 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
You need buy box with smartcard. We can't sale card without box
Page generated in 0.20657 seconds with 8 queries
