Old 07-19-2018, 11:47   #31 (permalink)
Member: 2182001
Thanks Meter: 51
Reading Android Info
Partition [/system] Not Found, Try Extended Search..
Partition #61 is [/system]. Mount..
Reading data..
Vendor = unknown
Brand = Huawei
Model = generic_a53_32
Device ID = generic_a53_32
Name ID = generic_a53_32
Android version = 7.0
Firm version = System 5.1.0.78(0H7S)
Firm date = Wed Oct 4 19:12:13 CST 2017
SDK version = 24
ID = NRD90M
CPU ABI = armeabi-v7a
CPU ABI2 = armeabi
CPU ABI LIST = armeabi-v7a,armeabi
CPU ABI LIST32 = armeabi-v7a,armeabi
Product = generic_a53_32
Ok so i have the same problem no ways guys need a key master blobs stored in cpu.. unique for each device like ios!
Old 07-19-2018, 15:26   #32 (permalink)
Member: 2182001
Thanks Meter: 51
For who have a working phone you can do that
You need to extract
Simply invoke the python script fde_bruteforce.py using:
The crypto footer from the device
The leaked KeyMaster keys
For other i think the only ways is swap emmc and cpu e recover the data...
Old 07-19-2018, 19:09   #33 (permalink)
Member: 2636476
Thanks Meter: 60
I hve the same situation in motorola xt1550 phone is short i remove emmc then dectect in easy jtag fully encrypted data
Old 07-19-2018, 20:15   #34 (permalink)
Member: 2182001
Thanks Meter: 51
remove the short...
For my case, after i backup the full image i try to solve the motherboard hw, reball the pm the phone was in full working condition... Done, see in my twitter the little story https://twitter.com/Nick_Il_Vento
The Following User Says Thank You to genhack23 For This Useful Post:
Old 07-21-2018, 08:06   #35 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 956
My problem still not solved but if someone have full short phone just watch this video to remove shortage easily.
Old 12-20-2018, 13:15   #36 (permalink)
tahernike's Avatar
Member: 495542
Sonork: 100.1650191
Thanks Meter: 45
how to get data from Encryption phone
i try many phone new type
like g610f j250f c7000 c9000
always give me that
Setting interface to EasyJtag2/ISP
Setting bus width to 1 Bit
Setting frequence to 36 Mhz
CMD Pullup Level: 2749 mV
CMD Active Level: 2807 mV
EMMC Device Information :
EMMC CID: 150100434A4E4234521097F959BF2431
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
EMMC Manufacture : SAMSUNG , EMMC NAME: CJNB4R , HEX: 434A4E423452 , S/N: 97F959BF , rev. 0x10
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 2/2017
   EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000)
   EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
   EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: CJNB4R_97F959BF_20181220_141126.extcsd
EMMC Init completed.
Scan from: CJNB4R
Vendor: Samsung
Searching GPT ...
GPT header is found and is valid
GPT header successfully parsed
Scan done
Mount [efs] successfully   PartType: LINUX
Mount [persist] successfully   PartType: LINUX
Mount [dsp] successfully   PartType: LINUX
Mount [modem] successfully   PartType: FAT16
Mount [apnhlos] successfully   PartType: FAT16
Mount [persdata] successfully   PartType: LINUX
Mount [system] successfully   PartType: LINUX
Mount [cache] successfully   PartType: LINUX
Mount [userdata] SKIPPED   PartType: Full Disk Encryption
The Following User Says Thank You to tahernike For This Useful Post:
Old 12-20-2018, 13:17   #37 (permalink)
NoName®'s Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 6,191
always give me that
Scan from: CJNB4R
Vendor: Samsung
Searching GPT ...
Scan done
There is no way , without knowledge of password pin etc , used for FDE encryption.
The Following 2 Users Say Thank You to NoName® For This Useful Post:
Old 01-24-2019, 13:53   #38 (permalink)
Member: 2127758
Thanks Meter: 26
Do you mean pattern code?
So if we have the pin/pattern we can decrypt the data?
Old 03-18-2019, 03:59   #39 (permalink)
c3llf3r's Avatar
Member: 149217
Thanks Meter: 21
of emmc will it be possible to read the user's data partition and then write it to another cell of the same model that works very well?
Will it be possible for me to see your user data?
thank you very much I hope soon answer.
Old 05-07-2019, 15:33   #40 (permalink)
Member: 975554
Sonork: KG state:prenormal
Thanks Meter: 234
Originally Posted by SILVER ANJEL View Post
s7 s7edge is support?
phone has ufs storage this is deferent type
Old 05-07-2019, 22:05   #41 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,836
At new phones userdata is crypted
Old 06-12-2019, 16:25   #42 (permalink)
Member: 971036
I have problem to extract data from samsung a520f.
This is my log:
Vendor: Qualcomm
Searching GPT ...
Scan done
Mount [preload] successfully PartType: LINUX
Mount [USERDATA] SKIPPED PartType: Full Disk Encryption
I try with easyjtag plus, classic and emmc file manager addon 1.17 but nothing. Any solution?
Old 06-12-2019, 19:50   #43 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,836
Currently there are no solutions
perhaps in the future it will be possible to somehow recognize the partition encryption keys
Old 06-28-2019, 12:24   #44 (permalink)
Member: 2701984
HELP USERDATA] SKIPPED PartType: Full Disk Encryption
I do not have access to the data partition I need to remove pattern or read it
Old 06-29-2019, 08:15   #45 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,836
There are no simple way to decode data from crypted partition - only format it, and data lost (with password settings)
Page generated in 0.25307 seconds with 9 queries
