11-24-2015, 19:35 | #4081 (permalink) |
Freak Poster Join Date: Jul 2014 Location: Haiti
Member: 2216186 Status: Offline Sonork: 100.1668130 Thanks Meter: 120 | Port: ALCATEL HS-USB Diagnostics 9002 (COM167) Build id: MPSS.TR.2.0.c13-00017-M8610BAAAANAZM-1 Compile Date: Dec 12 2014 Compile time: 13:49:42 Release date: Nov 26 2014 Release time: 01:00:00 IMEI: 014316000579064 Backup saved to: xxxxx Simlock Status: SIMLOCK[0] Locked: Counter[1] SIMLOCK[1] Unlocked SIMLOCK[2] Locked: Counter[3] SIMLOCK[3] Unlocked SIMLOCK[4] Unlocked Start direct unlock, wait.... Direct unlock done. Please restart phone. |
The Following User Says Thank You to diph001 For This Useful Post: |
11-25-2015, 01:20 | #4082 (permalink) | |
No Life Poster Join Date: Nov 2003 Location: GT
Member: 44659 Status: Offline Thanks Meter: 363 | ZTE R259 reset user code ... Quote:
The Following User Says Thank You to luzer For This Useful Post: |
11-25-2015, 07:38 | #4083 (permalink) |
No Life Poster Join Date: Nov 2010
Member: 1450664 Status: Offline Thanks Meter: 168 | world first zte f286 optus unlock done thx nck box team for hard work Now Power on the phone without the SIM card installed Enter * 983 * 8284 # (a prompt will appear to enter a password) Enter the calculated code (NCK only) and choose OK Power off the phone and install any non-optus SIM card Restart the device |
11-25-2015, 08:25 | #4084 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Albania,City Under The Castle Age: 47
Member: 388033 Status: Offline Thanks Meter: 693 | SGH T139 Unlocked As SGH T239!!! COMPORT : COM8 Selected : SGH-T239: SYSOL Press and keep Power ON!!! Boot OK. Loading Preloader, keep press power on. Send Preloader OK. Flash ID: 0008 Flash Name: K5N5629ATA_TOP Try Change BaudRate. Loading Mainloader.. Send Mainloader ok. Reading Eeprom Data.. Analyzing Data.. Parsing eeprom, wait. - Imei : 3551660564XXXXX Code[1] Found: 31545700 Master Unfreeze: 60399730 Done. |
11-25-2015, 18:18 | #4085 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Alcatel OneTouch Pixi 3 4009X Permanent Locked Direct Unlock done in flash mode.. Selected connection metod: FLASH Mode Exe version: NCKBox AndroidMTK 1.8.6.2 Selected phone: OT-4009X Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM4) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6572_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (29Gb+4096Mb) SAMSUNG 0x464a32354142 EMMC FW VERSION: 02:00:00:00:00:00:00:00 EMMC CID: 150100464A323541 : 0000000000000000 EMMC UA SIZE: 0xe9000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9880000 [3.649 GB] Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : DA USB VCOM Port (COM5) Block Size: 512 MODEL FROM PROINFO: 4009X-2AE8GB1 SECRO FROM PROINFO: X4B0CG05AZ10 IMEI marker was found in nvram IMEI[1] from NVRAM: 45f5090d0e1e56a If this phone have OTP IMEI, this is normal. IMEI[2] from NVRAM: 45f5090d0e1e56a If this phone have OTP IMEI, this is normal. Reading security, wait... IMEI[1] : 356868062425343 SIM[1]: Block1(N): Locked (remain:0) Code : 7554388088180834 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked Unlocking target...please wait. Unlock finished. Wait untill phone will start charging. All done. |
11-26-2015, 07:44 | #4086 (permalink) |
No Life Poster Join Date: May 2008 Location: pakistan pir mahal Age: 53
