04-17-2019, 16:44 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: *P*A*K*I*S*T*A*N
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | HCU Windows 7 64 Bit Drivers Problem :confused: Following are the attached images and logs including drivers installation of fastboot device FRD-L19, Operating System Windows 7 64 Bit FRP erase (Phone Not Found) Hi-Suite Installed Code: Before detection connect cable to usb and enable Manufacture mode ! Qualcomm and HiSilicon: *#*#2846579#*#* MTK: *#*#14789632#*#* Windows: ##2846579# ProjectMenu 1.Background setting 2.USB ports setting Select Manufacture mode 2019-04-17 08:20:09.929 Checking account azeem781986... 2019-04-17 08:20:09.939 Connecting to server... 2019-04-17 08:20:10.776 Connected! Account: azeem781986 Check success! Credits left: 0 License ends in 317day[s] 2019-04-17 08:20:18.670 Erase FRP start 2019-04-17 08:20:18.681 Not found device in fastboot mode! 2019-04-17 08:20:18.685 Erase FRP fail! Phone not found ! 2019-04-17 08:22:52.866 Erase FRP start 2019-04-17 08:22:52.880 Not found device in fastboot mode! 2019-04-17 08:22:52.885 Erase FRP fail! Phone not found ! 2019-04-17 08:22:53.673 Erase FRP start 2019-04-17 08:22:53.688 Not found device in fastboot mode! 2019-04-17 08:22:53.694 Erase FRP fail! Phone not found ! 2019-04-17 08:22:54.433 Erase FRP start 2019-04-17 08:22:54.448 Not found device in fastboot mode! 2019-04-17 08:22:54.453 Erase FRP fail! Phone not found ! |
04-18-2019, 09:15 | #3 (permalink) |
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | SIr! Here is the readed info from H.C.U Code: Before detection connect cable to usb and enable Manufacture mode ! Qualcomm and HiSilicon: *#*#2846579#*#* MTK: *#*#14789632#*#* Windows: ##2846579# ProjectMenu 1.Background setting 2.USB ports setting Select Manufacture mode 2019-04-18 01:14:29.656 Checking account azeem781986... 2019-04-18 01:14:29.667 Connecting to server... 2019-04-18 01:14:30.405 Connected! Account: azeem781986 Check success! Credits left: 0 License ends in 316day[s] 2019-04-18 01:14:32.571 Autodetect COM port and phone type start! 2019-04-18 01:14:33.291 Found COM port: COM122 2019-04-18 01:14:33.298 Found phone type: Huawei Android phone (HiSilicon CPU) 2019-04-18 01:14:33.311 Open COM port COM122 (Android Adapter PCUI (COM122))... 2019-04-18 01:14:33.430 Start read phone info! 2019-04-18 01:14:33.610 Connecting to server... 2019-04-18 01:14:34.136 Connected! 2019-04-18 01:14:43.901 Waiting for server responce (up to 45 seconds left)... 2019-04-18 01:14:48.155 CP State: ready 2019-04-18 01:14:48.155 Read phone basic info... 2019-04-18 01:14:49.819 Read phone secure info... 2019-04-18 01:15:01.689 Read phone info done! Model: FRD-L19 MEID: A0000082A55FFB pESN: 80B9AC25 IMEI: 86792603xxxxxxxx IMEI2: 86792603xxxxxxx IMEI3: 86792603xxxxxxx IMEISV: 00 Firmware ver.: NRD90M test-keys SN: GSLDU17C05006774 PCB SN: DU3MFJ17C6046419 WiFi MAC: 6C:B7:49:10:3C:81 BlueTooth MAC: 6C:B7:49:10:30:AC Vendor: hw Country: spcseas FASTBOOT:Chipset-austin 5.0.0.3(05IK)_FASTBOOT BOOT:Chipset-austin 5.0.0.3(05IK)_BOOT RECOVERY:(unknow) SYSTEM:System 5.0.0.48(0CJD) MAINVER:NRD90M test-keys DATAVER:FRD-L19C432B360_DATA_hw_eu APTIME:Fri Dec 30 13:04:31 CST 2016 RAM: 4G eMMC: 64G eMMC ID: 150100434A4E4234520648D7EAD79400 HUN: 0000000000000000 IMEI 1 Sim Lock status: NET: unlocked NETSUB: unlocked SP: unlocked 2019-04-18 01:15:01.963 Phone info data backup saved to file F:\HCU_322\Backup\20190418_011501_867926031701996.BAK |
04-18-2019, 09:19 | #4 (permalink) |
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | i can't understand why HCU does not identify all Huawei Phones in fastboot only in 64 bit OS earlier on 32bit i flawlessly did work in fastboot using HCU, Where as in DC phoenix i still can flash oem info and firmware in fastboot |
04-18-2019, 16:41 | #5 (permalink) |
Product Supporter Join Date: Sep 2013 Location: Lithuania, Kaunas
Member: 2023196 Status: Offline Thanks Meter: 1,893 | Please do this: 1. Restart HCU software. 2. Login with your account on software. 3. Right click on memo area make sure "enable debug logging" has a check mark. 4. Try to Detect your device in fastboot, after error do rest of the steps 5. Right click on memo area and save "debug log file". 6. Send that file to me, please. |
04-18-2019, 16:52 | #6 (permalink) | |
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | Quote:
as you told me | |
04-19-2019, 17:04 | #11 (permalink) | |
Code: Before detection connect cable to usb and enable Manufacture mode ! Qualcomm and HiSilicon: *#*#2846579#*#* MTK: *#*#14789632#*#* Windows: ##2846579# ProjectMenu 1.Background setting 2.USB ports setting Select Manufacture mode 2019-04-19 09:02:31.638 Autodetect COM port and phone type start! 2019-04-19 09:02:31.741 Compatible COM ports not found! 2019-04-19 09:02:31.748 ERROR! Phone not found ! 2019-04-19 09:02:52.256 Autodetect COM port and phone type start! 2019-04-19 09:02:52.351 Compatible COM ports not found! 2019-04-19 09:02:52.358 ERROR! Phone not found ! 2019-04-19 09:02:53.464 Autodetect COM port and phone type start! 2019-04-19 09:02:53.560 Compatible COM ports not found! 2019-04-19 09:02:53.568 ERROR! Phone not found ! unable to detect phone by READ INFO Button | |
04-23-2019, 10:42 | #13 (permalink) |
Member: 2023196 Status: Offline Thanks Meter: 1,893 | I suggest you to uninstall Huawei drivers from pc and reinstall hisuite, because it seems you work with mobiles and you have driver conflict. Otherwise can try from another clean pc perhaps. |
