02-25-2015, 15:54 | #124 (permalink) |
Freak Poster Join Date: Nov 2013 Location: Venezuela-Falcon
Member: 2074524 Status: Offline Sonork: 100.1627435 Thanks Meter: 135 | Z3X EasyJtag Software ver. 1.7.0.1 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 07FFB005A703FA68, ,FW Ver.: 01.51 CMD Pullup Level:1227 mV CMD Active Level:1629 mV eMMC Device Information EMMC CID : 15010056545530304DF18D2613C57F0A EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 07/2012 Rev.0xf1 EMMC NAME: VTU00M , S/N: 2368082885 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_2368082885_20150103_1013.extcsd Done. Running:SAMSUNG: MoviNAND Factory Reset... Skip loading eMMC Addon Firmware CMD Pullup Level:1227 mV CMD Active Level:1629 mV Sending Smart Wipe Request... Wiping Card... Please do not touch it!!! Done. Please don't forget to repair extCSD from backup!!! Running:SAMSUNG: MoviNAND Reset + Format... Z3X EasyJtag Software ver. 1.7.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1227 mV CMD Active Level:1629 mV EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Sending Internal Reconfiguration Request... Waiting configuration Apply!!! Restoring configuration... EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Wiping Card... Please do not touch it!!! Done. Please don't forget to repair extCSD from backup!!! extCSD file...C:\Archivos de programa\Z3X\EASYJTAG\Backups\VTU00M_2368082885_20 150103_1013.extcsd Running:Repair extCSD... Z3X EasyJtag Software ver. 1.7.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1227 mV CMD Active Level:1629 mV Writing... Done! Done. Please don't forget to repair extCSD from backup!!! You must select flash file first! Checking NAND Image : E:\Celulares\Box & Dongles\Easy Jtag\Repairs\Samsung\I9300\EMMC_ROM2_00000000_0020 0000.bin File successefuly loaded! Processing file...E:\Celulares\Box & Dongles\Easy Jtag\Repairs\Samsung\I9300\EMMC_ROM2_00000000_0020 0000.bin Z3X EasyJtag Software ver. 1.7.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1227 mV CMD Active Level:1629 mV Input file : E:\Celulares\Box & Dongles\Easy Jtag\Repairs\Samsung\I9300\EMMC_ROM2_00000000_0020 0000.bin Writing 0000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Done. Write Speed: 843 kB/s Checking NAND Image : E:\Celulares\Box & Dongles\Easy Jtag\Repairs\Samsung\I9300\EMMC_ROM1_00000000_2000 0000.bin File successefuly loaded! Processing file...E:\Celulares\Box & Dongles\Easy Jtag\Repairs\Samsung\I9300\EMMC_ROM1_00000000_2000 0000.bin Z3X EasyJtag Software ver. 1.7.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1227 mV CMD Active Level:1629 mV Input file : E:\Celulares\Box & Dongles\Easy Jtag\Repairs\Samsung\I9300\EMMC_ROM1_00000000_2000 0000.bin Writing 0020000000 bytes to 00000000 ...ROM1 (USER ROM) Done. Write Speed: 2592 kB/s |
02-25-2015, 18:15 | #125 (permalink) |
Member: 2074524 Status: Offline Sonork: 100.1627435 Thanks Meter: 135 | Thanks Z3x team and I managed to revive several dead my question is ?? what is the best software to version or repaired after flash emmc? since I have flashed with pit included and comprise! .. but giving me some errors in closed process etc what is the best software version or use ?? and after using Jtag Easy Z3x??? |
03-24-2015, 18:19 | #126 (permalink) |
No Life Poster Join Date: Jul 2008 Location: ::::...I LOVE PAKISTAN...::::