Member: 779470 Status: Offline Sonork: Waseem mobile Thanks Meter: 101 | Qmobile s1 mt6582 android 5.0 done Selected connection metod: Meta Connection Exe version: NCKDongle AndroidMTK 2.5.6.0 Selected phone: MT6582 Action : IMEI REPAIR. IMEI for write : 353030078228??? Scanning for presents meta ports... Meta ports not detected, starting brom stage. Curent Platform: MT6582 Phone must be off with battery inside. Please insert USB cable now... Detected(8) : MediaTek PreLoader USB VCOM (Android) (COM8) Starting META mode, wait... Restarting, wait.... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. META Port Detected[10] MediaTek USB VCOM (Android) (COM10) USB\VID_0E8D&PID_2006&MI_02\6&38BA29F&0&0002 Start sync target, waiting responce..... BaseBand CPU : MT6582, E01 SW_VER : MOLY.WR8.W1449.MD.WG.MP.V1.P3 HW_VER : TINNO6582_WT_L_HSPA_HW Meta mode conected ok, start reading phone.... IMEI to repair: [2] 353030078228??? IMEI repair OK. Clean Boot flag ok. All done. |
11-26-2015, 07:54 | #4087 (permalink) |
Freak Poster Join Date: Jan 2008 Location: philippines
Member: 669596 Status: Offline Sonork: 1657504 Thanks Meter: 136 | Huawei U8500 Unlocked DONE.... Code: Now connect phone to PC Start detect phone. Injecting Loader.. Reconnecting phone, this can take few second.. Start detect phone. Loader started ok. Reading Phone Info, please wait.. Phone Imei : 35302---------- Phone SN : 7XA7NC11A1400051 Phone Firmware : U8500V100R001C00B669_EFS SimLock marker found.. Total markers found : 1 Simlock Status : Unlocked |
The Following User Says Thank You to -=C.J.S=- For This Useful Post: |
11-26-2015, 08:00 | #4088 (permalink) |
Member: 779470 Status: Offline Sonork: Waseem mobile Thanks Meter: 101 | Qmobile s1 mt6582 android 5.0 read flash done Qmobile s1 mt6582 android 5.0 read flash done with nck |
The Following User Says Thank You to waseem pirmahal For This Useful Post: |
11-26-2015, 15:26 | #4089 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | samsung g361 frpreset done Code: Device detected OK: Modem (COM48) Bypassing data, wait.... Bypass ok. Reading Data,wait.... Done Chipset: SPRD8735 Checking, wait..... Data Found, processing... Resetting FRP, wait.. FRP OFF... Done Now you can wipe phone to remove remaining data... Restarting Phone Restart Ok All Done Done. -------------------------- Log saved to: logs\SM-G361H_frp_reset__1.txt |
11-26-2015, 15:28 | #4090 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | samsung g360h unlock done Code: PHONE SELECTED: SM-G360H Port: SAMSUNG Mobile USB Modem #3(COM34) SM-G360H Model: SM-G360H Base: SM-N900 Version: G360HDDU0AOB1/G360HOJV0AOB2/G360HDDU0AOD4/G360HDDU0AOB1 PRD: SM-G360HZWDKSA SN: R51G607BL3P IMEI: 3596560678 SIMLOCK:LOCKED[Phone May Be Hard Locked] Unlocking, wait. Reading locks, wait. Resetting Lock Codes... Done UnFreeze: 00712621 Net Lock: 83626762 For check lock use: *#7465625# -------------------------- Log saved to: logs\SM-G360H__unlock__1.txt Done. |
11-28-2015, 12:16 | #4091 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | mts m151 repair meid done Code: Module Ver. : 3.1 Com Port : COM73 : Qualcomm HS-USB Diagnostics 9004 (COM73) Baud Rate : 921600 Device : Karbonn B121 Operation : Write MEID Port Opened. Reading Phone Information... Compile : Jan 15 2015 21:01:24 Release : Apr 24 2010 23:00:00 Hw Ver. : W027_KK9 ESN : 00000000 MEID : 00000000000000 Build : Q1110-W027_KK9A_M151_MTS-3375 Trying to Write MEID [A100003FAA793D]... New ESN : 8019 New MEID : A100003FA Operation finished. Port Closed. Elapsed Time: 00:01 |
