08-08-2017, 10:14 | #16 (permalink) |
No Life Poster Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 535 | Samsung SM-J200H (J2 3G DS) at USB (COM75) [LOKE FLASH] {Reset FRP} PLATF: LOKE 00020000 PIT Read Done: 00:00 Reset FRP Done in: 00:00.437 Error: Close LOKE: 8, FFFFFFFF |
08-09-2017, 04:39 | #19 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Colombia
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | can add reset frp for motorola mtk mr sha MTK MT6737M (eMMC) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM38 BR Asic Id: MT0335 [0000] >> MT6735 BR Asic Sw: 8A00 CB00 0000 0000 BR Secured: 5 DA Version: MTK_AllInOne_DA_v3.3001.00.00 Auth File not Defined BR_BOOT Error: -12 Reset FRP Failed: -12 DA Shutdown Done, Disconnect Cable |
08-09-2017, 07:35 | #22 (permalink) |
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | try to write xt1756 by ufst, you have da for this model MTK MT6737M (eMMC) at USB Auto Select [MTK] {Write Flash} Scatter : MT6737M_Android_scatter.txt BR USB Com: Vid_0e8d&Pid_0003 DA Agent : DownloadAgent.bin BR ComPort: COM83 BR Asic Id: MT0335 [0000] >> MT6735 BR Asic Sw: 8A00 CB00 0000 0000 BR Secured: 5 DA Version: MTK_AllInOne_DA_v3.3001.00.00 Auth File not Defined BR_BOOT Error: -12 Flashing Canceled DA Shutdown Done, Disconnect Cable |
08-09-2017, 07:46 | #23 (permalink) | |
Member: 2185549 Status: Offline Thanks Meter: 535 | Quote:
please write with full firmware for exact model with ufst anad post logs to recover dead piece | |
08-09-2017, 07:54 | #24 (permalink) |
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | xt1757 cant find n lis of model support try to test in MTK modulo (mtk6737m), but in support find firmware of xt1756 are same model but DA of firmware not work, and try to format and now is dead by sptool. wait mr sha can help to add this model thanks |
08-09-2017, 08:44 | #26 (permalink) |
Product Supporter Join Date: Nov 2002 Location: usd Age: 64
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | uploaded ANDROID_UFS_1055_Test20.7z It have many changes, fixes. @jmr Please try it on Moto C XT1757 (Read at First) Because New Moto need special DA and in this version them are added |
08-09-2017, 09:06 | #28 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | Var OPPO-A33f (Neo 7 LTE DS) at USB (COM412) [DIAGS] {Gen.Settings} OFFLMODE: OK MDMVERSN: May 31 201718:19:16May 29 201703:00:00EAAAANUZ MDMBUILD: MPSS.DPM.2.0.2.c1.10-00045-M8936FAAAANUZM-1.100446.1.100898.3_VENDOR NV IMEI1: 862920-03-901037-2 NV IMEI2: 862920-03-901036-4 NV BTID : 4C1A:3D:31A38A NV WIFI : 4C1A:3D:31A38A oppo a33f fix diag mode is press *#801# then press enginner mode to enable diag |
The Following User Says Thank You to ferouz kassim For This Useful Post: |
