08-10-2018, 05:03 | #407 (permalink) | |
Freak Poster Join Date: Jul 2011 Location: hyderabad, india
Member: 1623940 Status: Offline Thanks Meter: 22 | Quote:
Yes absolutely u correct,,, It's not about BL or Pit file issue Need to do re-program correct way.. Other wise u can't boot ur phone | |
08-13-2018, 10:51 | #408 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: algeria
Member: 206173 Status: Offline Thanks Meter: 169 | Quote:
08-25-2018, 10:35 | #410 (permalink) |
Freak Poster Join Date: Apr 2008 Location: gsmworld
Member: 757297 Status: Offline Thanks Meter: 36 | sm-g532f dead boot problam plz esy-jtag team solve this problam. last 5pice sm-g532f dead boot repair not done. all prosess showing done but phone not power on i try more then 5 BL+PIT but phone not power on. i also try with rom1 and 2 write but same. and also erase rom1 then confing cpu then write BL+PIT but not done. plz solve this problam . this problam face only with sm-g532f |
08-25-2018, 13:34 | #411 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
08-26-2018, 09:35 | #412 (permalink) |
Member: 757297 Status: Offline Thanks Meter: 36 | g532f dead boot not done Setting frequence to 21 Mhz CMD Pullup Level: 2021 mV CMD Active Level: 2279 mV EMMC Device Information : EMMC CID: 150100514E3136424200917AD0EF250E EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QN16BB , HEX: 514E31364242 , S/N: 917AD0EF , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QN16BB_917AD0EF_20180826_101035.extcsd EMMC Init completed. Opening file: GRANDPPLTE_CIS_SER.pit Pit: GRANDPPLTE_CIS_SER.pit Entry count: 34 The size of the last section has been updated BL_G532FXWU1AQB5_CL10802954_QB12732196_REV00_user_ low_ship_MULTI_CERT.tar.md5 The list of files in the firmware: preloader.img lk.bin param.bin trustzone.bin efuse.img AP_G532FXWU1AQB5_CL10802954_QB12732196_REV00_user_ low_ship_MULTI_CERT.tar.md5 The list of files in the firmware: boot.img recovery.img system.img secro.img userdata.img CP_G532FXXU1AQB3_CL9364647_QB12616083_REV00_user_l ow_ship_MULTI_CERT.tar.md5 The list of files in the firmware: md1rom.img md1dsp.img CSC_XFV_G532FXFV1AQC1_CL10802954_QB12882653_REV00_ user_low_ship_MULTI_CERT.tar.md5 The list of files in the firmware: grandpplte_cis_ser.pit cache.img hidden.img Setting frequence to 21 Mhz CMD Pullup Level: 2010 mV CMD Active Level: 2279 mV EMMC Device Information : EMMC CID: 150100514E3136424200917AD0EF250E EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QN16BB , HEX: 514E31364242 , S/N: 917AD0EF , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QN16BB_917AD0EF_20180826_101135.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 0001D1FFBE00 Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: preloader.img Unpacking file: lk.bin Unpacking file: secro.img Unpacking file: efuse.img Unpacking file: trustzone.bin Unpacking file: param.bin Unpacking file: recovery.img Unpacking file: boot.img Unpacking file: md1rom.img Unpacking file: md1dsp.img Unpacking file: system.img Unpacking file: cache.img Unpacking file: hidden.img Unpacking file: userdata.img Partition name: BOOTLOADER Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 344.86 KB/s Partition name: LK Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 471.17 KB/s Partition name: SECRO Filename: secro.img , Offset: 000001400000 , filesize: 135424 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 706.82 KB/s Partition name: EFUSE Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 58.24 KB/s Partition name: TEE1 Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 745.79 KB/s Partition name: PARAM Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 861.79 KB/s Partition name: RECOVERY Filename: recovery.img , Offset: 000005800000 , filesize: 11553040 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 857.47 KB/s Partition name: BOOT Filename: boot.img , Offset: 000006800000 , filesize: 9963792 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 851.08 KB/s Partition name: MD1IMG Filename: md1rom.img , Offset: 000007800000 , filesize: 10510848 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 867.24 KB/s Partition name: MD1DSP Filename: md1dsp.img , Offset: 000009800000 , filesize: 1417728 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 828.60 KB/s Partition name: SYSTEM Filename: system.img , Offset: 00000C000000 , filesize: 3040662224 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 3371 Done writing partition. Write speed: 845.53 KB/s Partition name: CACHE Filename: cache.img , Offset: 0000CC800000 , filesize: 37650816 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 22 Done writing partition. Write speed: 687.92 KB/s Partition name: HIDDEN Filename: hidden.img , Offset: 0000E5800000 , filesize: 52531472 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 15 Done writing partition. Write speed: 708.48 KB/s Partition name: USERDATA Filename: userdata.img , Offset: 0000E9400000 , filesize: 128176800 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 40 Done writing partition. Write speed: 719.97 KB/s Check BootConfig for the selected vendor All done time: [01:16:31:243] Setting frequence to 21 Mhz CMD Pullup Level: 2021 mV CMD Active Level: 2279 mV EMMC Device Information : EMMC CID: 150100514E3136424200917AD0EF250E EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QN16BB , HEX: 514E31364242 , S/N: 917AD0EF , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QN16BB_917AD0EF_20180826_113315.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: bota0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB) Partition: nvram, [000000800000 - 000001000000], size: 000000800000 (8.00 MB) Partition: lk, [000001000000 - 000001200000], size: 000000200000 (2.00 MB) Partition: bota1, [000001200000 - 000001400000], size: 000000200000 (2.00 MB) Partition: secro, [000001400000 - 000001B00000], size: 000000700000 (7.00 MB) Partition: seccfg, [000001B00000 - 000001B80000], size: 000000080000 (512. KB) Partition: efuse, [000001B80000 - 000001C00000], size: 000000080000 (512. KB) Partition: tee1, [000001C00000 - 000002200000], size: 000000600000 (6.00 MB) Partition: bota2, [000002200000 - 000002800000], size: 000000600000 (6.00 MB) Partition: efs, [000002800000 - 000003000000], size: 000000800000 (8.00 MB) Partition: nvdata, [000003000000 - 000005000000], size: 000002000000 (32.0 MB) Partition: param, [000005000000 - 000005800000], size: 000000800000 (8.00 MB) Partition: recovery, [000005800000 - 000006800000], size: 000001000000 (16.0 MB) Partition: boot, [000006800000 - 000007800000], size: 000001000000 (16.0 MB) Partition: md1img, [000007800000 - 000009800000], size: 000002000000 (32.0 MB) Partition: md1dsp, [000009800000 - 000009C00000], size: 000000400000 (4.00 MB) Partition: keystore, [000009C00000 - 00000A400000], size: 000000800000 (8.00 MB) Partition: omekeystore, [00000A400000 - 00000A780000], size: 000000380000 (3.50 MB) Partition: proinfo, [00000A780000 - 00000AA00000], size: 000000280000 (2.50 MB) Partition: para, [00000AA00000 - 00000AA80000], size: 000000080000 (512. KB) Partition: persistent, [00000AA80000 - 00000AB00000], size: 000000080000 (512. KB) Partition: steady, [00000AB00000 - 00000AC00000], size: 000000100000 (1.00 MB) Partition: protect1, [00000AC00000 - 00000B400000], size: 000000800000 (8.00 MB) Partition: protect2, [00000B400000 - 00000BC00000], size: 000000800000 (8.00 MB) Partition: reserve2, [00000BC00000 - 00000C000000], size: 000000400000 (4.00 MB) Partition: system, [00000C000000 - 0000CC800000], size: 0000C0800000 (3.01 GB) Partition: cache, [0000CC800000 - 0000E5800000], size: 000019000000 (400. MB) Partition: hidden, [0000E5800000 - 0000E9400000], size: 000003C00000 (60.0 MB) Partition: userdata, [0000E9400000 - 0001D1FFBE00], size: 0000E8BFBE00 (3.64 GB) GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Model = SM-G532F Phone platform = mt6737t CPU Abi = armeabi-v7a Mediatek platform = MT6737T Android release = 6.0.1 Firmware version = MMB29T.G532FXWU1AQB5 Firmware date = Tue Feb 28 13:24:33 KST 2017 |