11-28-2015, 12:19 | #4092 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | ec315 repair meid and unlock done repair meid Code: Module Ver. : 3.1 Com Port : COM24 : FC - Application Interface (COM24) Baud Rate : 921600 Device : Huawei EC315 Operation : Write MEID Port Opened. Reading Information... Compile : Sep 11 2013 11:32:05 Release : Mar 12 2011 12:00:00 Hw Ver. : SCAUTHZ3 ESN : 00000000 MEID : 00000000000000 Hw. Type : EC315-1CE1EC315M Ver.A Firmware : 11.102.99.55.00 Dashboard : HiLink12.001.10.04.656 Calculating Flash Code... Flash Code : 34528025 Reading Lock Status... Lock Status : Locked RUIM Mode : RUIM Only Trying to Write MEID [A0000049E ]... Trying Security Unlock Method 1... Trying Security Unlock Method 2... New MEID : A0000049 Operation finished. Port Closed. Elapsed Time: 00:01 unlock done Code: Module Ver. : 3.1 Com Port : COM24 : FC - Application Interface (COM24) Baud Rate : 921600 Device : Huawei EC315 Operation : Unlock Opening Port... Reading Information... Compile : Sep 11 2013 11:32:05 Release : Mar 12 2011 12:00:00 Hw Ver. : SCAUTHZ3 ESN : 8069 MEID : A000004 Hw. Type : EC315-1CE1EC315M Ver.A Firmware : 11.102.99.55.00 Dashboard : HiLink12.001.10.04.656 Calculating Flash Code... Flash Code : 38071795 Reading Lock Status... Lock Status : Locked RUIM Mode : RUIM Only Unlocking Modem, Please wait... Modem Successfully Unlocked. No need to change RUIM Mode, Skipped! Operation finished. Port Closed. Elapsed Time: 00:01 |
11-28-2015, 12:22 | #4093 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | zte s1602 repair meid done Code: Module Ver. : 3.1 Com Port : COM85 : ZTE CDMA Handset Diagnostics Interface (COM85) Baud Rate : 921600 Device : C132 Operation : Write MEID Port opened. Compile : Apr 12 2011 11:09:05 Release : Apr 24 2009 24:00:00 Hw Ver. : CTYXK_S1 ESN : 00000000 MEID : 00000000000000 MemUnlock : Failed! Build : CTYXK_S193_RNTN01NV1.0.0B04 Detected : CTYXK_S1 User Code : 0000 Writing MEID A1000020D Write success. New ESN : 8029 New MEID : A1000020 Operation finished. Port closed. Elapsed Time: 00:01 Log saved as \!Log\LOG_15_11_28_16_51_17.log |
11-28-2015, 12:47 | #4094 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | samsung b159 unlock done Code: Module Ver. : 3.1 Com Port : COM87 : SAMSUNG HSP Plus Modem Driver Baud Rate : 921600 Device : Samsung B159 DE28 Operation : Unlock Port opened. Preparing phone... Phone prepared. Erasing security area... Erase finished. Patching security area... Operation finished. Port closed. Elapsed Time: 00:01 Log saved as \!Log\LOG_15_11_28_17_00_23.log |
11-28-2015, 15:06 | #4095 (permalink) |
Insane Poster Join Date: Sep 2009 Location: in your phone
Member: 1112784 Status: Offline Thanks Meter: 2 | Exe Version: NCKdongle v17.3 IMEI checksum seems ok Brand: Alcatel android Model: OT-4030A IMEI :013459007737060 Connecting to server please wait... PID: C9JM3 SECRO: XHE0OP01 NCK: 29379506-92 NSCK: 34960019-05 SPCK: 36006275-98 CCK: 35739204-33 CPCK: 27767991-20 Some phones use 8 digits codes, some use 10 digits codes. PID: C9JM3 SECRO: XHE0OP00 NCK: 29379506-92 NSCK: 34960019-05 SPCK: 36006275-98 CCK: 35739204-33 CPCK: 27767991-20 Some phones use 8 digits codes, some use 10 digits codes. |
