Old 02-06-2018, 21:32   #16 (permalink)
Member: 2659863
i have this problem
Old 02-07-2018, 02:41   #17 (permalink)
Member: 1112585
Sonork: 100.1645028
Thanks Meter: 91
Full Disk Encryption .!!!!
you have to burteforce the PASSW0RD.
Research the internet for FORENSIC TYPE DATA RECOVERY.
Old 02-08-2018, 15:18   #18 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 186,558
Originally Posted by vnsun View Post
I need recove data but faile..can you help me
here log :
eMMC_tool Suite ver. 1.4.9.0 (release date: 12.12.2017)
Microsoft Windows 7 (64 bit) build 7601 (6.1.7601.17686)
Looking for EasyJTAG box...
EasyJTAG API ver. 2022
EasyJTAG Box Serial =
Card Serial =
EasyJTAG Box Firmware = 1.62
Changelog:
12.12.2017 (ver 1.4.9.0)
Fix: Bugs that have been found through your crash report
Fix: RandomVerify function
Fix: Creation of GPT for Samsung (write by vendor)
Fix: Failed to mount large Fat partitions (explorer)
Fix: Extraction from contact2.db (explorer)
Fix: Error in the "build.prop" parser
Fix: CID Parser
Add: Support for EasyJtag Plus Box
Add: Path for TempDir and InitialDir (option in settings)
Add: Unpack Lenovo QSB (utilities)
Add: Selecting a PIT file from CSC (write by vendor Samsung)
Add: Detect for encrypted dumps from GPG Box
Add: Detect for FullDiskEncryption Partition (explorer)
Add: LinearVerify of the Partition (read by vendor)
Add: Information base about emmc compatibility (thanks to phonemicrodb)
Add: Resizing the window (for small screen resolutions)
Add: Converting large partitions in SparseImage when reading by vendor (option in settings)
Add: Mounting SparseImage (explorer)
Add: Automatic backup of the EFS partition for Samsung (read by vendor)
Add: Formatting of EFS partition for Samsung on request (write by vendor)
Scan from image: userdata.bin
Vendor: Samsung
Searching GPT ...
GPT header is not found
Searching PIT ...
PIT not found
Partition table not found
Scan done
Setting frequence to 14 Mhz
CMD Pullup Level: 2784 mV
CMD Active Level: 2722 mV
EMMC Device Information :
EMMC CID: 150100514E3136424200600ED2AB242C
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
EMMC Manufacture Name: SAMSUNG , EMMC NAME: QN16BB , EMMC NAME (HEX): 514E31364242 , S/N: 600ED2AB , rev. 0x00
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Manufacture Date: 2/2017
EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: QN16BB_600ED2AB_20180204_151830.extcsd
EMMC Init completed.
Scan from: QN16BB
Vendor: Samsung
Searching GPT ...
GPT header is found and is valid
GPT header successfully parsed
Scan done
Mount [efs] successfully PartType: LINUX
Mount [nvdata] successfully PartType: LINUX
Mount [protect_f] successfully PartType: LINUX
Mount [protect_s] successfully PartType: LINUX
Mount [system] successfully PartType: LINUX
Mount [cache] successfully PartType: LINUX
Mount [preload] successfully PartType: LINUX
Mount [userdata] SKIPPED PartType: Full Disk Encryption
on android 5 and high need password for open user data encrypt.
Old 03-06-2018, 14:58   #19 (permalink)
devika's Avatar
Member: 78028
Thanks Meter: 90
Setting interface to EasyJtag2/E-Socket
Setting bus width to 1 Bit
Setting frequence to 42 Mhz
EMMC CID: 150100524836344142054ED8A8174473
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
EMMC Manufacture Name: SAMSUNG , EMMC NAME: RH64AB , EMMC NAME (HEX): 524836344142 , S/N: 4ED8A817 , rev. 0x05
EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000)
Extended CSD rev: 1.8 (MMC 5.1)
Backup saved: RH64AB_4ED8A817_20180306_181431.extcsd
Get firmware version
Brand = vivo
Manufacturer = vivo
Model = vivo 1716
Phone platform = msm8953
CPU Abi = arm64-v8a
Android release = 7.1.2
Firmware version = N2G47H release-keys
Firmware date = Mon Sep 4 18:56:44 CST 2017
Backup saved: RH64AB_4ED8A817_20180306_180237.extcsd
Scan from: RH64AB
Vendor: Qualcomm
Searching GPT ...
