Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > Sim Cloning and Scaning
Old 07-26-2005, 11:19   #1 (permalink)
Member: 164652
Question about cloning
hi i'm new here
i wanted to know what are the advantages of sim cloning except doing backup of your own sim.
is it possible to steal someone line even if you never touched his sim?
Old 07-26-2005, 15:25   #2 (permalink)
Crazy Poster
Member: 1219
"NO!"
123456789123456789
Old 07-29-2005, 18:28   #3 (permalink)
Member: 153324
If I clone multiple SIM cards, Can I use the lines on them?
Also, Will my mobile phone display all the available networks on the screen or do I need to turn OFF the phone to select which network will display?
Old 07-29-2005, 22:00   #4 (permalink)
CH@IN's Avatar
Location: Getting it to work is easy... making it do the things you want is another thing.
Member: 9824
Thanks Meter: 79
One number will only be active. You can't have two lines activated at the same time.
The switching of the numbers can be done through a new menu that will appear on your mobile ('Select phone #'). You will not have to turn off your phone and log in with a different pin, but you can do it this way as well.
The "select phone #" menu does not work on every model without "reboot" of the phone. If the menu will work on your phone, expect about 10 seconds for the switching from one number to the other. The "active" phone number will appear on the display with a note that you can define.... My phone i.e. displays "NETWORK" and below that the active number "+691234567"
Old 07-30-2005, 14:51   #5 (permalink)
Member: 164652
Originally Posted by ferroxcube
"NO!"
123456789123456789
so what can i do with cloning what can it give for me?
Old 07-30-2005, 15:10   #6 (permalink)
CH@IN's Avatar
Member: 9824
Thanks Meter: 79
if you don't find a reason on your own, then you don't need a clone at all.
You might want to read this to get some ideas what it could be usefull for:
http://forum.gsmhosting.com/vbb/show...5&postcount=12
Old 08-04-2005, 06:00   #7 (permalink)
Member: 149498
Thanks Meter: 4
Hello Ch@in,
what is the solution now for cloning sims into 1???
I have 4 lines of 4 diffrent operators(plus 2 other lines from a diffrent countries) I don't want to be holding
4 hansets as it's expensive to maintain or buy 4 handsets @ the same time.
Forgot 1 home or forgot to charge 1 of them, fell down... Turning off 1 switching the sim, or loose the sim....... the list never ends
I want to be having 1 sim with all my lines in it & will be chosing wich 1 to use. It was possible before but now with V2 i guess it's not. So what is the solution????? What is illegal in having 1 sim with all the lines that i have???
Any coming solutions or a solution that i'm not aware of ???
Old 08-04-2005, 07:30   #8 (permalink)
CH@IN's Avatar
Member: 9824
Thanks Meter: 79
Originally Posted by nabilaj
Hello Ch@in,
Still the same situation as it was 4 years ago: Only comp128V1 cards (old generation cards) can be cloned. It's not possible to have more than 1 number active at the same time. If you urgently need to have two comp128V2 cards, then you can get a hardware solution that would require you to cut and solder the ORIGINAL sim on a small electronic device that will fit in your phones card-holder.
In my opinion, the best thing to do is find an OLD simcard (v1) from the network you want, and ask the network-provider to convert that number from prepaid to subscription WITHOUT ISSUING A NEW SIMCARD. Maybe some of your friends still have working V1 prepaid sims that you could buy from them or exchange for a new USIM card.
Good luck
Old 08-20-2005, 00:26   #9 (permalink)
Member: 171014
Thanks Meter: 2
Hi, RAMIRAMI
My advantages of cloning are:
I have 3 simcards, of 3 different operators (vodafone, tmn, optimus) now my telephone only gives for 1 simcard... OK?
Comprende my friend ?
Best regards
FClone from Portugal
Old 08-20-2005, 14:06   #10 (permalink)
Member: 171014
Thanks Meter: 2
More, I can still have up to 12 nº of telephone of any 3 operators ( in the same smartcard off course )
Regards
Old 08-20-2005, 15:16   #11 (permalink)
Member: 171014
Thanks Meter: 2
And more
I have of the double of phone book entries, and of the triple of sms
since you see, that is wonderfull.because the original sim has very little memory
From Portugal.............bye
question about superdongle data of n-95 8gb compue Universalbox 2 03-29-2010 15:16
One Question About Cruiser,pls Gubby_J Cruiser Suite 2 03-29-2010 12:46
Question about Sony Ericsson Xperia X1 Clone – iFone x1 sweunlockers Chinese Models & Cloned Phones 1 09-22-2009 08:43
Question about cloned SmartClip V2.05 Dream gsm Motorola P2k 7 02-22-2006 10:49
Few questions about sim-cloning... jnf Sim Cloning and Scaning 3 05-10-2004 09:46
Page generated in 0.27204 seconds with 9 queries
