07-09-2015, 10:19 | #1 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | GUIDE: Legacy phones (ace,buzz,vision,icon,legend,saga,bliss,chacha,run nym.,kingdom) With the release of XTC2Clip Tool version 1.04 you have an option for convenient service of "legacy" phones, which includes: - Desire HD [ace] - Wildfire [buzz] - Desize Z (G2/A7272) [vision] - Salsa [icon_g] - Legend A6363 [legend] - Desire S [saga] - Rhyme [bliss] - ChaCha [chacha] - Sensation XL [runnymede] - EVO Design 4G [kingdom] ... and other legacy HTC phones. In order to perform the desired action, you have to follow this instructions: As on all HTC phones, there are 2 operation modes: * Offline mode: CID, lock, unlock * Direct mode: S-OFF, CID, IMEI, unlock 1. No matter what mode are you going to use, you must carefully EJECT the smartcard from the XTC2Clip and put it into your phone as a SIM CARD. 2. Offline mode: - Put necessary files (CID and/or unlock config.dat) on the CLIP and connect it to your phone - Go to fastboot->Simlock and perform operation as usual. 2. Direct mode: - Connect phone in fastboot mode - Go to legacy tab in XTC 2 Clip Tool - Press "Step 2: Switch to modem mode", this will switch your phone into special modem mode. - Install drivers, if necessary. ( Get drivers HERE: http://xtc2.net/downloads/qhsusb.rar ) - Press "Refresh" and select appropriate COM port (there usually will be only one). - Press "Step 3: Connect" - The software will read information from the phone, and you can continue to perform the desired operations. Last edited by xtc2clip; 07-09-2015 at 11:26. |
The Following 12 Users Say Thank You to xtc2clip For This Useful Post: |
07-29-2015, 12:25 | #9 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Sheffield
Member: 26187 Status: Offline Sonork: 100:77458 Thanks Meter: 290 | i have a htc desire a buzz phone, part of legacy family we have tried direct mode but when we press "step 2 switch to modem mode" the phone doesnt react or change) we also have deice manager open and see no change any tips for this? |
07-29-2015, 17:59 | #11 (permalink) |
No Life Poster Join Date: May 2005 Location: bridgetown Age: 59
Member: 146939 Status: Offline Sonork: 100.1609615 Thanks Meter: 245 | Reading information... Using Fastboot mode... Reading common information (bootloader) version: 0.5 (bootloader) version-bootloader: 1.01.0001 (bootloader) version-baseband: 3.35.20.10 (bootloader) version-cpld: None (bootloader) version-microp: 0622 (bootloader) version-main: 2.22.405.4 (bootloader) serialno: SH14CPY00274 (bootloader) imei: 357758045462043 (bootloader) product: buzz (bootloader) platform: HBOOT-7225 (bootloader) modelid: PC4910000 (bootloader) cidnum: HTC__001 (bootloader) battery-status: good (bootloader) battery-voltage: 4161mV (bootloader) partition-layout: HTC (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: dirty-72b8c698 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 Execution time is 0(ms) all: Done! Reading secure flag information ... (bootloader) [ERR] Command error !!! Execution time is 15(ms) OKAY Reading CID information ... (bootloader) [ERR] Command error !!! Execution time is 15(ms) OKAY Read information completed. can this phone be unlock with direct mode |
08-08-2015, 15:32 | #13 (permalink) |
Registered User Join Date: Feb 2009 Location: in my mind Age: 35
Member: 962014 Status: Offline Thanks Meter: 7 | hi i have problem with s-off htc salsa ! i have used sd-editor and smart card method but your tools cant s-off my device error log in fastboot : SD init fail !!! process done reboot device ? <VOL UP> Yes and when i used direct mode the xtcclip soft hanged how to s-off legacy phones? |
08-10-2015, 14:15 | #14 (permalink) | |
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
As to direct mode, once switched to modem mode, you must install the drivers and choose the correct com port. | |
