GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares |
12-10-2016, 06:47 | #33 (permalink) | |
Major Poster Join Date: Oct 2006
Member: 364613 Status: Offline Thanks Meter: 3 | link not warking Quote:
link not warking plz upload to mediafire | |
12-10-2016, 06:59 | #34 (permalink) |
Insane Poster Join Date: Jul 2016
Member: 2599387 Status: Offline Thanks Meter: 5 | Hi, Carefully follow all the steps... and also the post 1 to 3.. But as i update the last firmware E5573cs_Update_21.318.03.00.00 it went into flash mode. My modem is e5573cs-322 not e5573cs-609 regards |
12-10-2016, 09:28 | #35 (permalink) | |
Major Poster Join Date: Jul 2013 Location: Nigeria
Member: 1970813 Status: Offline Sonork: kofi Thanks Meter: 24 | Quote:
Ur mobile wifi two light will go off as if it is DEAD but it is not!!! All u need to do is to flash it with the correct files and ur mobile wifi is unlock!!! U most first of all flash it with this E5573cs_Update_21.318.99.03.00!!! Now for the second file to flash must be this Update_WEBUI_17.100.15.01.356_MRE5!!! Then the last file to flash is the E5573cs_Update_21.318.03.00.00!!! And ur mobile wifi is unlock!!! U can use the dc-unlock to see ur mobile wifi and rewite ur IMEI | |
The Following User Says Thank You to sech444 For This Useful Post: |
12-10-2016, 10:20 | #36 (permalink) |
Member: 1970813 Status: Offline Sonork: kofi Thanks Meter: 24 | TRY THIS ALL FILES ARE HERE https://drive.google.com/open?id=0B0...3F2U3NIYTdpODQ |
The Following 2 Users Say Thank You to sech444 For This Useful Post: |
12-10-2016, 11:55 | #37 (permalink) | |
Member: 2599387 Status: Offline Thanks Meter: 5 | Quote:
All steps mention above are precise....as soon as the last file download finishes its reconnect and show single com port in device manager and detected in balong tool in flash mode. even i remove battery and put it back and power on it went directly into flash mode... Regards | |
12-10-2016, 14:41 | #38 (permalink) | |
12-10-2016, 18:18 | #41 (permalink) |
No Life Poster Join Date: Oct 2016 Location: Developer
Member: 2634133 Status: Offline Thanks Meter: 2,939 | stop make foolish to everyone if we not publish any file then you people not download anything from google google is not your home company you show our all data e5573cs-322 and e5573cs-323 loader and exe files you have 0% knowledge |
The Following User Says Thank You to balwinder27 For This Useful Post: |
12-10-2016, 18:20 | #42 (permalink) |
Member: 2634133 Status: Offline Thanks Meter: 2,939 | next time you see we block our all server website to your nigeria country then you say how you unlock latest models we not show any loader any exe then you telling |
12-10-2016, 21:22 | #43 (permalink) | |
not all can buy ur product pls let it go as u say i have no knowlage about it, so what is ur problem!!! | |
12-11-2016, 05:53 | #45 (permalink) |
Junior Member Join Date: Dec 2016
Member: 2659271 Status: Offline Thanks Meter: 0 | Please I have a problem, during bootshot I noticed the new device installing in task bar but after that I could not see the desired ports under device manager, I have tried bootshot like 6 times now still the same problem, the ports are not showing inn device manager. Also I can no longer view my Mifi Web UI like before again, when I connect the mifi to PC, the web UI is not loading again. My device is the MTN locked Huawei E5573Cs-322. Please help. What can I do to see the ports? How do I use the USB loader bin file? Help please I will appreciate if you can put me through the step by step, I have downloaded all the new files uploaded, how do I use them? When do I use each file at which step? The problem I have now is that I can not view the "Huawei 3G ports in device manager". I have tried more than 6 times already. When I double clicked on the USB loader bin file it was opened by my PC VLC player and nothing happened. Is this normal? How do I utilize the usb loader bin file? Thanks for your anticipated assistance. Last edited by Bossmd; 12-11-2016 at 06:02. |
