08-09-2017, 09:39 | #31 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: Colombia
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | Quote:
BR USB Com: Vid_0e8d&Pid_0003 DA Agent : DA_SWSEC_NAM.bin BR ComPort: COM141 BR Asic Id: MT0335 [0000] >> MT6735 BR Asic Sw: 8A00 CB00 0000 0000 BR Secured: 5 DA Version: MTK_AllInOne_DA_v3.3001.00.00 BR_RUN_D5 Error: -1 Possible not Valid DA Agent BR_BOOT Error: -14 DA_SHUTDOWN Error: -3 | |
The Following User Says Thank You to jmr For This Useful Post: |
08-13-2017, 12:32 | #34 (permalink) |
Freak Poster Join Date: Apr 2011 Location: pk
Member: 1565811 Status: Offline Sonork: 786 Thanks Meter: 8 | Box: 1 Location: 1042 Serial: TMB15945 Boot Id: 54 4D Box Login Failed Bad IX: ABCD Failed: -102 HID Number Corrupted, Try to Use [Update Box] Box: 1 Location: 1042 Serial: TMB19945 Boot Id: 54 4D Box Login Failed BOOT: TM ÿ Firmware Update Failed: s UD F1 Error: No Response Use [Check Box] Again |
The Following 2 Users Say Thank You to ITMAN142 For This Useful Post: |
08-16-2017, 09:01 | #36 (permalink) |
No Life Poster Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 535 | SPRD SC7731C (eMMC) at USB Auto Select [SPRD] {Write Flash} File: Itel-1407-W403-20151007.pac Vers: 12123123 No.of Operations: 21 (672.42 MB) BOOT: FDL1 and FDL2 from .pac File Hold Vol+, Vol- and Insert Cable to Switched OFF Device SROM: SPRD3 <<< STOP >>> FDL1_BOOT Failed: FDL1 RCON SPRD SC7730A (eMMC) at USB Auto Select [SPRD] {Write Flash} File: Itel-1407-W403-20151007.pac Vers: 12123123 No.of Operations: 21 (672.42 MB) BOOT: FDL1 and FDL2 from .pac File Hold Vol+, Vol- and Insert Cable to Switched OFF Device SROM: SPRD3 <<< STOP >>> FDL1_BOOT Failed: FDL1 RCON said we added picking loaders from .pac file but here is bug in test 21 |
08-16-2017, 09:44 | #37 (permalink) |
Product Supporter Join Date: Nov 2002 Location: usd Age: 64
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | I not agree with you, here is log with your file on other phone: SPRD SC7731C (eMMC) at USB Auto Select [SPRD] {Read Flash} File: Itel-1407-W403-20151007.pac File Size: 0x29FA4047 [671.64 MB] Vers: 12123123 Pac Version: BP_R1.0.0 No.of Operations: 3 (1.24 MB) BOOT: FDL1 and FDL2 from .pac File Hold Vol+, Vol- and Insert Cable to Switched OFF Device SROM: SPRD3 FDL1: Spreadtrum Boot Block version 1.1 FDL2: Ok, 96 Read uboot 1024 KB, Done in: 00:00.937 Restart Done, Disconnect Cable Read Files Path: D:\SPRD_FILES\SC7731C\READ\[2017_08_16_11_40_27]\ All Done in: 00:10.250 Seems something wrong with drivers afer FDL1 boot it cannot reconnect from SROM USB to FDL USB ... |
The Following User Says Thank You to Sha For This Useful Post: |
08-16-2017, 15:57 | #38 (permalink) | |
Member: 2185549 Status: Offline Thanks Meter: 535 | Quote:
can we please get compatible drivers uploaded on the server thnx mr. Sha | |
08-17-2017, 00:57 | #39 (permalink) |
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | Hi, Uploaded Root/DRIVERS/DRIVERS_SPRD_Signed_2.0.0.114.7z to install run 32install.exe or 64install.exe after instalation and connection check properties SPRD U2S Diag (COMxx) Properties: Driver Provider: DriverCoding Corporation Driver Date: 6/27/2014 Driver Version: 2.0.0.114 Digital Signer: Spreadtrum Communications (shanghai) Co., Ltd. Before Instalation uninstall all non signed and non trustable SPRD (SCI) drivers which have installed from other boxes. This driver must work Ok with all boxes. Monitor Ports with Device And try to do something with SPRD you must see SPRD U2S Diag Port Arriving when connecting cable After Boot Starts Port must Dissapear and Arrive Again when Boot finishing. If SPRD UDS Diag Port not Dissapears when cable Unpluged, this means bad driver instalation. Last edited by Sha; 08-17-2017 at 05:07. |
