GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares |
12-24-2016, 22:03 | #76 (permalink) | |
Crazy Poster Join Date: Dec 2016 Location: Pakistan Age: 28
Member: 2661546 Status: Offline Thanks Meter: 9 | Quote:
12-24-2016, 22:06 | #77 (permalink) |
Member: 2661546 Status: Offline Thanks Meter: 9 | Hello bro, thanks for your reply but E5573Cs-322 won't start after flashing with 21.318.03.00.00 it stays in dead mode and the link you provided dont have firmware for e5573cs-322 so bro i think nothing could be done, any ways thanks for ur support. |
12-25-2016, 03:26 | #78 (permalink) | |
Major Poster Join Date: Jul 2013 Location: Nigeria
Member: 1970813 Status: Offline Sonork: kofi Thanks Meter: 24 | Quote:
Dev-Host - E5573Cs-322TCPU-21.318.03.00.00_Firmware_general_2.zip - The Ultimate Free File Hosting / File Sharing Service | |
The Following User Says Thank You to sech444 For This Useful Post: |
12-25-2016, 16:04 | #80 (permalink) |
Member: 2661546 Status: Offline Thanks Meter: 9 | Bro i had done as you said, first detect Boot 3g and load the usbloader-5573cs-322 in balong tool and two ports are installed and it goes into flash mode and blinking green lights and then flash with E5573cs_Update_21.318.99.03.00 and it says update successsful and detected as huawei modem and two green lights stay on, after that flash with Update_WEBUI_17.100.15.01.356_MRE5 and again green lights stay on and detected as huawei modem and it dont works but after flashing with E5573cs_Update_21.318.03.00.00 the two blinking lights stop and modem wont turn on and boot 3g will be detected in balong tool. it becomes dead in this step, and update wizard say error 21 retrieving information failed. sorry due to some error my screenshots are not getting posted |
12-26-2016, 18:43 | #81 (permalink) | |
Junior Member Join Date: Mar 2005 Age: 47
Member: 130828 Status: Offline Thanks Meter: 4 | Quote:
E5573cs_Update_21.318.03.00.00 always ends with error the Retrieving user information fails No lights but detected in Device manager and balong tool as 3g PC UI No wifi no other connectivity | |
12-27-2016, 06:46 | #82 (permalink) | |
12-27-2016, 21:27 | #83 (permalink) | |
selection : manufacturer - Huawei modems model - Auto detect (recommended) Found Applications port COM11 Found modem : E5573CS-322 Model : Huawei E5573 (untested) IMEI : 861xxxxxxxxxxx Serial NR. : DGxxxxxx Firmware : 21.318.99.03.00 Compile date / time : May 13 2016 11:45:50 Hardware ver. : CL1E5573CSM11 Ver.B Dashboard version : WEBUI_17.100.15.01.356_MRE5 SIM Lock status : unlocked Wrong codes entered : 0 (unlock attempts left : 10) Last edited by shah95; 04-13-2020 at 16:47. | |
12-28-2016, 08:18 | #85 (permalink) | |
Junior Member Join Date: Aug 2008
Member: 847260 Status: Offline Thanks Meter: 1 | wizard say error 21 retrieving information failed Quote:
Some time this error appear when u not inserted battery during the unlock method plz ensure battery in cloud. | |
12-28-2016, 19:42 | #87 (permalink) |
Member: 2661546 Status: Offline Thanks Meter: 9 | battery is always inserted bro, because it wont turn on without battery and it is full charged and still same error, I think the firmware package is not compatible with device. If anyone could find old firmware please post it. |
12-29-2016, 20:04 | #88 (permalink) | |
