Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM / HSDPA Modems and Routers
GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares
Old 04-07-2015, 12:12   #16 (permalink)
Member: 1321038
Help regarding Charji unlock
Hi all... I just unlocked my own Char ji device by PTCL With model number Huawei EC5377u-872. I just gave my imei to the following sites and they posted me back my unlock code. The shopkeepers charge around 1000 to 4000 for unlocking the Device. Im posting the sites. if you have any problem unlocking yourself PM me and i will help you out. PM me for the link. i am not allowed to post links now...
Regards,
Asim
The Following User Says Thank You to asimyo88 For This Useful Post:
Old 04-12-2015, 19:31   #17 (permalink)
Member: 2373385
Originally Posted by ..::AppleLinks::.. View Post
did you check on 4g networks in pakistan????
i checked working perfectly even band # 3 , 1800Mhz working on EC5377u-872
i think so device unlocing may unlocked LTE bands as well
Old 05-02-2015, 07:51   #18 (permalink)
Member: 2206874
Sonork: 100.1584591
Thanks Meter: 36
Thumbs down i can unlock
I can unlock any version of Ec5377 only pakistani user can pm me
The Following User Says Thank You to TauheedMobiles For This Useful Post:
Old 05-05-2015, 13:38   #19 (permalink)
Member: 2370993
huawei EC5377
dear all mein recently huawei ec5377 leya hai .. phely tu walay mein tu unlock code mag rha tha per ab yeh msg aa rha hai it's lock for other network you can use on evo charji . koi bataty sakty hai yeh kiase unlock hogay
thanks
Old 05-11-2015, 18:06   #20 (permalink)
sunshine4u's Avatar
Member: 1383464
Sonork: 100.1669490
Thanks Meter: 100
NEw version of EC5377 by PTCL is not giving option for enter Unlock code . any solution for unlock on new version ?
Old 05-20-2015, 10:57   #21 (permalink)
Member: 714613
unlock
use huawei hilink andriod or ios app to inject unlock code easy and simple
Old 05-26-2015, 14:44   #22 (permalink)
Member: 2372277
Android Hilink App doesn't work on new firmware
Old 06-15-2015, 07:29   #23 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
Any new news about new sw which not supported code entering
Old 06-17-2015, 04:21   #24 (permalink)
Member: 2372277
Yes it can be unlocked by using command to enter unlock code
Old 06-24-2015, 06:08   #25 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
Originally Posted by unknownax View Post
yes it can be unlocked by using command to enter unlock code
by which commands and what is the procedure ????
Old 06-24-2015, 06:26   #26 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
THS THE OLD SOFTWRAE IN OLD EC5377
DC - Unlocker 2 Client 1.00.1190
Detecting modem :
selection :
manufacturer - Huawei modems
model - Auto detect (recommended)
Interface           : 192.168.8.1
Found modem         : EC5377u-872
Model               : Huawei EC5377
IMEI                : 864035020981420
Serial NR.          : D7KBY14B25003832
Firmware            : 11.432.11.10.172
Hardware ver.       : CL1EC5377UM
Web UI version      : 16.100.02.01.172
SIM Lock status     : unlocked
Wrong codes entered : 10 (unlock attempts left : 0)
HERE IS THE NEW SOFTWARE IN THESE DEVICES WHICH NOT ACCEPTED OR NOT ASK FOR ENTER CODES
Detecting modem :
selection :
model - Huawei EC5377
IMEI                : 864035020905718
Serial NR.          : D7KBY14B24001262
Firmware            : 11.432.11.11.172
Web UI version      : 16.100.02.02.172
Old 06-24-2015, 19:20   #27 (permalink)
salo_ustad's Avatar
Member: 413160
Sonork: 100.1657278
Thanks Meter: 96
how to connect these modems with window coz its not detecting ports
Old 07-10-2015, 06:11   #28 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
try to descend the position of network connection made by chargi in network properties.....bcz when you conect it it use the first postion for accessing the internet for the computer
Old 07-10-2015, 06:16   #29 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
Here you can see in attachment.............
Old 07-12-2015, 08:22   #30 (permalink)
Member: 2372277
This command
AT^CARDLOCK=”UNLOCK CODE”
Replace UNLOCK CODE with your code corresponding to the IMEI
Page generated in 0.31491 seconds with 9 queries
