07-17-2006, 18:10 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 43
Member: 102577 Status: Offline Thanks Meter: 4 | Widcomm 5.1.0.1700 Sorry for the delay, but as promissed here is the latest version of Widcomm 5.1.0.1700. It comes strait from Anycom and just like their 5.0.1.1400 release, it only has support in their btwusb.inf for their 3 devices. I recommend using the btwusb.inf file from the previous release : 5.1.0.1100 or simply editing it with your dongle's PID and VID. I have also included the licence patcher 1.7 in the package. If phantasm has any objection, i will remove it from the file. I didn't have time to test it yet but as soon as i'll post this, i'll get to it. Changelog : - Support for A2DP Profile as SNK - Support for A2DP Profile on Windows 98SE/ME - Support for Basic Printing Profile - Support for Windows XP x64 edition - Local PC can now be used as Bluetooth print server - Enhanced security - Skype integration - StackSwitcher is working again Enjoy ! http://www.megaupload.com/?d=B3LZWNY0 Adi |
07-17-2006, 20:27 | #4 (permalink) | |
Member: 102577 Status: Offline Thanks Meter: 4 | Quote:
Adi | |
07-18-2006, 04:44 | #7 (permalink) | |
Adi | |
07-18-2006, 04:57 | #8 (permalink) |
Junior Member Join Date: Jul 2006
Member: 305353 Status: Offline Thanks Meter: 1 | Works like a charm! Thanks a lot for the quick fix. As for skype integration, I found if I double click plantronics 510's talk button, the headset will connect to the bluetooth doogle and skype's audio in/out are automatically configured and redial the last number. Well I like the first half (auto audio configuration), but wish to get rid of the second half. Is there any way to disable auto-redial last number function? In most cases, it is annoying. By the way, what is Change Bluetooth Software Stack? I used it and it say The Bluetooth adapter wasn't found. Does it only work for AnyCom adapter? Last edited by shimh; 07-18-2006 at 05:14. |
07-18-2006, 05:09 | #10 (permalink) | |
Adi | |
07-18-2006, 06:51 | #11 (permalink) |
Junior Member Join Date: Jun 2006
Member: 302929 Status: Offline Thanks Meter: 0 | Unable to use bluetooth presenter/mouse Hi, Just FYI I tried the new drivers and I am unable to connect my bluetooth presenter/mouse. Version .1100 worked fine, but version .1700 does not connect. Any clue on why it won't connect. Cheers |
07-18-2006, 07:00 | #12 (permalink) |
Member: 292409 Status: Offline Thanks Meter: 0 | Same here, I am unable to connect a Jabra BT250v headset. It says something like "security", and the BT software crashes right after pairing (while discovering services)... it happened also while trying to pair with another PC. =( I tried it on XP SP2. Will try to check with XPx64. |
07-18-2006, 07:06 | #13 (permalink) |
Junior Member Join Date: Aug 2005 Location: Russia Age: 49
Member: 173825 Status: Offline Thanks Meter: 0 | very strange drivers. Install at WXPSP2 , 32bit version, Dell 350 BT, *.inf file from 1100 drivers I can't connect to Dial-UP at my Nokia 6600 (security error, try "repair", after "repair"-ing loop again not work "Discovering services" at Nokia 6600, and remote MSI6160 dongle at workstation. not working: hangs and/or periodically messaging "Security error" "Device busy" etc. Last edited by pasha1974; 07-19-2006 at 07:04. |
07-18-2006, 10:34 | #15 (permalink) |
Junior Member Join Date: May 2006
Member: 284528 Status: Offline Thanks Meter: 0 | My bluetooth adapter is a Zonet ZUB6201C (Broadcom 2045 based) and my headset is a Scala 500. The new 5.1.0.1700 drivers installed with no surprises and the headset works great with Skype (it seems to be clearer). A friend with the same headset but a Bluetake BT007Ex adapter (Cambridge Silicon Radio [CSR] based) is encountering the 'Security' and 'Device Busy' errors when trying to connect to the headset using 5.1.0.1700. He had no problems with 5.1.0.1100. I'm wondering if the others here who are experiencing these errors with 5.1.0.1700 are also using a CSR based bluetooth adapter. |
Widcomm.Bluetooth.Software.Drivers.5.1.0.1700.rc1b .with.FW.Up | illusion0 | Bluetooth-Software | 21 | 09-10-2010 09:56 |
Widcomm.Bluetooth.Software.Drivers.5.1.0.1700.Fina l.Release | illusion0 | Bluetooth-Software | 42 | 12-21-2009 19:37 |
BTW 5.1.0.1700 problem | Lolitka | Bluetooth-Software | 0 | 09-11-2006 15:44 |
Widcomm 5.1.0.1700a | adisor19 | Bluetooth-Software | 15 | 07-30-2006 15:47 |
Problem Serial Port in Widcomm 5.1.0.1100 | Nuker5 | Bluetooth-Software | 3 | 07-04-2006 12:45 |
