04-23-2015, 17:02 | #32 (permalink) |
No Life Poster Join Date: Nov 2011 Location: Student
Member: 1686564 Status: Offline Sonork: PM me Thanks Meter: 157 | FIRMWARE UPDATE ok writing error Z3X EasyJtag Software ver. 1.9.1.2 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 191911044D64DB2C, ,FW Ver.: 01.52 CMD Pullup Level:2052 mV CMD Active Level:2629 mV eMMC Device Information EMMC CID : 1501003030303030305620110726589C EMMC CSD : 902701320F5903FFF6DBFFEF8A404022 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/2005 Rev.0x56 EMMC NAME: 000000 , S/N: 537986854 EMMC NAME (HEX): 30303030303000 EMMC ROM1 (Main User Data) Capacity: 16384 MB EMMC ROM2 (Boot Partition 1) Capacity: 512 kB EMMC ROM3 (Boot Partition 2) Capacity: 512 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. Backup saved: 000000_ 537986854_20150304_2118.extcsd Done. eMMC firmware update Running:SAMSUNG: eMMC firmware update... Confirmed eMMC Part Number: KMVTU000LM-B503 Z3X EasyJtag Software ver. 1.9.1.2 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 191911044D64DB2C, ,FW Ver.: 01.52 CMD Pullup Level:2052 mV CMD Active Level:2619 mV Setup firmware update mode, wait 2..30 sec... Success! Sending eMMC firmware... Success! Verifying eMMC firmware... Success! Flashing eMMC firmware... Success! Repairing eMMC CID... Success! eMMC firmware is updated now! Please reconnect all eMMC lines before next operation! Please don't forget to repair extCSD from backup! Please don't forget to configure BOOT sizes! Done. Rading ok Z3X EasyJtag Software ver. 1.9.1.2 Skip loading eMMC Addon Firmware CMD Pullup Level:2031 mV CMD Active Level:2382 mV Output file :C:\Documents and Settings\Narayanmobile\My Documents\EMMC_ROM1_00000000_20000000.bin Reading 0x000020000000 bytes from 0x000000000000 ...ROM1 ( USER ROM) Done. Read Speed: 637 kB/s writing error Input file : C:\Documents and Settings\Narayanmobile\Desktop\I9300 Fromsupport\EMMC_ROM1_00000000_20000000.bin Writing 0020000000 bytes to 00000000 ...ROM1 (USER ROM) Retry writing adress 0x00000000 (Attempt #1)... Retry Success! Disabling Write Optimistations... Retry writing adress 0x00003E00 (Attempt #1)... Retry Success! Disabling Write Optimistations... Retry writing adress 0x00007C00 (Attempt #1)... Retry Success! Disabling Write Optimistations... Retry writing adress 0x0000BA00 (Attempt #1)... Retry Success! Disabling Write Optimistations... Retry writing adress 0x0000F800 (Attempt #1)... Retry Success! Disabling Write Optimistations... Retry writing adress 0x00011E00 (Attempt #1)... Retry Success! Disabling Write Optimistations... Retry writing adress 0x00013E00 (Attempt #1)... Retry Fail! Retry writing adress 0x00013E00 (Attempt #2)... Retry Fail! Retry writing adress 0x00013E00 (Attempt #3)... Retry Fail! Write Block Failed, Reason: CARD Ready Timeout Error Done. Emmc info eMMC Device Information EMMC CID : 15010056545530304DFC3D39868641FA EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 04/2014 Rev.0xFC EMMC NAME: VTU00M , S/N: 1027180166 EMMC NAME (HEX): 56545530304D00 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. Backup saved: VTU00M_1027180166_20150304_2149.extcsd Done. |
04-23-2015, 17:13 | #34 (permalink) | |
Moderator Join Date: Dec 2010 Location: Malaysia
Member: 1464783 Status: Offline Thanks Meter: 1,091 | Quote:
set boot partition............ BR Nizda Mobile | |
04-29-2015, 09:30 | #37 (permalink) |
Insane Poster Join Date: Sep 2012
Member: 1813698 Status: Offline Thanks Meter: 8 | Running:SAMSUNG: eMMC firmware update... Confirmed eMMC Part Number: KMVTU000LM Z3X EasyJtag Software ver. 1.9.1.0 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0303FF1EE5A6F6B4, ,FW Ver.: 01.52 CMD Pullup Level:2114 mV CMD Active Level:2629 mV Setup firmware update mode, wait 2..30 sec... Success! Sending eMMC firmware... Success! Verifying eMMC firmware... Verifying eMMC firmware fail: NO Error Done. |
04-29-2015, 10:17 | #38 (permalink) |