08-26-2018, 10:13 | #413 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | Try this: 1) Go to Read by vendor Samsung - Read Partition from eMMC, select only -nvram -efs -nvdata -protect1 -protect2 2) Read Selected - Save backups to folder (need to backup sert, IMEI, etc) 3) Download G532F_dump_G532FXXU1AQG2.bin.zip from support (z3x shell), unpack it 3) Go to eMMC general - select Write all Roms at once, select Rom1 file from folder with unpacked files, Rom2, Rom 3 files are auto select, press "Write All ROM's" 4) After finish goto Write by vendor - Samsung, select pit file from nvram-efs-nvdata backup folder, Write nvram-efs-nvdata-protect (Restore original files) 5) Try to run phone or put it to download mode If not success, it may be hardware problem. |
The Following 2 Users Say Thank You to layder For This Useful Post: |
08-27-2018, 13:46 | #414 (permalink) | |
Member: 757297 Status: Offline Thanks Meter: 36 | g532f dead boot not done Quote:
Setting frequence to 21 Mhz CMD Pullup Level: 2021 mV CMD Active Level: 2279 mV EMMC Device Information : EMMC CID: 150100514E3136424200917AD0EF250E EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QN16BB , HEX: 514E31364242 , S/N: 917AD0EF , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QN16BB_917AD0EF_20180827_153719.extcsd EMMC Init completed. Operation: Write all eMMC Regions at once Writing BootConfig ... Reg: 179 Value: 0x48 Reg: 177 Value: 0x00 Reg: 162 Value: 0x01 Done Writing to: ROM2 , start: 0x000000000000 , size: 0x000000400000 Filename: EMMC_QN16BB_ROM2_000000000000_000000400000.bin eMMC switching to ROM2 Writing partition... Done writing partition. Write speed: 329.99 KB/s Writing to: ROM3 , start: 0x000000000000 , size: 0x000000400000 Filename: EMMC_QN16BB_ROM3_000000000000_000000400000.bin eMMC switching to ROM3 Writing partition... Done writing partition. Write speed: 329.63 KB/s Writing to: ROM1 , start: 0x000000000000 , size: 0x00000C000000 Filename: EMMC_QN16BB_ROM1_000000000000_00000C000000.bin eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 761.93 KB/s All done time: [00:04:45:175] Setting frequence to 21 Mhz CMD Pullup Level: 2021 mV CMD Active Level: 2279 mV EMMC Device Information : EMMC CID: 150100514E3136424200917AD0EF250E EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QN16BB , HEX: 514E31364242 , S/N: 917AD0EF , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QN16BB_917AD0EF_20180827_154225.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB) Partition: nvram, [000000800000 - 000001000000], size: 000000800000 (8.00 MB) Partition: lk, [000001000000 - 000001200000], size: 000000200000 (2.00 MB) Partition: BOTA1, [000001200000 - 000001400000], size: 000000200000 (2.00 MB) Partition: secro, [000001400000 - 000001B00000], size: 000000700000 (7.00 MB) Partition: seccfg, [000001B00000 - 000001B80000], size: 000000080000 (512. KB) Partition: efuse, [000001B80000 - 000001C00000], size: 000000080000 (512. KB) Partition: tee1, [000001C00000 - 000002200000], size: 000000600000 (6.00 MB) Partition: BOTA2, [000002200000 - 000002800000], size: 000000600000 (6.00 MB) Partition: EFS, [000002800000 - 000003000000], size: 000000800000 (8.00 MB) Partition: nvdata, [000003000000 - 000005000000], size: 000002000000 (32.0 MB) Partition: PARAM, [000005000000 - 000005800000], size: 000000800000 (8.00 MB) Partition: recovery, [000005800000 - 000006800000], size: 000001000000 (16.0 MB) Partition: boot, [000006800000 - 000007800000], size: 000001000000 (16.0 MB) Partition: md1img, [000007800000 - 000009800000], size: 000002000000 (32.0 MB) Partition: md1dsp, [000009800000 - 000009C00000], size: 000000400000 (4.00 MB) Partition: keystore, [000009C00000 - 00000A400000], size: 000000800000 (8.00 MB) Partition: omekeystore, [00000A400000 - 00000A780000], size: 000000380000 (3.50 MB) Partition: proinfo, [00000A780000 - 00000AA00000], size: 000000280000 (2.50 MB) Partition: para, [00000AA00000 - 00000AA80000], size: 000000080000 (512. KB) Partition: PERSISTENT, [00000AA80000 - 00000AB00000], size: 000000080000 (512. KB) Partition: STEADY, [00000AB00000 - 00000AC00000], size: 000000100000 (1.00 MB) Partition: protect1, [00000AC00000 - 00000B400000], size: 000000800000 (8.00 MB) Partition: protect2, [00000B400000 - 00000BC00000], size: 000000800000 (8.00 MB) Partition: RESERVE2, [00000BC00000 - 00000C000000], size: 000000400000 (4.00 MB) Partition: system, [00000C000000 - 0000CC800000], size: 0000C0800000 (3.01 GB) Partition: cache, [0000CC800000 - 0000E5800000], size: 000019000000 (400. MB) Partition: hidden, [0000E5800000 - 0000E9400000], size: 000003C00000 (60.0 MB) Partition: userdata, [0000E9400000 - 0001D1C00000], size: 0000E8800000 (3.63 GB) GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Model = SM-G532F Phone platform = mt6737t CPU Abi = armeabi-v7a Mediatek platform = MT6737T Android release = 6.0.1 Firmware version = MMB29T.G532FXWU1AQB5 Firmware date = Tue Feb 28 13:24:33 KST 2017 | |
08-27-2018, 15:56 | #415 (permalink) | |
Phone may be dead at flashing process becouse it have hardware problem. (lost connection between eMMC and CPU when flashing). If you have work phone you can solder eMMC from working phone to this and try to put repaired eMMC to work pcb to check hardware or software problem will you have. | |
08-31-2018, 10:21 | #416 (permalink) |
No Life Poster Join Date: Feb 2009 Location: inside apples a15
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 253 | g532g dead help logs eMMC CID : 150100514E3136424200AB31E42124D3 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 02/2017 Rev.0x0 eMMC NAME: QN16BB , S/N: 2872173601 eMMC NAME (HEX): 514E31364242 IC Name: Samsung , KMQN10006B-B318/8GB @BGA221 Can't init EMMC, Reason: DATA RCV Timeout Error Check Data Line! Done. im sure may data lines are correct im using the v2 box and software version 3.0.0.0 can i still repair this without changing emmc? |
08-31-2018, 15:56 | #417 (permalink) | |
The Following User Says Thank You to layder For This Useful Post: |
09-01-2018, 04:34 | #418 (permalink) |
Freak Poster Join Date: Sep 2015
Member: 2463805 Status: Offline Thanks Meter: 32 | SM-G532G dead tried many BL got a SM G532G dead device by flashed wrong firmware. I tried write by vendor with many BL versions BL_G532GDXU1AQA4 BL_G532GDXU1APJ7 BL_G532GDDU1APK9 but the phone doesn't boot up. show's this error"Check BOOT_PARTITION_EN for the selected vendor" then I did format the EMMC and Write the DUMP unfortunately the support dump doesn't has the boot2.now i need the dump to repair the boot. can any one please upload dum with boot 1,2 and rom1. here the logs Detect Code: Setting frequence to 21 Mhz CMD Pullup Level: 1629 mV CMD Active Level: 1753 mV EMMC Device Information : EMMC CID: 90014A4838473475920104D674741530 EMMC CSD: D02701320F5903FFFFFFFFE78A40002A EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 04D67474 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 1/2018 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4u_04D67474_20180901_074554.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: bota0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB) Partition: nvram, [000000800000 - 000001000000], size: 000000800000 (8.00 MB) Partition: lk, [000001000000 - 000001200000], size: 000000200000 (2.00 MB) Partition: bota1, [000001200000 - 000001400000], size: 000000200000 (2.00 MB) Partition: secro, [000001400000 - 000001B00000], size: 000000700000 (7.00 MB) Partition: seccfg, [000001B00000 - 000001B80000], size: 000000080000 (512. KB) Partition: efuse, [000001B80000 - 000001C00000], size: 000000080000 (512. KB) Partition: tee1, [000001C00000 - 000002200000], size: 000000600000 (6.00 MB) Partition: bota2, [000002200000 - 000002800000], size: 000000600000 (6.00 MB) Partition: efs, [000002800000 - 000003000000], size: 000000800000 (8.00 MB) Partition: nvdata, [000003000000 - 000005000000], size: 000002000000 (32.0 MB) Partition: param, [000005000000 - 000005800000], size: 000000800000 (8.00 MB) Partition: recovery, [000005800000 - 000006800000], size: 000001000000 (16.0 MB) Partition: boot, [000006800000 - 000007800000], size: 