03-20-2014, 17:09 | #17 (permalink) |
Junior Member Join Date: Oct 2005 Location: city
Member: 191521 Status: Offline Thanks Meter: 1 | App: UFSx (HWK) Control Panel v 2.3.0.5 by SarasSoft CPU: AuthenticAMD Platform: Windows NT 6.1 (Build 7601 Service Pack 1) Versions: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 C:\Program Files (x86) C:\Program Files (x86)\Common Files Nokia Path not Found, Set to: C:\Program Files (x86)\Nokia\Phoenix C:\Users\ballatom\Desktop C:\Users\ballatom\AppData\Roaming\Microsoft\Window s\Start Menu\Programs Last Server Update: 2014/03/10 Active Panel Version: 2.3.0.5 App: UFSx (HWK) Control Panel v 2.3.0.5 by SarasSoft Ftd: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 Box: 1 Location: 0 Serial: UFST Boot v1.2 (c)SarasSoft 2012, Id: 54 4D 1 0 UFST Core v1.3 (c)SarasSoft 2013, Sn: HID: F3261504xxxxxxx, HWK: A1.04-PRO1 SID: BE351D5053797841CE125xxxxxxxxxxxxxxxxxxxxx XID: 6F21133E752DAA67E04D4xxxxxxxxxxxxxxxxxxxxx LIC: True BoxStat : Ok Firmware: Ok Your IP: 84.1.173.185 Support: Account Ok Last edited by mobileclinic; 03-21-2014 at 07:24. |
03-21-2014, 07:25 | #18 (permalink) | |
Product Supporter Join Date: Sep 2001 Location: India
Member: 6109 Status: Offline Sonork: 100.37432 Thanks Meter: 3,781 | Quote:
03-21-2014, 14:42 | #19 (permalink) | |
Member: 191521 Status: Offline Thanks Meter: 1 | Win7/64 Update ok, no error run any tool (samsung, DCTxBB5, etc.): authorised error Quote:
03-21-2014, 21:24 | #20 (permalink) | |
No Life Poster Join Date: Feb 2008 Location: Bosnia
Member: 698071 Status: Offline Sonork: 100.1622915 Thanks Meter: 283 | Quote:
UFST box is OK | |
The Following User Says Thank You to sajohaker For This Useful Post: |
04-13-2014, 03:31 | #23 (permalink) | |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | Quote:
First complete uninstall the software. Then using registry editor delete any hwk entry u found. Then install the latest one i.e 2.3.0.5. And do the update process. Ur problem will be definitely solved. | |
04-13-2014, 06:58 | #24 (permalink) | |
If your problem not solved then post your error log here. | |