Scan done
Mount [modem] successfully PartType: FAT16
Mount [dsp] successfully PartType: LINUX
Mount [persist] successfully PartType: LINUX
Mount [oem] successfully PartType: LINUX
Old 03-06-2018, 15:14   #20 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
1) Encrypted data not support
2) Set bus width to 8 Bit and use full speed of box
The Following User Says Thank You to layder For This Useful Post:
Old 03-06-2018, 15:53   #21 (permalink)
devika's Avatar
Member: 78028
Thanks Meter: 90
Thanks a lot for your kind information
https://www.androidauthority.com/how...device-326700/
Old 03-06-2018, 16:18   #22 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
http://netk.org/sites/default/files/...cryption_m.jpg
The Following 2 Users Say Thank You to layder For This Useful Post:
Old 03-21-2018, 06:33   #23 (permalink)
Member: 2170791
Thanks Meter: 50
i have the password but how can I recover data from phone? will you please explain the procedure?
The Following User Says Thank You to ksajin For This Useful Post:
Old 04-25-2018, 22:29   #24 (permalink)
DUSKnenixs's Avatar
Member: 5169
Thanks Meter: 684
yes with pin code any possibel to revocer data from phone?
The Following User Says Thank You to DUSKnenixs For This Useful Post:
Old 04-27-2018, 10:54   #25 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
If you have password, you can mount flash IC and CPU to another phone, and enter password at power-on phone. And you need to backup crypted partiton to restore it, when it needed.
The Following 3 Users Say Thank You to layder For This Useful Post:
Old 06-25-2018, 17:43   #26 (permalink)
Member: 1520712
Thanks Meter: 19
s7 s7edge is support?
Old 07-08-2018, 12:07   #27 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 957
Hi, Sir can you tell me how can we access userdata partition if i have screen pattern lock? Phone is not in working condition.
Old 07-15-2018, 10:01   #28 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 957
Remove FDE (Full Disk Encryption) Using Easy JTAG
History:
I received a MTK Basedphone in dead condition for customer and He want his personal data from it. Android info log can be seen below. He know screen lock but due to shortage phone can't power on.
Brand = Infinix
Manufacturer = Infinix
Model = Infinix HOT S
Phone platform = mt6753
CPU Abi = arm64-v8a
Mediatek platform = MT6735
Android release = 7.0
Firmware version = X521-J5088AC-N-170602V34
Firmware date = Fri Jun 2 23:32:32 CST 2017
Problem:
Due to FDE (Full Disk Encryption) i am facing "Mount [data] SKIPPED PartType: Full Disk Encryption" While exploring the internal memory.
Android FDE Info Log:
Selected pinout: EasyJTAG GEN1 ISP Pinout
Change EasyJTAG Pinout OK
Running:Search Full Drive Encryption Keys
Z3X EasyJtag Software ver. 2.9.0.1
Loading eMMC Addon Firmware... IO: 2800 mV
Box S/N: 0FFFF01xxxxxxxx, ,FW Ver.: 01.63
CMD Pullup Level:2062 mV
CMD Active Level:2681 mV
Box IO Level:2800 mV
CLK Rate:21000 kHz
HiPower mode is ON!
Can't init device, Reason: PORT Read Error
Done.
I have 16 GB full emmc dump from this phone. I tried almost all Easy JTAG Modules Easy Jtag Box Classic Suite, Easy JTAG Plus, Emmc File Manager, EasyJTAG Android Explorer etc,
If there is any way to explore this phone using ESAY JTAG please let me know where i making mistake? As i told we have screen lock password please let me know if there is any way to retrieve user from it via brute force, or any other way to mount userdata partion?
I have not good knowledge of programming but may be we can crack FDE using Brute Force method, or may be we can mount user data partition using android emulator and can enter screen lock to access userdata partition.
I also have some Easy JTAG Tutorial videos on my YouTube channel for users who can understand Urdu and Hindi language, Can embed youtube videos to post tutorials in Easy JTAG section?
Regards!
Last edited by >>PakFones<<; 07-15-2018 at 10:02. Reason: Removed some white spaces
The Following 2 Users Say Thank You to >>PakFones<< For This Useful Post:
Old 07-16-2018, 20:38   #29 (permalink)
johnoroo37's Avatar
Member: 2025428
Thanks Meter: 445
Plz post phone emmc pinout here
Old 07-19-2018, 08:52   #30 (permalink)
Member: 2636476
Thanks Meter: 61
Originally Posted by >>PakFones<< View Post
History:
Brand = Infinix
CPU Abi = arm64-v8a
Problem:
CLK Rate:21000 kHz
HiPower mode is ON!
Done.
Regards!
Your problem solved or not
Page generated in 0.25989 seconds with 9 queries