000001000000 (16.0 MB) Partition: md1img, [000007800000 - 000009800000], size: 000002000000 (32.0 MB) Partition: md1dsp, [000009800000 - 000009C00000], size: 000000400000 (4.00 MB) Partition: keystore, [000009C00000 - 00000A400000], size: 000000800000 (8.00 MB) Partition: omekeystore, [00000A400000 - 00000A780000], size: 000000380000 (3.50 MB) Partition: proinfo, [00000A780000 - 00000AA00000], size: 000000280000 (2.50 MB) Partition: para, [00000AA00000 - 00000AA80000], size: 000000080000 (512. KB) Partition: persistent, [00000AA80000 - 00000AB00000], size: 000000080000 (512. KB) Partition: steady, [00000AB00000 - 00000AC00000], size: 000000100000 (1.00 MB) Partition: protect1, [00000AC00000 - 00000B400000], size: 000000800000 (8.00 MB) Partition: protect2, [00000B400000 - 00000BC00000], size: 000000800000 (8.00 MB) Partition: reserve2, [00000BC00000 - 00000C000000], size: 000000400000 (4.00 MB) Partition: system, [00000C000000 - 0000CC800000], size: 0000C0800000 (3.01 GB) Partition: cache, [0000CC800000 - 0000E5800000], size: 000019000000 (400. MB) Partition: hidden, [0000E5800000 - 0000E9400000], size: 000003C00000 (60.0 MB) Partition: userdata, [0000E9400000 - 0001D1FFBE00], size: 0000E8BFBE00 (3.64 GB) GPT header successfully parsed Get firmware version Firmware info not found write BL Code: Setting frequence to 21 Mhz CMD Pullup Level: 1629 mV CMD Active Level: 1773 mV EMMC Device Information : EMMC CID: 90014A4838473475920104D674741530 EMMC CSD: D02701320F5903FFFFFFFFE78A40002A EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 04D67474 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 1/2018 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4u_04D67474_20180901_081254.extcsd EMMC Init completed. Opening file: GRANDPPLTE_CIS_SER.pit Pit: GRANDPPLTE_CIS_SER.pit Entry count: 34 The size of the last section has been updated BL_G532GDXU1APJ7_CL9387420_QB11347255_REV00_user_low_ship_MULTI_CERT.tar.md5 The list of files in the firmware: preloader.img lk.bin param.bin trustzone.bin efuse.img Setting frequence to 21 Mhz CMD Pullup Level: 1619 mV CMD Active Level: 1763 mV EMMC Device Information : EMMC CID: 90014A4838473475920104D674741530 EMMC CSD: D02701320F5903FFFFFFFFE78A40002A EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 04D67474 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 1/2018 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4u_04D67474_20180901_081319.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 0001D1FFBE00 Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: preloader.img Unpacking file: lk.bin Unpacking file: efuse.img Unpacking file: trustzone.bin Unpacking file: param.bin Partition name: BOOTLOADER Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 335.41 KB/s Partition name: LK Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 494.44 KB/s Partition name: EFUSE Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 44.37 KB/s Partition name: TEE1 Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 859.50 KB/s Partition name: PARAM Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 876.87 KB/s Partition CACHE : formatting as EXT4. Please wait ... Formatting completed Partition HIDDEN : formatting as EXT4. Please wait ... Formatting completed Partition USERDATA : formatting as EXT4. Please wait ... Error writing at address: 0000E96E4000 ... Retry #1 Formatting completed Check BOOT_PARTITION_EN for the selected vendor All done time: [00:01:17:775 |
09-01-2018, 07:42 | #419 (permalink) |
No Life Poster Join Date: Dec 2012 Location: india mumbai
Member: 1847344 Status: Offline Thanks Meter: 300 | easy jtag bugs 1.5.1 so use 1.52 all ok because not write bootloder file only write reloder |
The Following User Says Thank You to shamsulhaq For This Useful Post: |
09-01-2018, 12:23 | #420 (permalink) | |
Member: 2463805 Status: Offline Thanks Meter: 32 | Quote:
That has boot 1 and rom1. So I need to write the boot 2 , without boot 2 it doesn't boot up right ? | |
The Following User Says Thank You to pirunthan7 For This Useful Post: |
