GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2006 Location: .: India :. Heaven on Earth
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | ![]() I am just curious to know how SL3 Unlock Code calculation works. As in some boxes there is option to submit request by imei only. So the question is: > What data is needed to calculate unlock code? > Why unlock code calculation takes too much time? In short, if somebody can tell us the procedure involved in code calculation. Br, Shadab Ahmad |
![]() | #4 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2005 Location: Rome , Italy
Member: 190882 Status: Offline Sonork: BB PIN: 7C83D9CE Thanks Meter: 1,282 ![]() | Brute force SHA-1 of Truncated 15 digit-code + RND + IMEI until getting a match from the decrypted hash entries in PM 120. original post of x-shadow http://forum.gsmhosting.com/vbb/f609...0/#post6159636 |
The Following 4 Users Say Thank You to fr3nsis For This Useful Post: |
![]() | #5 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2009 Location: Europe Wienna
Member: 984046 Status: Offline Thanks Meter: 256 | Quote:
I forgot that post was in sub-forum where it shoud be. (Spent last 20 mins looking for it.) BR Haltec | |
![]() | #6 (permalink) |
Member: 984046 Status: Offline Thanks Meter: 256 | And what truncated mean in this context? Is it "Delphi" Trunc ? As discarding evriting behind floating point, or...? (ah, long time ago was that Turbo Pascal) Why RND? (not Random..., I presume?) BR Haltec |
![]() | #7 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2006 Location: ..::DZ-25::..
Member: 315181 Status: Offline Sonork: 100.1593455 Thanks Meter: 301 | can someone explain more this Truncated 15 digit-code +RND ?? truncate you mean this ? ![]() Last edited by angel25dz; 08-24-2010 at 21:41. |
![]() | #8 (permalink) | |
Crazy Poster ![]() ![]() ![]() Join Date: Apr 2008 Location: in your GALAXY
Member: 759444 Status: Offline Thanks Meter: 19 | And this is what BPH had posted about RND value: Quote:
Br, dualtrace | |
![]() | #9 (permalink) | |
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | Quote:
Br, Shadab Ahmad | |
![]() | #10 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2006 Location: APPLE i Center Age: 40
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | i think they are manually Generating the Unlock codes from Phone IMEI ,so why it took too much time for Generate an unlock codes for a single phone. |
![]() | #11 (permalink) | |
Cheater -Don't Deal with him- ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2004 Location: MicroControllers:: Age: 44
Member: 78619 Status: Offline Thanks Meter: 297 | Quote:
for time with ordinary or lower speed or less in numbers u have data processing units it must take long time to finish jobs.. as said above nokia use random numbers so they have to bruteforce the data for greater numbers of times to get exact match.. correct me if am wrong.. ![]() | |
![]() | #12 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2006 Location: Karachi, Pakistan Age: 34
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,593 | Quote:
All tool gets PM120 also with imei. Because SHA-1 sign is in PM120,2(decrypted hash entries i think so..) ![]() And they also modify loaders "RAPIDOv11" old hack ![]() ![]() BUT there are some new rapido single asic phones with (hash 479C), i am thought Nokia have fixed all bugs in it and it has high security..! There should be other method to unlock this phone instead bruteforce :-) or I could be wrong. BR | |
![]() | #14 (permalink) | |
I think no. It does not depend on MCC, MNC! They generates level7 codes which removes all restriction in phone. So, no matter which level phone is locked to. If any phone does not accept level7 code or phone is not locked to appropriate level then in this case is not possible to unlock phone with generated level7 code. - Telcel Maxico phones ![]() BR | |
The Following 2 Users Say Thank You to ..::Angel::.. For This Useful Post: |
![]() | #15 (permalink) | |
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | ![]() Quote:
Does this mean: > Need to make every possible 15 digit code. > Use Random number from 0-1000. > After adding both (dont know if it is simple addition), add IMEI. > Now compare SHA-1 of this value to the value stored in PM120-2 Am I right? or I need more mind power to understand it? ![]() Br, Shadab Ahmad | |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
