Old 11-27-2017, 23:29   #1 (permalink)
Member: 2767015
Using Easy Jtag for Data Recovery
Hi
I thinking on purchase Easy Jtag just for data recovery work, mainly from dead phones. I don't need to repair or unlock phones.
Is it the ideal tool? Can I get the data (photos, videos, for instance) out of a dead phone PCB? Will I have any type of encryption problem or the data reads directly? Do you have any videos/tutorials for this?
Will it also work on tablets?
What do you suggest?
Thank You
The Following User Says Thank You to rop12770 For This Useful Post:
Old 11-28-2017, 09:31   #2 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
You can use "EasyJTAG eMMC plus" tool and ""Emmc FileManger Addon" to extract dato from unencrypted disks from eMMC (ext, fat, ntfs)
Android 7 and 8 used encrypted userdata by default
The Following 8 Users Say Thank You to layder For This Useful Post:
Old 11-28-2017, 16:44   #3 (permalink)
Member: 1247453
Thanks Meter: 13
Hello. There is no way to extract the data in Android 7 and Android 8 ?, not even with another box like ufi box?
Old 11-28-2017, 16:45   #4 (permalink)
Member: 1247453
Thanks Meter: 13
Hello, There is no way to extract the data in Android 7 and Android 8 ?, not even with another box like ufi box?
Old 11-29-2017, 13:12   #5 (permalink)
Member: 2767015
The problem is that encryption... Is there any solution?
What about tablets? Can it work with them too?
Thank You
Old 11-29-2017, 20:53   #6 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
All box has one type of accses to eMMC. File system encryption are problem for all
eMMC File Manager screenshot:
http://i97.fastpic.ru/big/2017/1129/...e3819e3e52.png
work with tablet eMMC at socket via EasyJtag Box Plus
The Following 3 Users Say Thank You to layder For This Useful Post:
Old 11-29-2017, 21:56   #7 (permalink)
Member: 1247453
Thanks Meter: 13
then, it is currently not possible to recover data with any box emmc, taking a phone or tablet Android 7 or 8?
Enviado desde mi HTC One_M8 mediante Tapatalk
Old 11-29-2017, 22:56   #8 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
at deaful android 4-5-6 not crypt data partition.
Android 7 and 8 crypt data patition by default.
Old 11-30-2017, 15:06   #9 (permalink)
Member: 2767015
Well, 90% of the android market phones still work under version 7 or 8.
So the chance of getting a phone decrypted is still high I think.
Old 12-15-2017, 16:57   #10 (permalink)
Member: 142949
Thanks Meter: 71
xiaomi note 4 android 7.0
userdata not open
it is file binary
i use easy 2.061
version new have extract ?????
The Following User Says Thank You to nguyenhuu For This Useful Post:
Old 12-15-2017, 21:37   #11 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
userdata not open
it is file binary
i use easy 2.061
try use emmc_easyjtag_plus 1.4.9.0
if userdata crypted - you see it
Old 12-16-2017, 18:33   #12 (permalink)
Member: 142949
Thanks Meter: 71
eMMC_tool Suite ver. 1.4.9.0 (release date: 12.12.2017)
Microsoft Windows 7 (32 bit) build 7601 (6.1.7601.22177)
Mount [dsp] successfully PartType: LINUX
Mount [system] successfully PartType: LINUX
Mount [cache] successfully PartType: LINUX
Mount [persist] successfully PartType: LINUX
Mount [misc] successfully PartType: LINUX
Mount [cust] successfully PartType: LINUX
Mount [userdata] SKIPPED PartType: Full Disk Encryption <-> not ok
Old 12-16-2017, 18:34   #13 (permalink)
Member: 142949
Thanks Meter: 71
Get firmware version
Brand = xiaomi
Manufacturer = Xiaomi
Model = Redmi Note 4
Phone platform = msm8953
CPU Abi = arm64-v8a
Android release = 7.0
Firmware version = AL1512-mido-build-20171028011511
Firmware date = Sat Oct 28 01:15:09 WIB 2017
Old 12-16-2017, 19:30   #14 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
Encription not extract at now
Old 02-04-2018, 09:24   #15 (permalink)
Member: 655261
Thanks Meter: 46
Full Disk Encryption - How to fix?
I need recove data but faile..can you help me
here log :
Microsoft Windows 7 (64 bit) build 7601 (6.1.7601.17686)
Looking for EasyJTAG box...
EasyJTAG API ver. 2022
EasyJTAG Box Serial =
Card Serial =
EasyJTAG Box Firmware = 1.62
Changelog:
12.12.2017 (ver 1.4.9.0)
Fix: Bugs that have been found through your crash report
Fix: RandomVerify function
Fix: Creation of GPT for Samsung (write by vendor)
Fix: Failed to mount large Fat partitions (explorer)
Fix: Extraction from contact2.db (explorer)
Fix: Error in the "build.prop" parser
Fix: CID Parser
Add: Support for EasyJtag Plus Box
Add: Path for TempDir and InitialDir (option in settings)
Add: Unpack Lenovo QSB (utilities)
Add: Selecting a PIT file from CSC (write by vendor Samsung)
Add: Detect for encrypted dumps from GPG Box
Add: Detect for FullDiskEncryption Partition (explorer)
Add: LinearVerify of the Partition (read by vendor)
Add: Information base about emmc compatibility (thanks to phonemicrodb)
Add: Resizing the window (for small screen resolutions)
Add: Converting large partitions in SparseImage when reading by vendor (option in settings)
Add: Mounting SparseImage (explorer)
Add: Automatic backup of the EFS partition for Samsung (read by vendor)
Add: Formatting of EFS partition for Samsung on request (write by vendor)
Scan from image: userdata.bin
Vendor: Samsung
Searching GPT ...
GPT header is not found
Searching PIT ...
PIT not found
Partition table not found
Scan done
Setting frequence to 14 Mhz
CMD Pullup Level: 2784 mV
CMD Active Level: 2722 mV
EMMC Device Information :
EMMC CID: 150100514E3136424200600ED2AB242C
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
EMMC Manufacture Name: SAMSUNG , EMMC NAME: QN16BB , EMMC NAME (HEX): 514E31364242 , S/N: 600ED2AB , rev. 0x00
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Manufacture Date: 2/2017
EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: QN16BB_600ED2AB_20180204_151830.extcsd
EMMC Init completed.
Scan from: QN16BB
Vendor: Samsung
Searching GPT ...
GPT header is found and is valid
GPT header successfully parsed
Scan done
Mount [efs] successfully PartType: LINUX
Mount [nvdata] successfully PartType: LINUX
Mount [protect_f] successfully PartType: LINUX
Mount [protect_s] successfully PartType: LINUX
Mount [preload] successfully PartType: LINUX
The Following User Says Thank You to vnsun For This Useful Post:
Page generated in 0.25747 seconds with 9 queries
