GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
04-09-2011, 20:15 | #16 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Guangzhou-China
Member: 468587 Status: Offline Sonork: 100.1612429 Thanks Meter: 681 | Quote:
Code: Mastersp = 065222098608403 = 0605020202090806080403 Saved as:356918031143509.cod [IMEI] 356918031143509 [HASH] 8D1C71F10A3F36FAFCFEB60B8B3D10E341E4B78D [MASTERSP] 0605020202090806080403 [SPCodes] #pw+126673811028371+1# #pw+496488505802080+2# #pw+036354749939345+3# #pw+270409004584725+4# #pw+873365185473830+5# #pw+352514663105275+6# #pw+415369813640620+7# saved as : 356918031143509_SPCodes.txt end; end. Best Ragards. Mourad. Last edited by MOURAD™; 04-09-2011 at 20:23. | |
04-13-2011, 16:26 | #17 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Hell
Member: 679176 Status: Offline Sonork: 1585224 Thanks Meter: 119 | 5230 Asic ID : 000000010000022600010006400C192101051103 Public ID : 09D000195C4C0052361BB18066BD07986282618E Hash : 479C6DDE3942E12C429C1D6ADED80371 Hardware ID: 400C192101051103 from this info how is look a log file can someone learn me?? |
04-15-2011, 18:59 | #18 (permalink) |
Freak Poster Join Date: Jun 2003 Location: www.elektronika-s.hr Age: 53
Member: 30623 Status: Online Thanks Meter: 68 | Does someone tried to make this optimization for SL3 with the http://www.zorinaq.com/talks/breaking-unix-crypt.pdf |
04-17-2011, 21:38 | #19 (permalink) |
Freak Poster Join Date: Aug 2004 Age: 36
Member: 78543 Status: Offline Sonork: 100.1603369 Thanks Meter: 25 | SL3 is using SHA1, thing you posted is something else. Anyway, don't worry about optimization for SL3 I'm sure when there comes something new, everyone will talk about it. |
07-25-2012, 12:00 | #20 (permalink) |
Junior Member Join Date: Jul 2012
Member: 1789379 Status: Offline Thanks Meter: 0 | Hello I'm a bit lost I've tried reading tutorials and guides but still this is something very new to me. What I want is using Cyclone Box read the hash and the codes needed to do Bruteforce with ighashgpu. With Cyclone I get a lot of .bat files and for Ighashgpu I only need to enter a command line. I got: imei=351539041897580 hash=005DE892A9E68469F40507AB5E217E365A7E8001902CB 11B74958F5213F030E03A6F52CC45A15E252BC808510EEDE5B 4486407F2401F1044E3E4837336DCE3CD50146461288B1CBDE 47C1508805DF528373A3B13E8EC4BF2A9B7A254ED570095AB1 C44F0D8546753DDD63CE57521E69FE8938AD12371E465AA68C 97E029722490594AF0E7717DF53039F63026C7AF6EF82E12FF 069311C81ACD0EAD806590798 And im trying this command in ighashgpu: ighashgpu -t:sha1 -salt:351539041897580 -h:005DE892A9E68469F40507AB5E217E365A7E8001 -uh:00010203040506070809 -min:15 -max:15 pause But it´s not working, I've read I have to use this format: ighashgpu -t:sha1 -salt:00[imei]00 -h:[hash] -uh:00010203040506070809 -min:15 -max:15 But the -uh:[] it's always the same or I have to put a code I retreived from Cyclone? Sorry I know I'm very lost I'm trying to learn if you could give me a hand with the right command for ighashgpu I would really appreciate it. Thank you |
08-12-2012, 20:44 | #21 (permalink) |
Crazy Poster Join Date: Jul 2002 Location: a coruña, spain Age: 47
Member: 13445 Status: Offline Thanks Meter: 11 | Hello! probably your [imei] its incorrectly 15 bytes long. its only 00[14-bytes-imei]00 the .bat files are the correct command line ready to run with oclhashcat-lite, which is as speedy as ighashgpu (or maybe more ) |
08-03-2014, 16:29 | #22 (permalink) |
Junior Member Join Date: Aug 2014
Member: 2233872 Status: Offline Thanks Meter: 0 | Hi guys, I have problem too. data from SL3 Code: imei=359368039532427 hash=F38E8DF3D94F9EF83AC6723D9375655286FADEA848AC20AAB99482C897FF990CD94EE12DCD3B96549FD5B75482E81FE1C0A0FE5851543DE4E90061DCAD63358F3BE705FDC0042E622791631B1131D073F7E8538DA94994341C0A2B11E975D0C6DD62279CFF37FE3538BE71D56AB5DF9BFD089F3FA393DEB8164D1672B7E7B3D845C650404D07C43C8DFA34C537D99408CCAAB1B72E3A905564512FB190B698C4 model=RM-504 ver=1510 ticket=0EFAFA74D9BFB6C2DCD7E558A91541F8958D1EF8 Code: ighashgpu -t:sha1 -salt:003593680395324200 -h:F38E8DF3D94F9EF83AC6723D9375655286FADEA8 -uh:00010203040506070809 -min:15 -max:15 Code: C:\Users\lacik_000\Desktop\ighashgpu_v0.80.16.1>ighashgpu -t:sha1 -salt:0035 93680395324200 -h:F38E8DF3D94F9EF83AC6723D9375655286FADEA8 -uh:00010203040506070 809 -min:15 -max:15 **************************************************************** *** MD4/MD5/SHA1 GPU Password Recovery v0.80.16.1 *** *** For ATI RV 7X0 cards and nVidia 'CUDA' ones (G80+) *** *** (c) 2009-2010 Ivan Golubev, *** *** *** **************************************************************** *** Any commercial use of this program is strictly forbidden *** **************************************************************** Found 1 CUDA device(s) Starting brute-force attack, Charset Len = 10, Min passlen = 15, Max passlen = 1 5 Charset (unicode -> 0) [] Charset in HEX: 00 01 02 03 04 05 06 07 08 09 Starting from [] Hash type: SHA1, Hash: f38e8df3d94f9ef83ac6723d9375655286fadea8 Salt: 00 35 93 68 03 95 32 42 00 Device #0: [GeForce GTX 560 Ti] 1800.00 Mhz 256 SP Hardware monitoring disabled. CURPWD: ??????????????? DONE: 00.00% ETA: 25d 20h CURSPD: 447.6M |
10-13-2015, 20:46 | #27 (permalink) | |
Major Poster Join Date: Jul 2014 Location: Romania
Member: 2216077 Status: Offline Thanks Meter: 5 | hy. can someone help me with : Quote:
3310 problem display disappears after input pin | simonb | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 01-09-2009 10:37 |
how to input unlock code??? | skedone | Infineon C16X M51 & ARM7 M52 BASED | 1 | 08-07-2002 11:45 |
How to input nck by keyboard? | ren777 | Mitsubishi | 2 | 02-16-2002 15:47 |
restore T9 text-input siemens S35 | baronx | x1x to x45/x50 | 0 | 01-03-2002 23:16 |
Nck input problems, on mc9224.1m | dollyb | Infineon C16X M51 & ARM7 M52 BASED | 0 | 04-05-2001 21:27 |
