09-10-2017, 21:04 | #61 (permalink) |
Product Supporter Join Date: Nov 2002 Location: usd Age: 64
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | "BR Secured: 5 [SBC DAA]" You must try to use DA_SWSEC or DA_PL or can import any Download Agent from firmware pack, using [Add File] Button . |
The Following User Says Thank You to Sha For This Useful Post: |
09-22-2017, 21:16 | #63 (permalink) |
No Life Poster Join Date: Sep 2013 Location: INSIDE YOUR MIND
Member: 2025428 Status: Offline Thanks Meter: 445 | COOLPAD MT6582M PHONE WORKING OK JUST WANT FIRMWARE OF PHONE AS BACKUP BUT NOT WORKING MTK MT6582M (eMMC) at USB Auto Select [MTK] {Read Flash} BR USB Com: Vid_0e8d&Pid_2000 DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM17 BR Asic Id: MT6582 [0000] BR Asic Sw: 8A00 CA01 0001 0000 DA Version: MTK_AllInOne_DA_v3.3001.00.00 BR_RUN_D5 Error: -3 BR_BOOT Error: -14 DA Shutdown Done, Disconnect Cable |
09-23-2017, 00:54 | #66 (permalink) |
Member: 2025428 Status: Offline Thanks Meter: 445 | MT6735 AND NEWER CPU ALKWAYS SHOWS THIS ERROR TOO AFTER TICK FORMAT SELECTED AND UPDATE PMT FROM SCATTER THIS ERROR WILL APPEAR. AFTER ERASING FLASH FINISH.. MTK MT6735 (eMMC) at USB Auto Select [MTK] {Write Flash} Scatter : MT6735_Scatter_MT6735_0111374E3AA9 - Copy.txt BR USB Com: Vid_0e8d&Pid_2000 DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM17 BR Asic Id: MT0335 [0000] >> MT6735 BR Asic Sw: 8A00 CA00 0000 0000 DA Version: MTK_AllInOne_DA_v3.3001.00.00 PR MMC CID: 484A019061324734A15401118D8F3C0A [a2G4] PR Version: 4.2 [0x9B] (5) MT6737T eMMC BOOT1: 0x0000000000400000 [4.194.304] eMMC BOOT2: 0x0000000000400000 [4.194.304] eMMC RPMB : 0x0000000000400000 [4.194.304] eMMC USER : 0x00000000E9000000 [3.909.091.328] eMMC CID : 90014A4834473261110154A10A3C228D [H4G2a] ERAM Size : 0x0000000020000000 [536.870.912] IRAM Size : 0x0000000000020000 [131.072] UNICAL ID : D7A1CEF4FAC582F7389CCE6A619C521B PMT (GPT) Found : 27 Partition Entries Partitions to Flash: 19 (2.84 GB) Erasing: LinST: 0x0000080000 Size: 0x0000300000 proinfo Erasing: LinST: 0x0001C80000 Size: 0x0000080000 lk Erasing: LinST: 0x0001D00000 Size: 0x0000080000 para Erasing: LinST: 0x0001D80000 Size: 0x0001000000 boot Erasing: LinST: 0x0002D80000 Size: 0x0001000000 recovery Erasing: LinST: 0x0003D80000 Size: 0x0000800000 logo Erasing: LinST: 0x0004580000 Size: 0x0000A00000 expdb Erasing: LinST: 0x0004F80000 Size: 0x0000400000 rootm Erasing: LinST: 0x0005380000 Size: 0x0000080000 seccfg Erasing: LinST: 0x0005400000 Size: 0x0000200000 oemkeystore Erasing: LinST: 0x0005600000 Size: 0x0000600000 secro Erasing: LinST: 0x0005C00000 Size: 0x0000800000 keystore Erasing: LinST: 0x0006400000 Size: 0x0000500000 tee1 Erasing: LinST: 0x0006900000 Size: 0x0000500000 tee2 Erasing: LinST: 0x0006E00000 Size: 0x0000100000 frp Erasing: LinST: 0x0008F00000 Size: 0x0002100000 metadata Erasing: LinST: 0x000B000000 Size: 0x0035800000 system Erasing: LinST: 0x0040800000 Size: 0x0019000000 cache Erasing: LinST: 0x0059800000 Size: 0x0060000000 userdata Format Done in: 00:03.124 DL_SET_A4 Error: -3 Write PMT Failed DA Shutdown Done, Disconnect Cable |
