Old 12-11-2014, 18:49   #1 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 186,558
SD Card Unbrick Solution by Easy-JTAG Manual
EasyJTAG Magic SD Card Tool Operation Manual
Here are the instruction on creating recovery sd-card and boot sd-card to recover bricked Samsung Phones in case your phone got broken.*Before doing this, if your device are detected by usb as Qualcomm HS-USB QDLoader 9008 ( If you device are EXYNOS MCU Based it not need to be detected by USB at all)
Creating MAGIC CARD from ZBIN Image.
1. Download both PIT and ZBIN files for yor phone from support area.
2. Insert clean formatted SD Card in USB SD Card Reader
3. Run EasyJTAG Software and select SD Image Plugin
4. Select ZBIN file for creating recovery card by clicking button
5. Select yur SD card in drives list. And click button.
6. After few seconds magic SD card will be done. Close plugin and remove it from reader
Recovery Phone by SD Unbrick card
1. Insert SD Card in phone SD card slot and attach battery
2. Put phone in Download mode by USB-JIC either by keyboard combination ( make sure that you have used file with newer firmware than current phone firmware. If you don't know what firmware have ben in phone before software damage – just use latest zbin file from support!)
3. If phone go in ODIN mode, download firmware with same version as in ZBIN file e.g if you used
4. Samsung_GT-I9200_I9200XXUDNE4_GPT_UEFI.zbin you should use I9200XXUDNE4 firmware or newer one.
5. Flash phone with ODIN with PIT file!
6. Repair Done;
Creating MAGIC CARD from BIN Dump
If your phone have more actual firmware version than ZBIN file on support or you have unsupported phone – you can make ZBIN file by yourself from BINary dump ( eMMC Direct Dump or ADB Full Dump)
1. Run EasyJTAG Software and select SD Image Plugin
2. Select (128mbt DUMP)BIN* file for creating recovery card by clicking button
3. Click [Convert From BIN] button
4. After operation complete you will get ZBIN and PIT file in source folder.
• Different Platforms requires different ROM parts for Magic SD
The Following 68 Users Say Thank You to blang For This Useful Post:
Old 12-11-2014, 20:05   #2 (permalink)
DUNIYA JAMAL's Avatar
Member: 192810
Sonork: Some people NEED change
Thanks Meter: 860
Sir,
Very good user manual but better you give video manual.
Best Regards
The Following 5 Users Say Thank You to DUNIYA JAMAL For This Useful Post:
Old 12-11-2014, 20:13   #3 (permalink)
yuvraj9x2's Avatar
Member: 2213928
Thanks Meter: 440
but better you give video manual for full process
The Following 7 Users Say Thank You to yuvraj9x2 For This Useful Post:
Old 12-11-2014, 22:27   #4 (permalink)
umargee's Avatar
Member: 1075413
Sonork: 100.1656923
Thanks Meter: 149
(128mbt DUMP)BIN* file for need
working phone ??
The Following 4 Users Say Thank You to umargee For This Useful Post:
Old 12-11-2014, 22:28   #5 (permalink)
HaSHaM3001's Avatar
Member: 2065652
Thanks Meter: 60
Question
Do I need Use TWEEZER TO SHORT of some dead bodies
The Following 3 Users Say Thank You to HaSHaM3001 For This Useful Post:
Old 12-11-2014, 22:44   #6 (permalink)
Member: 334901
Thanks Meter: 28
thnx it good step, i like easy jtag
The Following 3 Users Say Thank You to iory For This Useful Post:
Old 12-12-2014, 00:19   #7 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Originally Posted by HaSHaM3001 View Post
Question
yes. need. soon will be added TP pictures in phone folders.
The Following 10 Users Say Thank You to blang For This Useful Post:
Old 12-12-2014, 06:57   #8 (permalink)
Member: 1637281
Sonork: 100.1657188
Thanks Meter: 95
Excellent ....feedback, tips..... results..... anyone.?
Problem is, some phones do not boot with the sd card method, unless your doing a tweak. I had a phone that I could only odin with the card in and when I pulled the card, It wouldnt work so I had to stop being lazy and do the jtag chain and presto, no need for sd after the real jtag thing. Now we need a image sharing thread with phones labeled correctly when we post them...
The Following 2 Users Say Thank You to concepttheman For This Useful Post:
Old 12-12-2014, 07:10   #9 (permalink)
.:MobileLife:.'s Avatar
Member: 188260
Sonork: 100.1590438
Thanks Meter: 428
Originally Posted by DUNIYA JAMAL View Post
Sir,
Best Regards
Bro steps are very easy. I think no need video easy then solder wires.
BR.
Siddeque.
The Following 2 Users Say Thank You to .:MobileLife:. For This Useful Post:
Old 12-12-2014, 07:26   #10 (permalink)
Member: 930245
Thanks Meter: 22
nice update.... good work from teamm...
The Following 3 Users Say Thank You to kalitirto For This Useful Post:
Old 12-12-2014, 08:33   #11 (permalink)
Member: 188260
Sonork: 100.1590438
Thanks Meter: 428
EasyJTAG Magic SD Card Tool Operation Picture Manual for new bees.
Step 1 Run Plugin
Step 2 Browse zbin file
Step 3 Select SD cared reader
Step 4 Write SD cared
Magic Cared is ready for boot repair now do these steps.
6. Repair Done.
Do step 1 and 2 same as above.
Step 3 and 4.
BR.
Siddeque.
The Following 19 Users Say Thank You to .:MobileLife:. For This Useful Post:
Old 12-12-2014, 08:35   #12 (permalink)
Member: 188260
Sonork: 100.1590438
Thanks Meter: 428
This could help for you bro.
http://forum.gsmhosting.com/vbb/f672.../#post10732554
BR.
Siddeque.
The Following 6 Users Say Thank You to .:MobileLife:. For This Useful Post:
Old 12-12-2014, 09:49   #13 (permalink)
Member: 276432
Thanks Meter: 65
Phone with product name unkown can fix boss
The Following 3 Users Say Thank You to dvdaio For This Useful Post:
Old 12-12-2014, 09:55   #14 (permalink)
Member: 276432
Thanks Meter: 65
Product name empty can we fix it
Old 12-12-2014, 11:12   #15 (permalink)
Member: 188260
Sonork: 100.1590438
Thanks Meter: 428
If hardware would be not fix means if have emmc damage can't be fix any box need to change emmc and most of problem no product name emmc fault.
t
Page generated in 0.27396 seconds with 8 queries
