04-08-2017, 00:41 | #1 (permalink) |
Freak Poster Join Date: Jan 2013
Member: 1872250 Status: Offline Thanks Meter: 33 | Finally! Solution for ipad 2 wifi dual nand!!! UNTIL TODAY!! if you have EMC 2415 DUAL NAND ipad 2 you need to remove BOTH nands and you will need to replace the second one with iphone 4s nand...(i have used TOSHIBA THGVX1G7D2GLA08) please read it again before ask any question,NOT IPHONE 4 NAND,you need 4S NAND and you will need to put it away from CPU like this if you put it near to cpu it will not work in my case for a reason i cant understand,i try to restore it via 3utools first and i got INVALID SN ERROR,after this i try it with itunes and the ipad successfully restored BUT after restore i need to activate it with 3uTools please do it yourself and post your results also please not what type of nand you used for it |
The Following 4 Users Say Thank You to xameleon7 For This Useful Post: |
04-08-2017, 02:40 | #2 (permalink) |
Freak Poster Join Date: Dec 2002 Location: maroc nador Age: 46
Member: 18767 Status: Offline Thanks Meter: 44 | Good work.. Can you share with us how did you programmed new information using ipbox2? Thanks for sharing your experiences Sent from my SM-N9005 using Tapatalk |
04-08-2017, 19:32 | #3 (permalink) | |
Member: 1872250 Status: Offline Thanks Meter: 33 | Quote:
as i said you need iPhone 4s NAND,i use 16GB TOSHIBA THGVX1G7D2GLA08 1st i select ERASURE ALL 2nd i select iPad 2 3rd insert the SN 4th Write 5th FIX Invalid SN(optional,on some users may not needed but i did it anyway) | |
The Following 6 Users Say Thank You to xameleon7 For This Useful Post: |
04-10-2017, 08:45 | #6 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: Philippines
Member: 302596 Status: Offline Thanks Meter: 784 | Quote:
if you know ? control the solution you can control the competition | |
The Following User Says Thank You to maxieboy For This Useful Post: |
05-04-2019, 08:54 | #7 (permalink) |
Freak Poster Join Date: Jul 2008 Location: meerut
Member: 804463 Status: Offline Thanks Meter: 77 | Ipad2 i have ipad 2 duall ic how to upgread 64gb memory 16gb new plus 32gb k9pfg08u5m-lcbo old but show only 16gb on ipad put old nand 32 + 32 error 9 help me |
09-07-2020, 21:44 | #11 (permalink) |
No Life Poster Join Date: Jan 2005 Location: India
Member: 107448 Status: Offline Thanks Meter: 29 | ipad 2 error 40 Using original nand removed from ipad 2 they nand is not deduct jcid pro1000s so i taken nand from iphone 4s and programmed using jcid pro1000s but result after restore i got error 40..... any one help for the solution |
