12-14-2015, 14:53 | #50 (permalink) |
No Life Poster Join Date: Jun 2004 Location: MACEDONIA
Member: 67805 Status: Offline Thanks Meter: 364 | I can't connect desire s saga to unlock in legacy mode.Sim from xtc2 is in phone slot. When I switch to modem mode show as disconnected but I can instal modem driver (qualcomm hs-usb modem 9002) from your link and port is found as modem port, but no good reading from phone Trying to swtich into modem mode ... Sending oem rtask c Execution time is 4140(ms) ... FAILED (status read failed (Too many links)) Phone DISconnected Trying to connect in modem mode... Reading security info... Reading CID... Reading IMEI... Reading SIMLOCK info... Checking lock status: Unknown reply: SUCCESSFULLY connected |
12-14-2015, 15:14 | #51 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
Try to perform any action, like S-OFF and check the result. Also, you can try to open Control panel (windows) -> Modems, select Qualcomm modem, and try to do diagnostics, to see if you get a reply. If you do not get a reply - it's a drivers issue. | |
12-14-2015, 15:46 | #52 (permalink) |
Member: 67805 Status: Offline Thanks Meter: 364 | diagnostic looks OK. I can't s-off also Code: ATQ0V1E0 - OK AT+GMM - HTC AT+FCLASS=? - +FCLASS: (0-1) AT#CLS=? - COMMAND NOT SUPPORTED AT+GCI? - COMMAND NOT SUPPORTED AT+GCI=? - COMMAND NOT SUPPORTED ATI1 - Manufacturer: HTC Model: HTC Revision: HTC IMEI: 35896704689528801 +GCAP: +CGSM,+DS,+ES ATI2 - Manufacturer: HTC Model: HTC Revision: HTC IMEI: 35896704689528801 +GCAP: +CGSM,+DS,+ES ATI3 - Manufacturer: HTC Model: HTC Revision: HTC IMEI: 35896704689528801 +GCAP: +CGSM,+DS,+ES ATI4 - Manufacturer: HTC Model: HTC Revision: HTC IMEI: 35896704689528801 +GCAP: +CGSM,+DS,+ES ATI5 - Manufacturer: HTC Model: HTC Revision: HTC IMEI: 35896704689528801 +GCAP: +CGSM,+DS,+ES ATI6 - Manufacturer: HTC Model: HTC Revision: HTC IMEI: 35896704689528801 +GCAP: +CGSM,+DS,+ES ATI7 - Manufacturer: HTC Model: HTC Revision: HTC IMEI: 35896704689528801 +GCAP: +CGSM,+DS,+ES ATQ0V1E0 - OK AT+GMM - HTC AT+FCLASS=? - +FCLASS: (0-1) AT#CLS=? - COMMAND NOT SUPPORTED AT+GCI? - COMMAND NOT SUPPORTED AT+GCI=? - COMMAND NOT SUPPORTED ATI1 - Manufacturer: HTC Model: HTC Revision: HTC IMEI: 35896704689528801 +GCAP: +CGSM,+DS,+ES ATI2 - Manufacturer: HTC Model: HTC Revision: HTC IMEI: 35896704689528801 +GCAP: +CGSM,+DS,+ES ATI3 - Manufacturer: HTC Model: HTC Revision: HTC IMEI: 35896704689528801 +GCAP: +CGSM,+DS,+ES ATI4 - Manufacturer: HTC Model: HTC Revision: HTC IMEI: 35896704689528801 +GCAP: +CGSM,+DS,+ES ATI5 - Manufacturer: HTC Model: HTC Revision: HTC IMEI: 35896704689528801 +GCAP: +CGSM,+DS,+ES ATI6 - Manufacturer: HTC Model: HTC Revision: HTC IMEI: 35896704689528801 +GCAP: +CGSM,+DS,+ES ATI7 - Manufacturer: HTC Model: HTC Revision: HTC IMEI: 35896704689528801 +GCAP: +CGSM,+DS,+ES ATQ0V1E0 - OK AT+GMM - HTC AT+FCLASS=? - +FCLASS: (0-1) AT#CLS=? - COMMAND NOT SUPPORTED AT+GCI? - COMMAND NOT SUPPORTED AT+GCI=? - COMMAND NOT SUPPORTED ATI1 - Manufacturer: HTC Model: HTC Revision: HTC IMEI: 35896704689528801 +GCAP: +CGSM,+DS,+ES ATI2 - Manufacturer: HTC Model: HTC Revision: HTC IMEI: 35896704689528801 +GCAP: +CGSM,+DS,+ES ATI3 - Manufacturer: HTC Model: HTC Revision: HTC IMEI: 35896704689528801 +GCAP: +CGSM,+DS,+ES ATI4 - Manufacturer: HTC Model: HTC Revision: HTC IMEI: 35896704689528801 +GCAP: +CGSM,+DS,+ES ATI5 - Manufacturer: HTC Model: HTC Revision: HTC IMEI: 35896704689528801 +GCAP: +CGSM,+DS,+ES ATI6 - Manufacturer: HTC Model: HTC Revision: HTC IMEI: 35896704689528801 +GCAP: +CGSM,+DS,+ES ATI7 - Manufacturer: HTC Model: HTC Revision: HTC IMEI: 35896704689528801 +GCAP: +CGSM,+DS,+ES |
12-14-2015, 16:00 | #53 (permalink) |
Member: 67805 Status: Offline Thanks Meter: 364 | After install this with same name driver but certified I make unlock and s-off even I get same modem faild info blabla Thanks for info about modem querring Code: Trying to perform sim unlock for network lock... SUCCESS: The command was executed! Trying to perform sim unlock for network subset... SUCCESS: The command was executed! Trying to perform sim unlock for service provider lock... SUCCESS: The command was executed! Trying to perform sim unlock for corporate lock... SUCCESS: The command was executed! Trying to perform sim unlock for sim lock... SUCCESS: The command was executed! Last edited by MOBICOM; 12-14-2015 at 16:09. |
01-02-2016, 18:55 | #55 (permalink) |
Insane Poster Join Date: Sep 2011
Member: 1656411 Status: Offline Sonork: Scott Probert Thanks Meter: 29 | i cannot get drivers to install. software run as administrator,switch to model mode ran as first and only command. the phone is now in model mode(fastboot frozen) and shows up in device manager as Qualcomm CDMA Technologies MSM and Qualcomm HS-USB Modem 9002 but will not show up as a com port,so i cannot connect the software to it. i have tried manually deleting drivers and reinstalling,pointing to the qhusb file. i get a "driver is not instended for this platform" error message. unplugging and replugging the phone in this mode,it tries to install the drivers and gives a "drivers not successfully installed" error using windows 7 32 bit,and version 1.16 of clip software. any ideas? phone is an old htc chacha i am just trying to make the process work. |
02-06-2016, 16:06 | #57 (permalink) |
Freak Poster Join Date: Mar 2009 Location: morocco Age: 38
Member: 986038 Status: Offline Thanks Meter: 43 | sure I tried all frist page bat not warking for legacy modil geve this error Trying to swtich into modem mode ... Sending oem rtask c Execution time is 2092(ms) ... FAILED (command write failed (Unknown error)) i tried whit more 4 phone not switchet ton modem mode please hulp me |
02-06-2016, 18:46 | #58 (permalink) | |
Member: 1656411 Status: Offline Sonork: Scott Probert Thanks Meter: 29 | Quote:
The Following User Says Thank You to scotty85 For This Useful Post: |
