Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia X Android Based
Nokia X Android Based Nokia X Nokia X+ Nokia XL The Nokia X family is a range of new smartphones from Nokia introduced in 2014, running a forked version of Android
Old 05-02-2018, 09:53   #31 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 1,034
Service work just fime on Oreo Nokia 6
Nice work - smooth and fast
Like all SW till now from Laser ...
WBR, DebeliaMark, BG
The Following User Says Thank You to debeliamark For This Useful Post:
Old 05-02-2018, 20:36   #32 (permalink)
Member: 9519
Thanks Meter: 2,150
most important, we change new values factory way and new values are in effect.
for example, when you change IMEI with any other software, than OST or NTool, you will only change IMEI on screen, network reported IMEI will not change.
Old 05-04-2018, 04:49   #33 (permalink)
Member: 4627
Thanks Meter: 1,034
Confirmed - OTA updates work well after service job(s) ... The nice thing here is - if you don't like latest update - you can go back !!! with NTool dowgrage!!!
Old 05-04-2018, 04:58   #34 (permalink)
mebugti's Avatar
Member: 2545664
Sonork: nill
Thanks Meter: 88
RUNNING NTool 0.01
HMD PHONE "PL2Gxxxxxxxxxxxx" CONNECTED
model=P2A
sub_model=none
software version=PL2-213B-0-00WW-B09
SW model=00WW
build number=B09
hardware version=5.0
RF band id=G_850_900_1800_1900^W_1_2_5_8^L_1_3_5_7_8_20_28 _
secure:yes
reported max download size: 536870912
getBootloaderType:commercial
SecVer:4
challenge611A10DD5955148ADE2077F13D8FB2AE0A37B0E
dm-veracity passed
extract and flash "B2N-0-213B-xbl_service.zip" to "xbl_a"
Extracted 2563273 bytes
extract and flash "B2N-0-213B-xbl_service.zip" to "xbl_b"
extract and flash "B2N-0-213B-abl_service.zip" to "abl_a"
Extracted 380928 bytes
extract and flash "B2N-0-213B-abl_service.zip" to "abl_b"
device PL2Gxxxxxxxxxxxx removed
HMD phone "PL2Gxxxxxxxxxxxx" removed
perform auth routine
SecVer:4
getBootloaderType:service
ProjectCode:PL2
UID:xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Using cached signature
service key auth passed
flash "B2N-0-213B-gpt_both0.bin" to "partition"
skip flashing B2N-0-213B-xbl_service.elf
skip flashing B2N-0-213B-abl_service.elf
flash "B2N-0-213B-tz.mbn" to "tz_a"
flash "B2N-0-213B-rpm.mbn" to "rpm_a"
flash "B2N-0-213B-hwcfg.img" to "hwcfg"
flash "B2N-0-213B-hyp.mbn" to "hyp_a"
flash "B2N-0-213B-pmic.elf" to "pmic_a"
flash "B2N-0-213B-keymaster64.mbn" to "keymaster_a"
flash "B2N-0-213B-cmnlib.mbn" to "cmnlib_a"
flash "B2N-0-213B-cmnlib64.mbn" to "cmnlib64_a"
flash "B2N-0-213B-dspso.bin" to "dsp_a"
flash "B2N-0-213B-devcfg.mbn" to "devcfg_a"
flash "B2N-0-213B-sec.dat" to "sec"
flash "B2N-0-213B-mdtpsecapp.mbn" to "mdtpsecapp_a"
flash "B2N-0-213B-storsec.mbn" to "storsec"
flash "systeminfo.img" to "systeminfo_a"
perform "reboot-bootloader"
SecVer:4
ProjectCode:PL2
flash "B2N-1-213B-NON-HLOS.bin" to "modem_a"
flash "B2N-0-213B-00WW-mdtp.img" to "mdtp_a"
flash "PL2-0-213B-00WW-boot.img" to "boot_a"
erase "boot_b"
flash "PL2-0-213B-00WW-system.img" to "system_a"
TotalSize: 0000003221225472
flash "PL2-0-213B-00WW-system_other.img" to "system_b"
flash "B2N-0-213B-BTFM.bin" to "bluetooth_a"
flash "B2N-0-213B-00WW-persist.img" to "persist"
TotalSize: 0000000033554432
erase "userdata" if not retain user data
flash "PL2-00WW-001-sutinfo.img" to "sutinfo"
flash "B2N-0-213B-NV-default.mbn" to "nvdef_a"
flash "C1N-0-0020-0001-hidden.img.ext4" to "hidden_a"
flash "PL2-00WW-018-cda.img" to "cda_a"
erase "ssd" if not retain user data
erase "misc" if not retain user data
erase "sti" if not retain user data
flash "PL2-00WW-018-splash.img" to "splash_a"
flash "PL2-00WW-018-multi-splash.img" to "splash2"
erase "ddr"
erase "securefs" on factory
skip, options: 0000000000000001 bootName "KEY_INFO"
skip, options: 0000000000000001 bootName "box"
flash "PL2-0-213B-00WW-vendor.img" to "vendor_a"
TotalSize: 0000001073741824
flash "B2N-0-213B-xbl.elf" to "xbl_a"
flash "B2N-0-213B-xbl.elf" to "xbl_b"
flash "B2N-0-213B-abl.elf" to "abl_a"
