GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares |
03-21-2016, 14:14 | #61 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: APPLE i Center Age: 39
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | Quote:
BEFORE DOWNGARDE Code: Detecting modem : selection : manufacturer - Huawei modems model - Auto detect (recommended) Interface : 192.168.8.1 Found modem : EC5377u-872 Model : Huawei EC5377 IMEI : 864035020981420 Serial NR. : D7KBY14B25003832 Firmware : 11.432.11.10.172 Hardware ver. : CL1EC5377UM Web UI version : 16.100.02.01.172 SIM Lock status : unlocked Wrong codes entered : 10 (unlock attempts left : 0) Code: selection : manufacturer - Huawei modems model - Auto detect (recommended) Found Applications port COM8 Found modem : EC5377u-872 Model : Huawei EC5377 IMEI : 864035020981420 Serial NR. : D7KBY14B25003832 Firmware : 11.432.11.00.45 Hardware ver. : CL1EC5377UM Dashboard version : UTPS22.001.22.00.03 SIM Lock status : Locked (Card lock) Wrong codes entered : 10 (unlock attempts left : 0) at^cardlock=”unlock code” | |
03-26-2016, 17:29 | #62 (permalink) |
Product Manager Join Date: May 2008 Location: Ukraine Age: 45
Member: 772096 Status: Offline Sonork: 100.69222 Thanks Meter: 8,277 | Hi all, i can make real unlock fir this modem. Need only get hardware in hands fir debug and internal testing. After private solution will be aboe for Mkey users only. |
08-13-2016, 10:25 | #65 (permalink) |
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | SOME ONE FOUND REAL AD WORKING SOLUTION FOR RESET CODE UNLOCK COUNTER FOR HUWAEI EC5377.??????? Code: Found modem : EC5377u-872 Model : Huawei EC5377 IMEI : 864035020966884 Serial NR. : D7KBY14B25002378 Firmware : 11.432.11.12.172 Hardware ver. : CL1EC5377UM Dashboard version : 22.001.22.02.03 SIM Lock status : Locked (Card lock) Wrong codes entered : 10 (unlock attempts left : 0) |
08-20-2016, 19:20 | #66 (permalink) | |
Member: 772096 Status: Offline Sonork: 100.69222 Thanks Meter: 8,277 | Quote:
I can do this if get modem in hands. | |
08-25-2016, 23:11 | #68 (permalink) | |
If you have 1-2 modems then forget, if have over 100 modems then send one two and get discount for unlock. about sending - via china u can send to russia. | |
08-29-2016, 07:24 | #71 (permalink) | |
10-11-2016, 22:18 | #74 (permalink) |
Junior Member Join Date: Sep 2010
Member: 1394646 Status: Offline Thanks Meter: 0 | I have unlocked the device using the unlock code , is there anyway possible that i can change the firmware to international version so that future issue regarding it getting locked may be avoided ? |
