Nokia X Android Based Nokia X Nokia X+ Nokia XL The Nokia X family is a range of new smartphones from Nokia introduced in 2014, running a forked version of Android |
04-27-2018, 01:37 | #16 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Russia Age: 44
Member: 9519 Status: Offline Thanks Meter: 2,150 | or some other software ? cause if OST can detect phone, NTOOL should recognize it for sure ... |
04-27-2018, 10:38 | #17 (permalink) | |
No Life Poster Join Date: Jun 2004 Location: MACEDONIA
Member: 67805 Status: Offline Thanks Meter: 364 | Quote:
Br | |
04-27-2018, 13:15 | #18 (permalink) |
Member: 9519 Status: Offline Thanks Meter: 2,150 | we will see further reports, so far i can not reproduce such issue. btw, if you think that "enter FTM" button in cracked OST really put phone in FTM mode, you are wrong. |
04-27-2018, 13:28 | #19 (permalink) |
Member: 9519 Status: Offline Thanks Meter: 2,150 | can you execute next commands on this PC and send me output.reg ? 1. open command prompt as admin 2. enter next commands, line by line Code: c: mkdir c:\temp cd c:\temp reg export HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\USB output.reg start . 4. if you are skilled in command line, you can do all this much easier |
The Following User Says Thank You to the_laser For This Useful Post: |
04-27-2018, 15:39 | #21 (permalink) |
Member: 9519 Status: Offline Thanks Meter: 2,150 | thanks, as expected, it is drivers - you have a lot of device drivers in your system and phone used fastboot driver from Google, while NTool want drivers from HMD two possible solutions - either i'll add Google fastboot to recognized devices or you just change FastBoot driver manually in device manager to HMD's one |
The Following 4 Users Say Thank You to the_laser For This Useful Post: |
04-27-2018, 16:08 | #22 (permalink) |
Member: 67805 Status: Offline Thanks Meter: 364 | Yes i have tons of drivers as windows is instaled 10.2014, but still works I really like this your new project, because for new nokia hmd we doesent have any support exept from xda members |
04-27-2018, 17:30 | #23 (permalink) |
Member: 9519 Status: Offline Thanks Meter: 2,150 | btw, one of most interesting NTool functions is bootloader unlock signature generation - it allows to generate bootloader unlock signatures for other users ... |
04-29-2018, 15:53 | #25 (permalink) |
Member: 9519 Status: Offline Thanks Meter: 2,150 | it will be added in later releases, qualcomm models for sure, and mtk models most probably. |
The Following 2 Users Say Thank You to the_laser For This Useful Post: |
05-01-2018, 18:27 | #30 (permalink) | |
Member: 9519 Status: Offline Thanks Meter: 2,150 | NTool v0.025 Quote:
1 credit for bootloader unlock generation ( charged each time ) | |
The Following 3 Users Say Thank You to the_laser For This Useful Post: |
