Follow factory you need rewrite firmware after any rework, but you can solve this by press factory reset manually. And there not a fact not repaired, just no factory reset . |
Also before this version (about 174) hcu has wrong reset method (not as factory) and failing (if huawei account in phone, vendor country wrong or other reasons) for many users. Now HCU Huawei repair is same as factory. Can i know any other problems ? |
I repeat the phone has been restored to factory settings, uploading new software does not improve anything, the problem still occurs, this is the HCU problem. I've tested on 20 phones with android 7 |
Phone after loading imei sam restore the factory settings, manually also tried the problem remains in fastboot imei is old but in the android is changed imei should be completely changed and he only overlaps |
but still the same error !! “The application was unable to start correctly (0xc0150002), Click OK to close the application.” Its doing my head in especially that it runs on my old XP machine.:mad: |
That is strange but your link is the exact same file as krzychunh linked me to, but I uninstalled his and installed yours and it works, don't know how but it does. BTW. I still have to disable "Win. Defender" as it complains about HCU containing a trojan. Also for some reason I lost 3 credits even though I did nothing, perhaps Namelocked could look at this for me, please? I can supply the log if needed. Again thank you to you both. Cheers. |
http://i67.tinypic.com/288701.png Repairing new IMEIs: http://i64.tinypic.com/21chtmg.png Top info before repair, bottom - after repair and reset: http://i66.tinypic.com/6qdtnb.png Quote:
Thanks Namelocked, my username is Sparkrite. TIA. |
Excellent. Thank you. |
https://www.youtube.com/watch?v=w5al...ture=********* |
is it already known what is the cause ?, does not HCU support Android 7? |
HCU - problem Android 7 It is not possible to repair the IMEI number on Android 7. Imei is changed in the android system, but this is an overlay only, because in the fastboot command there is an old IMEI and there is no possibility to change https://www.youtube.com/watch?v=w5al...ture=********* |
