Nokia X Android Based Nokia X Nokia X+ Nokia XL The Nokia X family is a range of new smartphones from Nokia introduced in 2014, running a forked version of Android |
![]() | #31 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Service work just fime on Oreo Nokia 6 Like all SW till now from Laser ![]() WBR, DebeliaMark, BG |
The Following User Says Thank You to debeliamark For This Useful Post: |
![]() | #32 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2002 Location: Russia Age: 44
Member: 9519 Status: Offline Thanks Meter: 2,150 | most important, we change new values factory way and new values are in effect. for example, when you change IMEI with any other software, than OST or NTool, you will only change IMEI on screen, network reported IMEI will not change. |
![]() | #33 (permalink) |
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Confirmed - OTA updates work well after service job(s) ... The nice thing here is - if you don't like latest update - you can go back !!! with NTool dowgrage!!! |
![]() | #34 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2016 Location: Balochistan
Member: 2545664 Status: Offline Sonork: nill Thanks Meter: 88 ![]() | RUNNING NTool 0.01 HMD PHONE "PL2Gxxxxxxxxxxxx" CONNECTED model=P2A sub_model=none software version=PL2-213B-0-00WW-B09 SW model=00WW build number=B09 hardware version=5.0 RF band id=G_850_900_1800_1900^W_1_2_5_8^L_1_3_5_7_8_20_28 _ secure:yes reported max download size: 536870912 getBootloaderType:commercial SecVer:4 getBootloaderType:commercial challenge ![]() dm-veracity passed extract and flash "B2N-0-213B-xbl_service.zip" to "xbl_a" Extracted 2563273 bytes extract and flash "B2N-0-213B-xbl_service.zip" to "xbl_b" Extracted 2563273 bytes extract and flash "B2N-0-213B-abl_service.zip" to "abl_a" Extracted 380928 bytes extract and flash "B2N-0-213B-abl_service.zip" to "abl_b" Extracted 380928 bytes device PL2Gxxxxxxxxxxxx removed HMD phone "PL2Gxxxxxxxxxxxx" removed HMD PHONE "PL2Gxxxxxxxxxxxx" CONNECTED perform auth routine SecVer:4 getBootloaderType:service ProjectCode:PL2 UID:xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx Using cached signature service key auth passed flash "B2N-0-213B-gpt_both0.bin" to "partition" skip flashing B2N-0-213B-xbl_service.elf skip flashing B2N-0-213B-xbl_service.elf extract and flash "B2N-0-213B-xbl_service.zip" to "xbl_a" Extracted 2563273 bytes extract and flash "B2N-0-213B-xbl_service.zip" to "xbl_b" Extracted 2563273 bytes skip flashing B2N-0-213B-abl_service.elf skip flashing B2N-0-213B-abl_service.elf extract and flash "B2N-0-213B-abl_service.zip" to "abl_a" Extracted 380928 bytes extract and flash "B2N-0-213B-abl_service.zip" to "abl_b" Extracted 380928 bytes flash "B2N-0-213B-tz.mbn" to "tz_a" flash "B2N-0-213B-rpm.mbn" to "rpm_a" flash "B2N-0-213B-hwcfg.img" to "hwcfg" flash "B2N-0-213B-hyp.mbn" to "hyp_a" flash "B2N-0-213B-pmic.elf" to "pmic_a" flash "B2N-0-213B-keymaster64.mbn" to "keymaster_a" flash "B2N-0-213B-cmnlib.mbn" to "cmnlib_a" flash "B2N-0-213B-cmnlib64.mbn" to "cmnlib64_a" flash "B2N-0-213B-dspso.bin" to "dsp_a" flash "B2N-0-213B-devcfg.mbn" to "devcfg_a" flash "B2N-0-213B-sec.dat" to "sec" flash "B2N-0-213B-mdtpsecapp.mbn" to "mdtpsecapp_a" flash "B2N-0-213B-storsec.mbn" to "storsec" flash "systeminfo.img" to "systeminfo_a" perform "reboot-bootloader" device PL2Gxxxxxxxxxxxx removed HMD phone "PL2Gxxxxxxxxxxxx" removed HMD PHONE "PL2Gxxxxxxxxxxxx" CONNECTED perform auth routine SecVer:4 getBootloaderType:service ProjectCode:PL2 UID:xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx Using cached signature service key auth passed flash "B2N-1-213B-NON-HLOS.bin" to "modem_a" flash "B2N-0-213B-00WW-mdtp.img" to "mdtp_a" flash "PL2-0-213B-00WW-boot.img" to "boot_a" erase "boot_b" flash "PL2-0-213B-00WW-system.img" to "system_a" TotalSize: 0000003221225472 flash "PL2-0-213B-00WW-system_other.img" to "system_b" TotalSize: 0000003221225472 flash "B2N-0-213B-BTFM.bin" to "bluetooth_a" flash "B2N-0-213B-00WW-persist.img" to "persist" TotalSize: 0000000033554432 erase "userdata" if not retain user data flash "PL2-00WW-001-sutinfo.img" to "sutinfo" flash "B2N-0-213B-NV-default.mbn" to "nvdef_a" flash "C1N-0-0020-0001-hidden.img.ext4" to "hidden_a" flash "PL2-00WW-018-cda.img" to "cda_a" erase "ssd" if not retain user data erase "misc" if not retain user data erase "sti" if not retain user data flash "PL2-00WW-018-splash.img" to "splash_a" flash "PL2-00WW-018-multi-splash.img" to "splash2" erase "ddr" erase "securefs" on factory skip, options: 0000000000000001 bootName "KEY_INFO" skip, options: 0000000000000001 bootName "box" flash "PL2-0-213B-00WW-vendor.img" to "vendor_a" TotalSize: 0000001073741824 flash "B2N-0-213B-xbl.elf" to "xbl_a" flash "B2N-0-213B-xbl.elf" to "xbl_b" flash "B2N-0-213B-abl.elf" to "abl_a" flash "B2N-0-213B-abl.elf" to "abl_b" perform "oem set_active _a" perform "oem enable-charger-screen" skip, options: 0000000000000001 bootName "cda" skip, options: 0000000000000001 bootName "e2p_package" skip, options: 0000000000000001 bootName "e2p_script" flash "md4.dat" to "md4" Elapsed: 201 secs.RUNNI |
The Following User Says Thank You to mebugti For This Useful Post: |
![]() | #35 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2006 Location: India
Member: 376471 Status: Offline Sonork: 100.1608095 Thanks Meter: 107 | Quote:
Is frp charged or free | |
![]() | #37 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2012 Location: india mumbai
Member: 1847344 Status: Offline Thanks Meter: 300 | ta1032 dead or sp tool erase preloader solution nokia ta1032 erase reloader solution hi to all my phone is working well but automatice download some applecation so i flash sp tools select formate all +download so my hand set is fully dead only sp flash tool connect da red file and error s auth handle is not ready 0x1388 any solution |
![]() | #38 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2008
Member: 714291 Status: Offline Thanks Meter: 39 | hi NTool team i have nokia 7 plus , it was working fine but decided to wipe data once data wiped its now stuck at androidone logo with bootloop repeated factory reset but no success please team give me some idea what to do so as to revive my phone Thank you |
![]() | #41 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2009 Location: pilapil marangle
Member: 1190283 Status: Online Thanks Meter: 67 | Hi the_laser I have nokia 7 the problem stock on download mode..i download the firmware on xda..but unable to flash.. This ntool fix my nokia 7 ? I want to unlock bootloader Sorry for my bad english.. |
![]() | #44 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2004 Location: MACEDONIA
Member: 67805 Status: Offline Thanks Meter: 364 | Nokia 5 frp Nokia 5 on oreo8 remuved frp for just 9 sec ![]() I finaly fix driver issue, manual update driver and untick "show compatibile hardware" then it will show HMD Global / Fastboot device like on pic bellow Code: RUNNING NTool 0.027 PLEASE CONNECT POWERED OFF PHONE PHONE "D1AGAS37B0207703" CONNECTED model : D1A sub_model : none software version : ND1-558B-0-00WW-B01 SW model : 00WW build number : B01 hardware version : 5.0 RF band id : _850_900_1800_1900^W_1_2_5_8^L_1_3_5_7_8_20_28_38_40 chip version : none MCP info : none EMMC version : Hynix 5.1 16GB secure:yes Bootloader type : commercial Security version : 0004 Challenge : ce5adac9968ab8cfb7306bf5b3e4df7b57597589 Waiting for calculation process ... RESPONSE: "SUCCESS" [256] BOOTLOADER AUTH PASSED Flash "D1C-0-5600-emmc_appsboot_service.zip" to "aboot" PHONE "D1AGAS37B0207703" REMOVED PHONE "D1AGAS37B0207703" CONNECTED Security version : 0004 ProjectCode : ND1 UID : e9d9a152d5776c7eccd5527dddd6924a8abf2768 Waiting for calculation process ... RESPONSE: "SUCCESS" [256] SERVICE AUTH PASSED Flash "D1C-0-5600-ftm.img" to "ftmboot" Flash "D1C-0-5600-emmc_appsboot.mbn" to "aboot" FRP partition erased Elapsed: 9 secs. |
![]() | #45 (permalink) |
Member: 376471 Status: Offline Sonork: 100.1608095 Thanks Meter: 107 | Dear Sir, i need to flash TA-1021, phone in bootloop also has SW: PLE-522C-0-00WW-B01 unable to flash any nb0 or mlf to this phone. I dont have credit. Can i get any help to resolve this problem from u. |
