03-28-2019, 15:41 | #1 (permalink) |
No Life Poster Join Date: Sep 2011 Location: NOKIA
Member: 1663119 Status: Offline Sonork: iffi3 Thanks Meter: 213 | Ale-l02 flashing error IMEI:867258024870723 IMEI:867258024921732 Build number: :ALE-L02C190B584 Model: ALE-L02 Battery state: 3718mv Extracting partition MODEMIMAGE... Writing MODEMIMAGE partition MODEMIMAGE partition UPDATE :FAIL flash write prim vrl failure Trying to unlock device... Writing MODEMIMAGE partition MODEMIMAGE partition UPDATE :FAIL flash write prim vrl failure Extracting partition MODEMNVM1... Writing MODEMNVM1 partition MODEMNVM1 partition UPDATE ...OK Extracting partition MCUIMAGE... Writing MCUIMAGE partition MCUIMAGE partition UPDATE :FAIL flash write prim vrl failure Extracting partition HIFI... Writing HIFI partition HIFI partition UPDATE :FAIL flash write prim vrl failure Extracting partition DSP... Writing DSP partition DSP partition UPDATE :FAIL flash write prim vrl failure Extracting partition DTIMAGE... Writing DTIMAGE partition DTIMAGE partition UPDATE :FAIL flash write prim vrl failure Extracting partition TEEOS... Writing TEEOS partition TEEOS partition UPDATE :FAIL flash write prim vrl failure Extracting partition TRUSTFIRMWARE... Writing TRUSTFIRMWARE partition TRUSTFIRMWARE partition UPDATE :FAIL flash write prim vrl failure Extracting partition SECURETYSTORAGE... Writing SECURETYSTORAGE partition SECURETYSTORAGE partition UPDATE ...OK Extracting partition NVME... Writing NVME partition NVME partition UPDATE ...OK Extracting partition FASTBOOT1... Writing FASTBOOT1 partition FASTBOOT1 partition UPDATE :FAIL flash write prim vrl failure Extracting partition FASTBOOT... Writing FASTBOOT partition FASTBOOT partition UPDATE :FAIL flash write prim vrl failure Extracting partition RECOVERY... Writing RECOVERY partition RECOVERY partition UPDATE :FAIL flash write prim vrl failure Extracting partition RECOVERY2... Writing RECOVERY2 partition RECOVERY2 partition UPDATE :FAIL flash write prim vrl failure Extracting partition BOOT... Writing BOOT partition BOOT partition UPDATE :FAIL flash write prim vrl failure Extracting partition SYSTEM... Writing SYSTEM partition sending sparse file 469762048 bytes send sparse file OK sending sparse file 469762048 bytes send sparse file OK sending sparse file 469762048 bytes send sparse file OK sending sparse file 469762048 bytes send sparse file OK sending sparse file 469762048 bytes send sparse file OK sending sparse file 133690812 bytes send sparse file OK SYSTEM partition UPDATE ...OK Extracting partition CACHE... Erasing CACHE partition Partition CACHE erased Writing CACHE partition CACHE partition UPDATE ...OK Extracting partition CUST... Erasing CUST partition Partition CUST erased Writing CUST partition CUST partition UPDATE ...OK Extracting partition USERDATA... Erasing USERDATA partition Partition USERDATA erased Writing USERDATA partition USERDATA partition UPDATE ...OK Software written 2019-03-28 04:38:43 PM Writing device finished - INCOMPLETE Waiting for fastboot device... No devices detected in fastboot mode Cannot update device in upgrade mode HOW TO FIX THIS PROBLEM.PLZ |
03-30-2019, 09:53 | #5 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Hi, Just flash the board firmware, you will need to set the country's vendor. Or You can check this thread, how to change vendor/country. Example:- http://forum.gsmhosting.com/vbb/f929...l-sim-2581042/
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post: |
