12-11-2014, 18:49 | #1 (permalink) |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | SD Card Unbrick Solution by Easy-JTAG Manual Here are the instruction on creating recovery sd-card and boot sd-card to recover bricked Samsung Phones in case your phone got broken.*Before doing this, if your device are detected by usb as Qualcomm HS-USB QDLoader 9008 ( If you device are EXYNOS MCU Based it not need to be detected by USB at all) Creating MAGIC CARD from ZBIN Image. 1. Download both PIT and ZBIN files for yor phone from support area. 2. Insert clean formatted SD Card in USB SD Card Reader 3. Run EasyJTAG Software and select SD Image Plugin 4. Select ZBIN file for creating recovery card by clicking button 5. Select yur SD card in drives list. And click button. 6. After few seconds magic SD card will be done. Close plugin and remove it from reader Recovery Phone by SD Unbrick card 1. Insert SD Card in phone SD card slot and attach battery 2. Put phone in Download mode by USB-JIC either by keyboard combination ( make sure that you have used file with newer firmware than current phone firmware. If you don't know what firmware have ben in phone before software damage – just use latest zbin file from support!) 3. If phone go in ODIN mode, download firmware with same version as in ZBIN file e.g if you used 4. Samsung_GT-I9200_I9200XXUDNE4_GPT_UEFI.zbin you should use I9200XXUDNE4 firmware or newer one. 5. Flash phone with ODIN with PIT file! 6. Repair Done; Creating MAGIC CARD from BIN Dump If your phone have more actual firmware version than ZBIN file on support or you have unsupported phone – you can make ZBIN file by yourself from BINary dump ( eMMC Direct Dump or ADB Full Dump) 1. Run EasyJTAG Software and select SD Image Plugin 2. Select (128mbt DUMP)BIN* file for creating recovery card by clicking button 3. Click [Convert From BIN] button 4. After operation complete you will get ZBIN and PIT file in source folder. • Different Platforms requires different ROM parts for Magic SD |
The Following 68 Users Say Thank You to blang For This Useful Post: |
12-11-2014, 20:05 | #2 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Pakistan
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | Sir, Very good user manual but better you give video manual. Best Regards |
The Following 5 Users Say Thank You to DUNIYA JAMAL For This Useful Post: |
12-11-2014, 22:28 | #5 (permalink) |
Freak Poster Join Date: Nov 2013 Location: SAUDIA ARABIA
Member: 2065652 Status: Offline Thanks Meter: 60 | Question Do I need Use TWEEZER TO SHORT of some dead bodies |
The Following 3 Users Say Thank You to HaSHaM3001 For This Useful Post: |
12-12-2014, 00:19 | #7 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
The Following 10 Users Say Thank You to blang For This Useful Post: |
12-12-2014, 06:57 | #8 (permalink) |
Freak Poster Join Date: Aug 2011 Location: New York City
Member: 1637281 Status: Offline Sonork: 100.1657188 Thanks Meter: 95 | Excellent ....feedback, tips..... results..... anyone.? Problem is, some phones do not boot with the sd card method, unless your doing a tweak. I had a phone that I could only odin with the card in and when I pulled the card, It wouldnt work so I had to stop being lazy and do the jtag chain and presto, no need for sd after the real jtag thing. Now we need a image sharing thread with phones labeled correctly when we post them... |
The Following 2 Users Say Thank You to concepttheman For This Useful Post: |
12-12-2014, 08:33 | #11 (permalink) |
No Life Poster Join Date: Oct 2005 Location: iSiddeque Age: 41
Member: 188260 Status: Offline Sonork: 100.1590438 Thanks Meter: 428 | EasyJTAG Magic SD Card Tool Operation Picture Manual for new bees. Creating MAGIC CARD from ZBIN Image. Step 1 Run Plugin Step 2 Browse zbin file Step 3 Select SD cared reader Step 4 Write SD cared Magic Cared is ready for boot repair now do these steps. Recovery Phone by SD Unbrick card 1. Insert SD Card in phone SD card slot and attach battery 2. Put phone in Download mode by USB-JIC either by keyboard combination ( make sure that you have used file with newer firmware than current phone firmware. If you don't know what firmware have ben in phone before software damage – just use latest zbin file from support!) 3. If phone go in ODIN mode, download firmware with same version as in ZBIN file e.g if you used 4. Samsung_GT-I9200_I9200XXUDNE4_GPT_UEFI.zbin you should use I9200XXUDNE4 firmware or newer one. 5. Flash phone with ODIN with PIT file! 6. Repair Done. Creating MAGIC CARD from BIN Dump Do step 1 and 2 same as above. Step 3 and 4. BR. Siddeque. |
The Following 19 Users Say Thank You to .:MobileLife:. For This Useful Post: |
12-12-2014, 08:35 | #12 (permalink) |
Member: 188260 Status: Offline Sonork: 100.1590438 Thanks Meter: 428 | |
The Following 6 Users Say Thank You to .:MobileLife:. For This Useful Post: |