The Following User Says Thank You to johnoroo37 For This Useful Post: |
09-23-2017, 01:07 | #67 (permalink) |
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | PMT (GPT) Found : 27 Partition Entries PMT is OK, why You select PMT Write ? I will check and revise a PMT problem on 64bit mcu's Last edited by Sha; 09-23-2017 at 01:17. |
09-23-2017, 12:32 | #68 (permalink) |
No Life Poster Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 535 | Log File: 2017_09_23_14_07_44_Log.txt Alcatel 5056N (Fierce 4 LTE) at Auto Select Flash Port [SAHARA] {Reset FRP} QDL USB Com: Vid_05c6&Pid_9008 (COM252) SAHARA VERS: 2 SAHARA PROG: prog_emmc_firehose_8909_alc1.mbn SAHARA Upload Failed: -2 Possible Wrong FireHose Attestation Restart/Reconnect Device, Battery before Next Boot FHREST DONE: Ok Reset FRP Failed Alcatel 5056N (Fierce 4 LTE) at Auto Select Flash Port [SAHARA] {Reset FRP} QDL USB Com: Vid_05c6&Pid_9008 (COM252) SAHARA VERS: 2 SAHARA PROG: prog_emmc_firehose_8909_alc.mbn SAHARA Upload Failed: -2 Possible Wrong FireHose Programmer Restart/Reconnect Device, Battery before Next Boot FHREST DONE: Ok Reset FRP Failed Alcatel 5056N (Fierce 4 LTE) at Auto Select Flash Port [SAHARA] {Reset FRP} QDL USB Com: Vid_05c6&Pid_9008 (COM252) SAHARA VERS: 2 SAHARA PROG: prog_emmc_firehose_8909_alc2.mbn SAHARA Upload Failed: -2 Possible Wrong FireHose Attestation Restart/Reconnect Device, Battery before Next Boot FHREST DONE: Ok Reset FRP Failed Alcatel 5056N (Fierce 4 LTE) at Auto Select Flash Port [SAHARA] {Reset FRP} QDL USB Com: Vid_05c6&Pid_9008 (COM252) SAHARA VERS: 2 SAHARA PROG: prog_emmc_firehose_8909_alc3.mbn SAHARA Upload Failed: -2 Possible Wrong FireHose Attestation Restart/Reconnect Device, Battery before Next Boot FHREST DONE: Ok Reset FRP Failed Alcatel 5056N (Fierce 4 LTE) at Auto Select Flash Port [SAHARA] {Reset FRP} QDL USB Com: Vid_05c6&Pid_9008 (COM252) SAHARA VERS: 2 SAHARA PROG: prog_emmc_firehose_8909_alc5.mbn SAHARA Upload Failed: -2 Possible Wrong FireHose Attestation Restart/Reconnect Device, Battery before Next Boot FHREST DONE: Ok Reset FRP Failed Alcatel 5056N (Fierce 4 LTE) at Auto Select Flash Port [SAHARA] {Reset FRP} QDL USB Com: Vid_05c6&Pid_9008 (COM252) SAHARA VERS: 2 SAHARA PROG: prog_emmc_firehose_8909_alc6.mbn SAHARA Upload Failed: -2 Possible Wrong FireHose Attestation Restart/Reconnect Device, Battery before Next Boot FHREST DONE: Ok Reset FRP Failed Alcatel 5056N (Fierce 4 LTE) at Auto Select Flash Port [SAHARA] {Reset FRP} QDL USB Com: Vid_05c6&Pid_9008 (COM252) SAHARA VERS: 2 SAHARA PROG: prog_emmc_firehose_8909_alc7.mbn SAHARA Upload Failed: -2 Possible Wrong FireHose Attestation Restart/Reconnect Device, Battery before Next Boot FHREST DONE: Ok Reset FRP Failed Alcatel 5056N (Fierce 4 LTE) at Auto Select Flash Port [SAHARA] {Reset FRP} QDL USB Com: Vid_05c6&Pid_9008 (COM252) SAHARA VERS: 2 SAHARA PROG: prog_emmc_firehose_8909_alc8.mbn SAHARA Upload Failed: -2 Possible Wrong FireHose Attestation Restart/Reconnect Device, Battery before Next Boot FHREST DONE: Ok Reset FRP Failed |
