11-09-2015, 12:51 | #4036 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Flash files count is :16 Action : Firmware update. Selected Alcatel: OT-4015D Exe version: NCKBox AndroidMTK 1.8.6.2 Scenario: Safe Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM4) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6572_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (29Gb+4096Mb) SAMSUNG 0x4e35585a4d42 EMMC FW VERSION: 01:00:00:00:00:00:00:00 EMMC CID: 1501004E35585A4D : 0000000000000000 EMMC UA SIZE: 0xe9000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9880000 [3.649 GB] Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : DA USB VCOM Port (COM5) Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Flash EMMC Algo Start. Starting flash. Download firmware to flash now... Wait untill phone will start charging. All done. |
11-09-2015, 13:02 | #4037 (permalink) |
Freak Poster Join Date: Aug 2013
Member: 1995502 Status: Offline Thanks Meter: 139 | PHONE: MF190 Port: ZTE NMEA Device (COM566) Build id: M6290A-KPRZL-2.4.0105T Compile Date: Aug 16 2010 Compile time: 09:50:51 Release date: Aug 12 2010 Release time: 10:00:00 Software: 8BD_MF190TLF3V1.0.0B03 IMEI: 359728035726796 Searching lock marker,wait. Simlock marker found, seems supported. Modem is locked.(1F40) Unlocking , wait.... Done. |
11-09-2015, 13:59 | #4038 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | j110h read unlock code done Code: PHONE SELECTED: SM-J100H Port: SAMSUNG Mobile USB Modem #5(COM22) Phone Detected. SM-J110H Model: SM-J110H Base: SM-N900 Version: J110HXXU0AOGA/J110HOJV0AOGB/J110HXXU0AOGA/J110HXXU0AOGA PRD: SM-J110HZBDKSA SN: R51G92HW7YZ IMEI: 353118076xxxxxx SIMLOCK:LOCKED[Phone May Be Hard Locked] Unlocking, wait. Reading locks, wait. Resetting Lock Codes... Done UnFreeze: 00712621 Net Lock: 83626762 For check lock use: *#7465625# -------------------------- Log saved to: logs\SM-J100H__unlock__3.txt |
The Following User Says Thank You to rehmani For This Useful Post: |
11-09-2015, 14:43 | #4039 (permalink) |
Member: 1995502 Status: Offline Thanks Meter: 139 | Port: 564 Model Selected : SM-G900F Reading Info, wait... IMEI: 359660061338008 Start unlock, wait.... Job done, if phone not restart, restart manually Total Time: 00:00:02 -------------------------- Log saved to: logs\SM-G900F_unlock__1.txt |
11-09-2015, 15:00 | #4040 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Alcatel OT-4037T Direct Unlock done... Selected connection metod: FLASH Mode Exe version: NCKBox AndroidMTK 1.8.6.2 Selected phone: OT-4037T Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MTK USB Port (COM61) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6582_S01 BaseBand CPU Secure Version : 05 BaseBand CPU Bootloader Version : 00 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (29Gb+4096Mb) SAMSUNG 0x4e35585a4d42 EMMC FW VERSION: 01:00:00:00:00:00:00:00 EMMC CID: 1501004E35585A4D : 0000000000000000 EMMC UA SIZE: 0xe9000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9880000 [3.649 GB] Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : DA USB VCOM Port (COM5) Block Size: 512 MODEL FROM PROINFO: 4037T-2BTBUS1 SECRO FROM PROINFO: X2C0UM04BF00 IMEI marker was found in nvram IMEI[1] from NVRAM: 45f5090d0e1e56a If this phone have OTP IMEI, this is normal. IMEI[2] from NVRAM: 45f5090d0e1e56a If this phone have OTP IMEI, this is normal. Reading security, wait... IMEI[1] : 014068001348839 SIM[1]: Block1(N): Locked (remain:1) Code : 2529838501 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked Unlocking target...please wait. Unlock finished. Wait untill phone will start charging. All done. |
11-10-2015, 05:52 | #4041 (permalink) |
Registered User Join Date: Jul 2013 Location: Harare
Member: 1972271 Status: Offline Sonork: zwanaz Thanks Meter: 164 | Model Selected : GT-I5500 Start Reading Info.. Model : GT-I5500 Product code : I5500XWJQ3 Version : I5500XWJQ3/I5500H3GJP2/I5500NEJP2 Imei : 35479604623348 Bypass MSL Need... Bypass MSL done.. Start Direct Unlocking.. Direct Unlock done . Wait untill phone restart... Total Time: 00:00:06 -------------------------- |
11-10-2015, 14:09 | #4043 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bangladesh
Member: 387110 Status: Offline Sonork: Not Use Thanks Meter: 630 | HUAWEI Y530-U051 Unlock Done Code: Phone must be on, USB debugging must be enabled. If Phone ask for SU, allow. Found Device, reading info.. Brand: Huawei Model: HUAWEI Y530-U051 Build ID: HuaweiY530-U051 Platform ID: msm8610 OS version: 4.3 Build version: Y530-U051V100R001C451B191 SU binary present. Starting unlock, wait... Using metod 1. Reading simlock info, wait.... SIMLOCK[0]: Locked SIMLOCK[1]: Unlocked SIMLOCK[2]: Unlocked Unlocking phone.... Write simlock succes. Restarting phone, wait..... If phone not restarted, please restart manually . All done. |
The Following User Says Thank You to Dilip_Nath For This Useful Post: |
11-10-2015, 19:43 | #4044 (permalink) | |
No Life Poster Join Date: Apr 2013 Location: Uzbekistan / Bukhara
Member: 1912005 Status: Offline Sonork: 100.1658592 Thanks Meter: 623 | UZTE Grand V7 Direct unlock done (phone locked to Beeline Uzbekistan ) Quote:
