05-10-2014, 10:55 | #62 (permalink) |
Major Poster Join Date: Apr 2014 Location: Libya
Member: 2164581 Status: Offline Sonork: 100.1670571 Thanks Meter: 6 | Thankx Alot Bro im Soldering Again bCoz there were bundlx Of err0r s0me tym usb Some tym CMD But The Most common error that i sufferd was CMD according to seqrch they said, soldrring is not Good 80 Percent Comentx that i read was about soldering CMD Properly i have removed all wires now gonna sold again i hope thia tym it will w0rk Thankz alot once again Mobi bro Sent from my iPhone using Tapatalk |
06-02-2014, 02:30 | #65 (permalink) |
Freak Poster Join Date: Dec 2013
Member: 2077936 Status: Offline Thanks Meter: 21 | I am very interested in purchasing a Z3X box. Blang, you're picture shows how to connect to box but not the direct EMMC points on the board. If I purchase the Z3X box and support will I have access to these pinout pictures on your support files? Or are the support files just JTAG connections that don't go directly to the EMMC? |
06-08-2014, 13:49 | #66 (permalink) |
Freak Poster Join Date: May 2014
Member: 2194348 Status: Offline Thanks Meter: 52 | i have an i9100p stuck on samsung logo , after flash its completly dead , so i connect emmc chipset with my tool then write boot partition 1 and 2 but still no download mode , please i need some generale steps to work with emmc tool to get a good diagnostic for my device (hardware or software ...... ) |
06-22-2014, 08:36 | #67 (permalink) |
Freak Poster Join Date: Dec 2011 Location: Chittagong, Bangladesh
Member: 1706809 Status: Offline Thanks Meter: 63 | how to work with Easy-Jtag [QUOTE=blang;9593804]FAQ - DIRECT EMMC connect in pictures!! DONT ASK MORE! HERE SAMPLE OF CONNECTION TO PCB. ===============FAQ============================== Q - If i not have Adapter can i connect to EMMC direct on boart? A - YES. But need use 2 external power. ================================================== Q - Why i need use double voltage? A - VCC - power of NAND memory inside eMMC (can be 2.8 - 3.3V) VCCQ - power of internal emmc controller. (can be 1.8 - 2.8V) (need setup vccq in sw same with real voltage) ================================================== Q - Do i need connect anything else to phone PCB ? A - NO. NO NEED CONNECT BATTERY OR USB CABLE TO PCB. NEED ONLY 6 WIRES: GND, CLK, CMD, DAT0, VCC, VCCQ ================================================== Q - Can i repair EMMC CHIP (suddenly dead phones) A - NO. AT THIS moment you cant repair EMMC. But we work on solution for update internal emmc firmware. May be ... who know. ================================================== Q - Can i repair Suddenly dead phones. A - Yes. If something was erased in EMMC CHIP. ================================================== Q - Can i repair boot on phone with disable JTAG? A - Yes you can. (N7100,I9300 boot inside ROM2, after write ROM2 phones back to work) ================================================== Q - Can i repair dead phones I9082, i9105, S6810P with disabled JTAG, after touch ROM2. A -YES you can. Just need write ROM2 via EMMC direct connection. ================================================== Q - Where i can take EMMC DIRECT connection pinout on BOARD? A - Tested EMMC direct connect pinout we uploading to EMMC pinout under phone folder name on support. ================================================== Q - How can i find byself EMMC pinout. A - Yes you can most of emmc have same pinouts. Need desolder EMMC and find where go 5 pins. CMD,CLK, DAT0, VCC,VCCQ ================================================== Q - What phones supported by EMMC Tool. A - Supported any phones for READ/WRITE based on known EMMC. At this moment we support most of known EMMC. HERE list of EMMC based samsung: ================================================== sir I am sorry to ask you again on how to connect and how to work with easy jtag .I'm very eager to work with it but i have no knowledge about it on how to connect and work so it is very typical and complicated for me and many more ,even reading FAQ and following picture tutorial given by you so we need a video tutorial on different kind of mobile phones. thanks sir and sorry again for my newbie question, |
The Following User Says Thank You to shohidsd1 For This Useful Post: |
09-03-2014, 14:53 | #71 (permalink) |
Junior Member Join Date: Sep 2014
Member: 2250829 Status: Offline Thanks Meter: 2 | i have adaptar. i sold 6 ware.. connect usb but emmc card not detecting. Z3X EasyJtag Software ver. 1.5.6.0 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 0D00201ADBA517B7, ,FW Ver.: 01.50 CMD Pullup Level:1175 mV CMD Active Level:2402 mV Can't init EMMC, Reason: CMD Timeout Error =================================== Done. help sir......... |
10-02-2014, 13:57 | #72 (permalink) | |
Junior Member Join Date: Dec 2009
Member: 1191351 Status: Offline Sonork: 22 Thanks Meter: 1 | Quote:
Z3X EasyJtag Software ver. 1.6.1.1 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 0EFFF02156D6D079, ,FW Ver.: 01.50 CMD Pullup Level:1175 mV CMD Active Level:1536 mV Can't init EMMC, Reason: DATA Status Error =================================== Done. plez help meeeeeeeeeeee | |
10-21-2014, 12:45 | #73 (permalink) |
Insane Poster Join Date: Sep 2010 Location: mumbai Age: 39
Member: 1387849 Status: Offline Sonork: 100.1623264 Thanks Meter: 15 | hello guys i have a problem with galaxy grand i9082 phone is dead motherboard shorting any one help how to solve im waiting for solution Thank you Last edited by i_4_u89; 10-21-2014 at 12:46. Reason: mis typ |
11-30-2014, 19:09 | #74 (permalink) |
Junior Member Join Date: Mar 2009
Member: 988127 Status: Offline Thanks Meter: 0 | please helpme sir Z3X EasyJtag Software ver. 1.6.6.0 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 17FFE0166CEC3928, ,FW Ver.: 01.50 CMD Pullup Level:2062 mV CMD Active Level:2103 mV Can't init EMMC, Reason: CMD Timeout Error =================================== Done. |
01-02-2015, 12:58 | #75 (permalink) | |
Insane Poster Join Date: Apr 2014
Member: 2175541 Status: Offline Thanks Meter: 24 | Quote:
