Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 08-13-2019, 23:17   #1 (permalink)
Member: 2738836
Thanks Meter: 3
Exclamation A102U - Carrier relock success but phone still not accepting the simcard
Hi support,
I made a template that i have been using correctly on S10, so the problem isn't the simcard mcc/mnc code not being on the template.
Here is the log but the same simcard i have beeing using for test on s10 is not being accepted on this A102U after the relock process. Credits were rebated. Please check this. Regards
Chimera Mobile Phone Utility version: 22.02.1024 @ 2019-08-13
Carrier relock started
Gathering phone info...
Collecting information. Be patient! Do NOT disconnect the phone!
Model: SM-A102U
Sales Code: TMK
Country Code: USA
Timezone: America/Havana
Android Version: 9 [PPR1.180610.011] [SDK 28]
Build Date: Thu Jun 27 14:52:03 KST 2019
PDA Version: A102USQU1ASFI [june 2019, revI]
Phone Version: A102USQU1ASFI [june 2019, revI]
CSC Version: A102UOYN1ASFI [june 2019, revI]
Product Code: TMK
HIDSw Version: A102USQU1ASFI/A102UOYN1ASFI/A102USQU1ASFI/A102USQU1ASFI
Board Platform: EXYNOS5
Modem Platform: SHANNON327
Serial Number: RF8M70A12WN
Imei: 356274*********
Unique Number: CBJ00A887D8C966
Connections: AT,MTP
Battery Status: 4.10V (79%)
Network Type: GSM
SIM Status: ABSENT
Multisim Config: SS
Knox Version: v30
Warranty Bit: 0
Security Patch: 2019-06-01
Data Encryption State: encrypted
Carrier relock...
The operation is in progress. Be patient! Do NOT disconnect the phone!
Restarting phone.
Waiting for ADB connection. Be patient! Do NOT disconnect the phone!
Carrier relocked.
Successfully finished.
Finished at local time: [08.13.19 16:32:20]
WorkID: 69677020
Old 08-14-2019, 04:14   #2 (permalink)
chavonbravo's Avatar
Member: 952912
Thanks Meter: 142
Any way you could insert the sim you are attempting to use, and run an adb command?
adb shell service call iphonesubinfo 7
Then please copy here the reply.
The Following User Says Thank You to chavonbravo For This Useful Post:
Old 08-14-2019, 17:54   #3 (permalink)
Member: 2738836
Thanks Meter: 3
Result: Parcel(00000000 ffffffff '........')
Old 08-14-2019, 17:56   #4 (permalink)
Member: 2738836
Thanks Meter: 3
Here is the read info log:
Chimera Mobile Phone Utility version: 22.02.1024 @ 2019-08-14
Printing phone history
Carrier Relock
13/08/2019
8:30:34
Get info started
Model: SM-A102U
Sales Code: TMK
Country Code: USA
Product Code: TMK
Connections: AT,MTP
Battery Status: 3.90V (53%)
Network Type: GSM
SIM Status: SIM_SERVICE_PROVIDER_LOCKED
Multisim Config: SS
Knox Version: v30
Warranty Bit: 0
Finished at local time: [08.14.19 12:56:22]
WorkID: 69754896
Old 08-15-2019, 16:15   #5 (permalink)
Member: 909015
Thanks Meter: 75
Same To me after update to bit 2, phone locked again
Chimera Mobile Phone Utility version: 22.02.1024 @ 2019-08-15
Get Info
14/8/2019
08:11:11
Carrier Relock
14/8/2019
08:07:57
Carrier Relock
14/8/2019
08:03:36
Carrier Relock
14/8/2019
07:59:15
Rmm Unlock
14/8/2019
07:57:30
Model: SM-G975U
Sales Code: TMB
Country Code: USA
Timezone: America/Tegucigalpa
Build Date: Mon Jul 22 08:27:20 KST 2019
PDA Version: G975USQU2ASGC [july 2019, revC]
Phone Version: G975USQU2ASGC [july 2019, revC]
CSC Version: G975UOYN2ASGC [july 2019, revC]
Product Code: TMB
HIDSw Version: G975USQU2ASGC/G975UOYN2ASGC/G975USQU2ASGC/G975USQU2ASGC
Board Platform: MSMNILE
Modem Platform: SM8150
Serial Number: R38M405EM1Y
Imei: 354415****69779
Unique Number: 988ECD4441364D4B3934
Connections: AT,MTP
Battery Status: 3.80V (41%)
Network Type: GSM
SIM Status: ABSENT
Multisim Config: SS
Knox Version: v30
Warranty Bit: 0
Security Patch: 2019-07-01
Carrier relock...
Carrier relocked.
Finished at local time: [08.15.19 09:11:25]
WorkID: 69848644
Old 08-15-2019, 16:22   #6 (permalink)
Member: 2738836
Thanks Meter: 3
Well, i didn't even update the phone. Check the first info and the second after the problem. Is the same bit 1 and still not working.
The relock never worked, please Chimera Team give a fix. Regards
Old 08-15-2019, 16:35   #7 (permalink)
Member: 952912
Thanks Meter: 142
Can you insert the same sim in another Samsung which accepts it and tun the same adb command and post output please?
Old 08-15-2019, 17:07   #8 (permalink)
Member: 909015
Thanks Meter: 75
I think it is not a 100% reliable method
Old 08-15-2019, 17:07   #9 (permalink)
Member: 2738836
Thanks Meter: 3
Result: Parcel(
0x00000000: 00000000 0000000f 00360033 00300038 '........3.6.8.0.'
0x00000010: 00310031 00310031 00310030 00340038 '1.1.1.1.0.1.8.4.'
0x00000020: 00360032 00000037 '2.6.7... ')
Old 08-15-2019, 17:13   #10 (permalink)
Member: 952912
Thanks Meter: 142
Thank you, and a screenshot of *#0011# on working phone, if you dont mind?
Old 08-15-2019, 17:35   #11 (permalink)
Member: 2738836
Thanks Meter: 3
This is a Samsung Galaxy S8:
Result: Parcel(00000000 00000002 00370030 00000000 '........0.7.....')
Old 08-15-2019, 17:39   #12 (permalink)
Member: 952912
Thanks Meter: 142
My recommendation, reattempt, create template with only the Cuba MccMnc (368/01), and see if there are better results.
The process is reliable, it just sometimes is difficult to select correct mccmnc in templates, and match to actual sim of customer.
This adb command I posted earlier, along with info from *#0011# can ensure you select correct mcc/mnc. You do not get charged more than once for the same device, so you can reattempt until you get the right template working for the carrier of your choice. It seems you only attempted once on this device (A102U).
Old 08-15-2019, 17:44   #13 (permalink)
Member: 2738836
Thanks Meter: 3
I didn't know it will not charge me again i will try this and let you know. Thanks for your help
Old 08-15-2019, 17:50   #14 (permalink)
Member: 952912
Thanks Meter: 142
Sample dial code menu with carrier mccmnc.
This is what looks like. You see 310/260 as MccMnc for carrier signal. And the adb command gives MccMnc on sim card (first 5 or 6 digits). From your picture, it looks like the the phone is on carrier MccMnc 000/00, which is reserved for test purposes only.
It is possible someone has a test network nearby (best case scenario). You may need to add 000/00 and 000/000 to your template list if this is the case.
Old 08-15-2019, 17:51   #15 (permalink)
Member: 2738836
Thanks Meter: 3
It worked selecting only that carrier. Thanks!!!
Regards
Page generated in 0.20772 seconds with 8 queries