flash "B2N-0-213B-abl.elf" to "abl_b"
perform "oem set_active _a"
perform "oem enable-charger-screen"
skip, options: 0000000000000001 bootName "cda"
skip, options: 0000000000000001 bootName "e2p_package"
skip, options: 0000000000000001 bootName "e2p_script"
flash "md4.dat" to "md4"
Elapsed: 201 secs.RUNNI
The Following User Says Thank You to mebugti For This Useful Post:
Old 05-10-2018, 12:02   #35 (permalink)
Member: 376471
Sonork: 100.1608095
Thanks Meter: 107
Originally Posted by the_laser View Post
NTool v0.025
1 credit for flashing/service ( charged once for one phone )
1 credit for bootloader unlock generation ( charged each time )
Where to buy credits? where is option to dl firmware's
Is frp charged or free
Old 05-10-2018, 12:54   #36 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 4,127
frp 1 credit
buy setool credits
Old 05-10-2018, 13:29   #37 (permalink)
Member: 1847344
Thanks Meter: 300
ta1032 dead or sp tool erase preloader solution
nokia ta1032 erase reloader solution
hi to all my phone is working well but automatice download some applecation
so i flash sp tools
select formate all +download so my hand set is fully dead only sp flash tool connect da red file
and
error s auth handle is not ready 0x1388
any solution
Old 05-14-2018, 10:27   #38 (permalink)
Member: 714291
Thanks Meter: 39
hi NTool team
i have nokia 7 plus , it was working fine but decided to wipe data
once data wiped its now stuck at androidone logo with bootloop
repeated factory reset but no success
please team give me some idea what to do so as to revive my phone
Thank you
Old 05-15-2018, 16:35   #39 (permalink)
Member: 9519
Thanks Meter: 2,150
just reflash phone with latest firmware version
Old 05-19-2018, 11:08   #40 (permalink)
voltran2008's Avatar
Member: 861795
Thanks Meter: 1,275
Will it support upcoming phones with KaiOS, like 8110 4G?
Old 05-21-2018, 17:36   #41 (permalink)
dre2's Avatar
Member: 1190283
Thanks Meter: 67
Hi the_laser
I have nokia 7 the problem stock on download mode..i download the firmware on xda..but unable to flash..
This ntool fix my nokia 7 ? I want to unlock bootloader
Sorry for my bad english..
Old 05-24-2018, 23:45   #42 (permalink)
Member: 9519
Thanks Meter: 2,150
Argon will be supported, no any problems with this
The Following 2 Users Say Thank You to the_laser For This Useful Post:
Old 05-24-2018, 23:45   #43 (permalink)
Member: 9519
Thanks Meter: 2,150
Originally Posted by dre2 View Post
Hi the_laser
yes, reflash will fix your phone for sure.
Old 05-25-2018, 14:32   #44 (permalink)
Member: 67805
Thanks Meter: 364
Nokia 5 frp
Nokia 5 on oreo8 remuved frp for just 9 sec
I finaly fix driver issue, manual update driver and untick "show compatibile hardware" then it will show HMD Global / Fastboot device like on pic bellow
RUNNING NTool 0.027
PLEASE CONNECT POWERED OFF PHONE
PHONE "D1AGAS37B0207703" CONNECTED
model : D1A
sub_model : none
software version : ND1-558B-0-00WW-B01
SW model : 00WW
build number : B01
hardware version : 5.0
RF band id :
_850_900_1800_1900^W_1_2_5_8^L_1_3_5_7_8_20_28_38_40
chip version : none
MCP info : none
EMMC version : Hynix 5.1 16GB
secure:yes
Bootloader type : commercial
Security version : 0004
Challenge : ce5adac9968ab8cfb7306bf5b3e4df7b57597589
Waiting for calculation process ...
RESPONSE: "SUCCESS" [256]
BOOTLOADER AUTH PASSED
Flash "D1C-0-5600-emmc_appsboot_service.zip" to "aboot"
PHONE "D1AGAS37B0207703" REMOVED
ProjectCode : ND1
UID : e9d9a152d5776c7eccd5527dddd6924a8abf2768
SERVICE AUTH PASSED
Flash "D1C-0-5600-ftm.img" to "ftmboot"
Flash "D1C-0-5600-emmc_appsboot.mbn" to "aboot"
FRP partition erased
Elapsed: 9 secs.
The Following 2 Users Say Thank You to MOBICOM For This Useful Post:
Old 05-26-2018, 12:41   #45 (permalink)
Member: 376471
Sonork: 100.1608095
Thanks Meter: 107
Dear Sir,
i need to flash TA-1021, phone in bootloop also has SW: PLE-522C-0-00WW-B01
unable to flash any nb0 or mlf to this phone. I dont have credit. Can i get any help to resolve this problem from u.
Page generated in 0.31383 seconds with 9 queries