The Following 2 Users Say Thank You to Sha For This Useful Post: |
08-17-2017, 01:15 | #40 (permalink) |
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | Here some Log with SPRD using Default FDL's: SPRD SC7731G (eMMC) at USB Auto Select [SPRD] {Read Flash} BOOT: FDL1 and FDL2 from Default [DA] Hold Vol+, Vol- and Insert Cable to Switched OFF Device SROM: SPRD3 FDL1: Spreadtrum Boot Block version 1.1 FDL2: Ok, 96 Found Partitions: splloader Size: 4 MB, Type: 4 uboot Size: 4 MB, Type: 4 prodnv Size: 5 MB, Type: 0 miscdata Size: 1024 KB, Type: 0 wmodem Size: 8 MB, Type: 0 wdsp Size: 2 MB, Type: 0 wfixnv1 Size: 1024 KB, Type: 3 wfixnv2 Size: 1024 KB, Type: 3 wruntimenv1 Size: 1024 KB, Type: 6 wruntimenv2 Size: 1024 KB, Type: 6 wcnmodem Size: 1024 KB, Type: 0 wcnfixnv1 Size: 1024 KB, Type: 3 wcnfixnv2 Size: 1024 KB, Type: 3 wcnruntimenv1 Size: 1024 KB, Type: 6 wcnruntimenv2 Size: 1024 KB, Type: 6 logo Size: 1024 KB, Type: 0 fbootlogo Size: 1024 KB, Type: 0 boot Size: 15 MB, Type: 0 system Size: 1.22 GB, Type: 5 persist Size: 2 MB, Type: 5 cache Size: 350 MB, Type: 5 recovery Size: 14 MB, Type: 0 misc Size: 1024 KB, Type: 0 userdata Size: 2.02 GB, Type: 5 Partitions to Read: 4 Read splloader 4 MB, Done in: 00:04.989 Read uboot 4 MB, Done in: 00:04.898 Read prodnv 5 MB, Done in: 00:01.100 Read miscdata 1024 KB, Done in: 00:00.265 Restart Done, Disconnect Cable Read Files Path: D:\Users\saras\FILES\SPRD_FILES\SC7731G\READ\[2017_08_17_03_13_45]\ All Done in: 00:30.851 |
The Following 3 Users Say Thank You to Sha For This Useful Post: |
08-17-2017, 01:22 | #41 (permalink) |
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | And some log in CAL Mode: SPRD SC7731G (eMMC) at AutoSelect Port [CAL] {Factory Info} Insert Cable to Switched OFF Device CAL_MODE: FE8E CAL_DEVT: SP09 CA_CPVER: Platform Version: MOCORTM_14B_TShark_OC_W16.04_DebugProject Version: sc7731g_CP0_modemBASE Version: TM_BASE_15A_W16.04HW Version: sc7731g_CP0_modem01-18-2016 21:19:49 CA_APVER: MZ_VDF_P731V35V1.0.0B14 CA_SERN1: 900615493012 CA_SERN2: 32C2656430AA CA_CALST: PASS CA_IMEI1: 355575-0X-X56197-1 CA_BTID : 3CA:2A:3B:6F:BA CA_WIFI : 8C:79:67:56:18:E5 |
08-20-2017, 09:09 | #42 (permalink) |
Freak Poster Join Date: Dec 2011 Location: pakistan
Member: 1703671 Status: Offline Sonork: 100.1627623 Thanks Meter: 26 | my ufst show this problem please help me Box: 1 Location: 16674 Serial: TMA12******* UFST Boot v1.2 (c)SarasSoft 2012, Id: 54 4D 1 0 UFST Core v1.3 (c)SarasSoft 2013, Sn: 12****** BOX: CORRUPTED or MANIPULATED BOOT: TM UFST Boot v1.2 (c)SarasSoft 2012 Firmware: Ok Fatal SECURITY Error, Need Repair Box, Contact Distributor |
08-23-2017, 06:05 | #43 (permalink) |
Freak Poster Join Date: Jul 2008 Location: GSM,Pakistan
Member: 811049 Status: Offline Thanks Meter: 99 | useless added models UFST dear devlopers at UFST, please take anotice of phone models for example huawei and mtk based frp erase not working every time errors and failed. instead if possible please focus on only few brands and which works perfactly. where as other tools done these simple jobs in a seconds. Thanks. best regards. mian jahangir iqbal |
08-23-2017, 06:40 | #44 (permalink) | |
The Following User Says Thank You to ferouz kassim For This Useful Post: |
08-23-2017, 20:10 | #45 (permalink) |
Junior Member Join Date: Aug 2017
Member: 2750523 Status: Offline Thanks Meter: 1 | None of Flash Ports Selected <<< STOP >>> Samsung SM-G930F (S7) at USB (COM4) [LOKE FLASH] {Reset FRP} PLATF: LOKE 00020000 PIT Read Done: 00:00 Reset FRP Done in: 00:00.473 Comm Error LOKE Close: Cannot Write: 0 |
The Following User Says Thank You to yassssine For This Useful Post: |