09-25-2017, 15:13 | #69 (permalink) |
No Life Poster Join Date: Jul 2012 Location: vietnam
Member: 1781157 Status: Offline Sonork: 100.1624851 Thanks Meter: 167 | add huawei phone flash file app and unlock bootloader / fix and add boot for huawei |
The Following User Says Thank You to ngocdiemmobile For This Useful Post: |
09-27-2017, 05:08 | #70 (permalink) | |
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | Quote:
Fixed in: ANDROID_UFS_1055_Test28.7z | |
09-27-2017, 14:11 | #71 (permalink) |
Junior Member Join Date: Apr 2009
Member: 1019757 Status: Offline Sonork: [email protected] Thanks Meter: 9 | dear ufst team plz add more featcher,s in ufst it too backword fom other running tool,s , plz add read info read/reset pattren pin pass safe formating, other boot loader unlocking for locked boot devices , and also add mtk keypad support chips , spd had already added keypad phones 6530/31 , kindly speed up it for take backup and improve spd pac,Sc file also |
10-01-2017, 11:09 | #72 (permalink) |
Freak Poster Join Date: Sep 2014 Location: MOZAMBIQUE
Member: 2263412 Status: Offline Thanks Meter: 86 | TECNO CANON CX at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM135 BR Asic Id: MT0321 [0000] >> MT6755 BR Asic Sw: 8A00 CA00 0000 0000 DA Version: MTK_AllInOne_DA_v3.3001.00.00 BR_RUN_D5 Error: -1 Possible not Valid DA Agent BR_BOOT Error: -14 Reset FRP Failed: -14 DA_SHUTDOWN Error: -2 Last USB Exception: 0x0002 The system cannot find the file specified. |
10-02-2017, 07:38 | #73 (permalink) | |
Member: 2185549 Status: Offline Thanks Meter: 535 | Quote:
thx | |
10-02-2017, 08:47 | #74 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | lg mtk phone imei repair not done for lg mtk based devices partition can be wri**** and changed via dwonload mode please add that fucntion LG K120E (K4 LTE) at USB (COM55) [MODEM] {Gen.Settings} MODEMCON: OK MD MODEL: LG-K120E MD HWVRS: 1.0 MD SWVER: LGK120EAT-00-V10e-234-30-SEP-24-2016+0 MD DVPID: CB43S170113001195 MD IMEI1: 357137-07-910739-6 MD BTID : B81D:AA:099E97 MD WIFI : 5CAF:06:83CA2D MD NTCOD: "2","234,30F,FFFFFFFF,FFFFFFFF,02","234,33F,FFFFFF FF,FFFFFFFF,02" MD LTYPE: 0000 NONE Gen.Settings Write Done: 0 Item(s) Gen.Settings Write Done: 3 Item(s) LG K120E (K4 LTE) at USB (COM55) [MODEM] {Factory Info} MODEMCON: OK MD MODEL: LG-K120E MD HWVRS: 1.0 MD SWVER: LGK120EAT-00-V10e-234-30-SEP-24-2016+0 MD DVPID: CB43S170113001195 MD IMEI1: 357137-07-910739-6 MD BTID : B81D:AA:099E97 MD WIFI : 5CAF:06:83CA2D MD NTCOD: "2","234,30F,FFFFFFFF,FFFFFFFF,02","234,33F,FFFFFF FF,FFFFFFFF,02" MD LTYPE: 0000 NONE |
10-02-2017, 09:08 | #75 (permalink) |
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | Try [Unlock/Sec] button in [OEM] Tab It do exactly what you Ask |