Member: 1813698 Status: Offline Thanks Meter: 8 | Running:SAMSUNG: eMMC firmware update... Confirmed eMMC Part Number: KMVTU000LM Z3X EasyJtag Software ver. 1.9.1.0 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0303FF1EE5A6F6B4, ,FW Ver.: 01.52 CMD Pullup Level:1258 mV CMD Active Level:2650 mV Setup firmware update mode, wait 2..30 sec... Success! Sending eMMC firmware... Success! Verifying eMMC firmware... Success! Flashing eMMC firmware... Success! Repairing eMMC CID... Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 1.9.1.0 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0303FF1EE5A6F6B4, ,FW Ver.: 01.52 CMD Pullup Level:1227 mV CMD Active Level:2650 mV Can't init device, Reason: CMD Timeout Error Done. |
05-30-2015, 21:49 | #40 (permalink) |
Freak Poster Join Date: Aug 2009
Member: 1090661 Status: Offline Thanks Meter: 15 | cAN ANYONE GIVE ME A HAND? Hi everyone, I am trying to fix a I9300, it has a white lcd when I try to turn it on, I can access download mode normally, I coonect 6 cables to pcb according to the pictures on z3x server. after that I am using EMMC adaptor, I plug the cable to a phone charger 5 V, and When I try to detect EMMC y get this message: Z3X EasyJtag Software ver. 2.0.0.2 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 1717160E617F118E, ,FW Ver.: 01.52 CMD Pullup Level:3114 mV CMD Active Level:3196 mV Can't init device, Reason: CMD Timeout Error Done. Whitout care the Voltage I select is always same answer, If I press Set i9300/i7100 Config Running:Change BOOT CONFIG... Z3X EasyJtag Software ver. 2.0.0.2 Skip loading eMMC Addon Firmware CMD Pullup Level:1753 mV CMD Active Level:1815 mV Can't init device, Reason: CMD Timeout Error Done. Running:Change BOOT WIDTH... Z3X EasyJtag Software ver. 2.0.0.2 Skip loading eMMC Addon Firmware CMD Pullup Level:1753 mV CMD Active Level:1815 mV Can't init device, Reason: CMD Timeout Error Done. |
06-06-2015, 14:41 | #41 (permalink) |
Freak Poster Join Date: Apr 2008 Location: west java
Member: 756701 Status: Offline Sonork: 100.1592286 Thanks Meter: 91 | please ADD firmware emmc samsung KMK5U000VM-B309 for Gt-s7270 Z3X EasyJtag Software ver. 2.0.0.0 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 07070xxxxxxxxx, ,FW Ver.: 01.52 CMD Pullup Level:2145 mV CMD Active Level:3104 mV eMMC Device Information EMMC CID : 1501003030303030305620110726589C EMMC CSD : 902701320F5903FFF6DBFFEF8A404022 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/2005 Rev.0x56 EMMC NAME: <b>000000</b> , S/N: 537986854 EMMC NAME (HEX): 30303030303000 EMMC ROM1 (Main User Data) Capacity: 4095 MB EMMC ROM2 (Boot Partition 1) Capacity: 512 kB EMMC ROM3 (Boot Partition 2) Capacity: 512 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. Backup saved: 000000_ 537986854_20150505_1826.extcsd Done. BR |
09-01-2015, 07:56 | #43 (permalink) |
No Life Poster Join Date: Jul 2007 Location: My Computer
Member: 553178 Status: Offline Sonork: 100.1592454 Thanks Meter: 957 | Samsung i9300 totally dead EMMC repair done without removing EMMC Hi, friends here i am going to share Samsung i9300 totally dead EMMC [KMVTU000LM-B503] repair info how i have done this without removing EMMC from board. its not easy and also not possible without special devices. its just information if you have any emmc repair device you can get much information from this post. if you have dead phone in hands and have not any professional tool you can visit our service Lab to fix that. What we need to do this. 1= Z3X Easy Jtag 2= i9300 with dead emmc 3= special needle [shown in picture] 4= Good soldering skills Let's start get i9300 direct emmc pinouts from support. and remove glue under emmc near TP Solder pinouts carefully on board and emmc adapter witch come with x3x jtag insert needle and try then connect emmc adapter to easy jtag box. then try to detect emmc when you see emmc detected log in lo window you can remove needle. then start formware upgrade and follow instruction carefully given in easy jtag box log window. some screenshots.
The Following 3 Users Say Thank You to >>PakFones<< For This Useful Post: |
