this will work only if you have emmc connection experience before then you will need a tp neadle this needle must be connected with ground wire at detection time. first do experimenta on open emmc when you get hold on it then try on board emmc. Good Luck dear. Sent from my SM-N910C using Tapatalk |
@shamsulhaq @ shabirahmad22 this is not fake this is real we are doing this since months without removing emmc ic on i9300/n7100 if you need prove bring sets with such issue we will show you how to do this in few mins without removing emmc or any components Regards |
1 Attachment(s) @shamsulhaq and shabirahmad22 : don't worry dear everything is no impossible in this world. one more update i have dumped emmc with usb flash drive pcb also connect memory card on it few years ago. i have got this picture from my facebook account you can see there. Attachment 346424 Sent from my SM-N910C using Tapatalk |
Nice work here Thanks very much |
Anyone work out how to not wipe the eMMC with firmware update.? If so please telll...?? |
please help me pinout samsung SM-G316HU/DS |
before repair it was dead JTAG Connection is not supported for this device Z3X EasyJtag Software ver. 2.2.0.2 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 1616100C7FD4B36E, ,FW Ver.: 01.55CMD Pullup Level:2010 mV CMD Active Level:2475 mV Box IO Level:3300 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ----------EMMC CID : 1501003030303030305620110726589C EMMC CSD : 902701320F5903FFF6DBFFEF8A404022 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/2005 Rev.0x56 EMMC NAME: 000000 , S/N: 537986854 EMMC NAME (HEX): 30303030303000 EMMC ROM1 (Main User Data) Capacity: 16384 MB EMMC ROM2 (Boot Partition 1) Capacity: 512 kB EMMC ROM3 (Boot Partition 2) Capacity: 512 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: 000000_ 537986854_20160811_1922.extcsd Done. after repair Z3X EasyJtag Software ver. 2.2.0.2 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 1616100C7FD4B36E, ,FW Ver.: 01.55CMD Pullup Level:2547 mV CMD Active Level:3124 mV Box IO Level:3300 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 1501005654553030300C20138686416E EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 04/2014 Rev.0xC EMMC NAME: VTU000 , S/N: 538150534 EMMC NAME (HEX): 56545530303000 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: VTU000_ 538150534_20160811_1931.extcsd Done. world best z3x team |
nice information and zex jtag price????? |
i still dont know ....why to use special needle ? pls explain more why we need that |
very good i need some video !!!! Thanks. |
Is it just a wire attached to the ic???? |
where is the tp point? Quote:
With great interest I looked at the topic. |
