Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 09-30-2010, 14:13   #121 (permalink)
ssa
ssa's Avatar
Member: 23420
Thanks Meter: 3,080
you need to know the algo how the hashed code is build, you need to decrypt the values from the phone, you need to make phone loaders etc etc
cracking a computer program is something totaly different..
if you have no or little experiance in gsm programming and functioning.. i would say i give you no chance you can do this
The Following User Says Thank You to ssa For This Useful Post:
Old 10-13-2010, 15:20   #122 (permalink)
coolvenom's Avatar
Member: 345321
Thanks Meter: 37
TNAX BUT I WILL.LOL...
The algorithms used in earlier Nokia brand phones (based on IMEI and MCC code) have been reverse-engineered, stolen or leaked, resulting in many people offering Nokia unlock codes for free or for a fee. The algorithms used in earlier Nokia brand phones (based on IMEI and MCC code) have been reverse-engineered, stolen or leaked, resulting in many people offering Nokia unlock codes for free or for a fee.
HENCE A RANDOM NUMBER CHOSEN!!!!!!!!!!!EASY
Old 10-13-2010, 17:12   #123 (permalink)
Member: 607934
Thanks Meter: 6
As far as i know the counters of SL3 phones can be reset. So just an idea, a small program which is brute-forcing the phone with unlock codes and then resets the counter and continue brute-forcing.....and again...
Old 10-28-2010, 03:42   #124 (permalink)
Member: 512970
Sonork: 100.1584185
Thanks Meter: 134
The bb5 any system lock ned the hash foldes decrypt befor show to calcule valeur and after u have manny jobs for mack code rsa that if you have big experiens in this system programation gsm my thnxx to old master dejan in this system phonix loader and aplication manny solution by dejan testpoin for dercypt and crack valeuR
Old 10-28-2010, 05:28   #125 (permalink)
Member: 1144205
Thanks Meter: 75
whycan not the firmware hacker nokia is only one thing you need is to reverse the algorithm to find the nck, on the pc it is easier to find the truth and the msgbox I think nokia would be something like looking for the conditional jump or flag z if active or wrong nck. if we talk about nokia thing you need is to know everything about the arm and the type of microcontroller that is rap or omap right? Mirren is at sec and find the check in wachtbog and rap while doing a chip change at runtime with some jtag. or learn to think in arm asembly
Old 10-30-2010, 03:52   #126 (permalink)
boucettay's Avatar
Member: 148814
Sonork: 100.1576882
Thanks Meter: 5,012
Originally Posted by shadab_a4u View Post
In case you are right, then why Cyclone cant provide more slots to submit unlocking Job?
Where UB has not restricted Job submission?
Also why some teams are very slow than other in calculation?
One more thing, if this all takes place at DM3 then other teams dont need to setup such powerfull servers to handle jobs.
Br,
Shadab Ahmad
and why not all hash are supported...
and why....
SL3 unlock have relation with DK...and DM3 is the only and unique solution supporting all models/hashes (almost).
perhaps if karwos+alex+.... work together, a solution will be found, at least to support more hashes, and finally we'll be able to unlock sl3 in our shop, and a little faster...
Even I prefer the actual situation than a standalone free solution...
and better if a TP solution, that will be great
WBR
The Following 3 Users Say Thank You to boucettay For This Useful Post:
Old 10-30-2010, 16:54   #127 (permalink)
Member: 457470
Thanks Meter: 159
and why....
WBR
teams have solution to unlock 6700 etc. but they are not supporting it coz
the solution for that unlock is easy and they are afraid of the solution being
cracked. so not release as many models as DM3
Old 11-06-2010, 02:55   #128 (permalink)
boucettay's Avatar
Member: 148814
Sonork: 100.1576882
Thanks Meter: 5,012
Just keep eyes on Forum...!
and hope not for long, something new
WBR,
Old 11-06-2010, 04:28   #129 (permalink)
eyestrain's Avatar
Member: 237911
Thanks Meter: 632
why zulea having a problem of reversing this method
we all know he is one of the best coder...
is that because he is being blocked by the gsm coder on sonork or YM because of what happen with mxkey?
as i was reading i have learned a lot of things regarding sl3 NCK calculation...
but we still want the exact knowledge how the calculating are being process...
Old 07-28-2011, 14:52   #130 (permalink)
sniper007's Avatar
Member: 722656
Sonork: 100.1584918
Thanks Meter: 294
What about the supercomputer for calculating the codes. can someone give me an idea on the list of parts to assemble such a computer and what we need to do to calculate sl3 unlocking codes. I am planing to setup a system as i have lots of trade customers and I am sure we will receive lots of phones.
thanks in advance for your advice and help
Old 07-28-2011, 19:34   #131 (permalink)
Member: 972745
Sonork: 100.1627715
Thanks Meter: 216
Can we not exploit the ram or something i mean when we enter a code the phone must perform a check tosee whether its correct or not right? can we exploit in this in some way? maybe wen enter code it gts pusdh in to ram or something :S
Old 07-29-2011, 05:42   #132 (permalink)
..:: Devil_king ::..'s Avatar
Member: 696623
Sonork: 100.1601050
Thanks Meter: 526
Cracking an MD5
There are a few different ways that you can crack an MD5 hash but they all revolve around the same technique. Because the hash cannot be reversed, the only way to crack it is to encrypt text and then compare it against the hash. A couple examples would be:
- Dictionary Attack (Where the cracker has a set password list and they have a program encrypt and compare these hashed passwords).
- Brute Force Attack (Where the cracker will begin encrypting all possible text combinations in order to compare them against the hash. This will take around a few thousand years unless you have a super computer. The amount of possible passwords for a password up to ten digits is 35^10.
Old 09-22-2011, 19:27   #133 (permalink)
Member: 1639595
nokioteca.net/home/forum/index.php/forum/209-product-codes-nokia/page__prune_day__100__sort_by__Z-A__sort_key__title__topicfilter__all__st__150
get code free
The Following User Says Thank You to snkhan120 For This Useful Post:
Old 09-28-2011, 19:49   #134 (permalink)
mchizan's Avatar
Member: 505345
Thanks Meter: 11
The site is giving product codes, could that be a key to unlocking?!
Help: Forgot my 6110 user lock code!! GByte9 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 02-26-2016 14:52
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-16-1999 08:41
Page generated in 0.31994 seconds with 9 queries