Member: 823250 Status: Offline Sonork: 100.1587800 Thanks Meter: 187 | THANX JAVED BROTHER...I HAVE DONE IT BUT IT NOT GONA FLASH WITH ANY TOOL AND ODIN..... Code: EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/2012 Rev.0xF1 EMMC NAME: VTU00M , S/N: 3351519891 EMMC NAME (HEX): 56545530304D00 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_3351519891_20150202_1644.extcsd Done. Running:SAMSUNG: MoviNAND Factory Reset... Skip loading eMMC Addon Firmware CMD Pullup Level:732 mV CMD Active Level:1598 mV Sending Smart Wipe Request... Wiping Card... Please do not touch it! Please don't forget to repair extCSD from backup! Done. Running:SAMSUNG: MoviNAND Reset + Format... Z3X EasyJtag Software ver. 1.8.1.1 Skip loading eMMC Addon Firmware CMD Pullup Level:732 mV CMD Active Level:1598 mV EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Sending Internal Reconfiguration Request... Waiting configuration Apply! Restoring configuration... EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Wiping Card... Please do not touch it! Please don't forget to repair extCSD from backup! Done. extCSD file...C:\Users\AK'\Desktop\New folder\EMMC_00000000_00020000.bin You must select a valid extCSD file first! extCSD file...C:\Program Files\Z3X\EASYJTAG\Backups\VTU00M_3351519891_20150202_1644.extcsd Running:Repair extCSD... Z3X EasyJtag Software ver. 1.8.1.1 Skip loading eMMC Addon Firmware CMD Pullup Level:732 mV CMD Active Level:1598 mV Writing... Done. You must select flash file first! Checking NAND Image : C:\Users\AK'\Desktop\New folder\EMMC_ROM2_00000000_00200000.bin File successefuly loaded! Processing file...C:\Users\AK'\Desktop\New folder\EMMC_ROM2_00000000_00200000.bin Z3X EasyJtag Software ver. 1.8.1.1 Skip loading eMMC Addon Firmware USB Open Failed, Reason: PORT Open Error Done. Processing file...C:\Users\AK'\Desktop\New folder\EMMC_ROM2_00000000_00200000.bin Z3X EasyJtag Software ver. 1.8.1.1 Skip loading eMMC Addon Firmware CMD Pullup Level:732 mV CMD Active Level:1598 mV Input file : C:\Users\AK'\Desktop\New folder\EMMC_ROM2_00000000_00200000.bin Writing 0000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Done. Write Speed: 855 kB/s Checking NAND Image : C:\Users\AK'\Desktop\New folder\EMMC_ROM1_00000000_20000000.bin File successefuly loaded! Processing file...C:\Users\AK'\Desktop\New folder\EMMC_ROM1_00000000_20000000.bin Z3X EasyJtag Software ver. 1.8.1.1 Skip loading eMMC Addon Firmware USB Open Failed, Reason: PORT Open Error Done. Processing file...C:\Users\AK'\Desktop\New folder\EMMC_ROM1_00000000_20000000.bin Z3X EasyJtag Software ver. 1.8.1.1 Skip loading eMMC Addon Firmware USB Open Failed, Reason: PORT Open Error Done. Processing file...C:\Users\AK'\Desktop\New folder\EMMC_ROM1_00000000_20000000.bin Z3X EasyJtag Software ver. 1.8.1.1 Skip loading eMMC Addon Firmware CMD Pullup Level:732 mV CMD Active Level:1598 mV Input file : C:\Users\AK'\Desktop\New folder\EMMC_ROM1_00000000_20000000.bin Writing 0020000000 bytes to 00000000 ...ROM1 (USER ROM) Done. Write Speed: 2614 kB/s |
04-04-2015, 10:10 | #127 (permalink) |
Insane Poster Join Date: Mar 2015 Location: pakistan
Member: 2369915 Status: Offline Sonork: 100.1655031 Thanks Meter: 8 | HI i have i9505 when i conent with computer he take all driver butt when i connect download mood he never take any driver or not connect with computer plzz help what can i do ????? |
04-04-2015, 11:28 | #128 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | You are totally Of Topic, here is for Exsinos I9300 you are talking about a Qualcomm phone I9505...please use search button and not post anywhere.... BR allumts |
05-11-2015, 12:54 | #129 (permalink) | |||
No Life Poster Join Date: Oct 2006 Age: 45
Member: 369678 Status: Offline Thanks Meter: 192 | my phone condition now, can enter download mode whithout product name, try to connect with emmc connection 1.8v Quote:
The Following User Says Thank You to dharyadi For This Useful Post: |