The Following User Says Thank You to UzUnlocker For This Useful Post: |
11-12-2015, 00:50 | #4045 (permalink) | |
No Life Poster Join Date: Nov 2003 Location: GT
Member: 44659 Status: Offline Thanks Meter: 363 | Alcatel OT-4015T AT&T (may be needed to enter the code twice) ... Quote:
The Following User Says Thank You to luzer For This Useful Post: |
11-12-2015, 08:19 | #4046 (permalink) |
Freak Poster Join Date: Sep 2014 Location: philippines
Member: 2256970 Status: Offline Thanks Meter: 67 | G526-L11 unlock failed in other tool but one click in nckbox Phone must be on, USB debugging must be enabled. If Phone ask for SU, allow. Found Device, reading info.. Brand: Huawei Model: G526-L11 Build ID: HuaweiG526-L11 Platform ID: msm8960 OS version: 4.1.2 Build version: G526-L11V100R001C294B197 SU binary present. Starting unlock, wait... Using metod 1. Reading simlock info, wait.... SIMLOCK[0]: Locked SIMLOCK[1]: Unlocked SIMLOCK[2]: Unlocked Unlocking phone.... Write simlock succes. Restarting phone, wait..... If phone not restarted, please restart manually . All done. |
The Following User Says Thank You to Naps For This Useful Post: |
11-12-2015, 16:12 | #4047 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Vodafone 695 Direct Unlock done.. Selected connection metod: FLASH Mode Exe version: NCKBox AndroidMTK 1.8.6.2 Selected phone: Vodafone 695 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM4) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6572_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (29Gb+4096Mb) MICRON 0x50314a39344d EMMC FW VERSION: 12:00:00:00:00:00:00:00 EMMC CID: FE014E50314A3934 : 0000000000000000 EMMC UA SIZE: 0xe9800000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9b00000 [3.651 GB] Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : DA USB VCOM Port (COM5) Block Size: 512 MODEL FROM PROINFO: V695-2AVDGB2 SECRO FROM PROINFO: X8I0HE01AZ10 IMEI marker was found in nvram IMEI[1] from NVRAM: 45f5090d0e1e56a If this phone have OTP IMEI, this is normal. IMEI[2] from NVRAM: 45f5090d0e1e56a If this phone have OTP IMEI, this is normal. Reading security, wait... IMEI[1] : 357773066164394 SIM[1]: Block1(N): Locked (remain:6) Code : 34798774 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked Unlocking target...please wait. Unlock finished. Wait untill phone will start charging. All done. |
11-12-2015, 20:38 | #4048 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Flash files count is :16 Action : Firmware update. Selected Alcatel: OT-4033X Exe version: NCKBox AndroidMTK 1.8.6.2 Scenario: Safe Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM4) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6572_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (29Gb+4096Mb) SAMSUNG 0x4e35575a4d42 EMMC FW VERSION: 01:00:00:00:00:00:00:00 EMMC CID: 1501004E35575A4D : 0000000000000000 EMMC UA SIZE: 0xe9000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9480000 [3.645 GB] Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : DA USB VCOM Port (COM5) Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Flash EMMC Algo Start. Starting flash. Download firmware to flash now... Wait untill phone will start charging. All done. |
11-13-2015, 10:48 | #4049 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Alcatel OT-4035X Direct Unlock done in Flash Mode... Selected connection metod: FLASH Mode Exe version: NCKBox AndroidMTK 1.8.6.2 Selected phone: OT-4035X Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM4) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6572_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (29Gb+4096Mb) HYNIX 0x483447316404 EMMC FW VERSION: 05:00:00:00:00:00:00:00 EMMC CID: 90014A4834473164 : 0000000000000000 EMMC UA SIZE: 0xe9000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9c00000 [3.652 GB] Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : DA USB VCOM Port (COM5) Block Size: 512 MODEL FROM PROINFO: 4035X-2GVRGB1 SECRO FROM PROINFO: X9H0CG03AN10 IMEI marker was found in nvram IMEI[1] from NVRAM: 45f5090d0e1e56a If this phone have OTP IMEI, this is normal. IMEI[2] from NVRAM: 45f5090d0e1e56a If this phone have OTP IMEI, this is normal. Reading security, wait... IMEI[1] : 863657022658564 SIM[1]: Block1(N): Locked (remain:10) Code : 22418052 Block2(NS): Unlocked Block3(SP): Locked (remain:10) Code : 01624114 Block4(C): Unknown[2] Unlocking target...please wait. Unlock finished. Wait untill phone will start charging. All done. |
The Following User Says Thank You to razib143 For This Useful Post: |
11-13-2015, 12:48 | #4050 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Vodafone Smart 4 Turbo Unlock code read done.. Coolpad Android Diagnostics USB VCOM (COM130) detected. Build id : GWL_T3_1013901_01 Version info : May 19 201417:05:18Apr 21 201406:00:00DAAAANAZ* ÿd IMEI : 353853060817462 Start reading.. Backup saved to : C:\Documents and Settings\Dell_Laptop\My Documents\NckBox\backup\coolpad_android\3538530608 17462_simlock_backup_1.bin Simlock Status: SIMLOCK[1] Locked: Counter[10] SIMLOCK[2] Unlocked SIMLOCK[3] Unlocked SIMLOCK[4] Unlocked SIMLOCK[5] Unlocked Code: 29206501 Read Info End. |
