07-10-2020, 15:00 | #1 (permalink) |
Insane Poster Join Date: Dec 2007 Location: MX-KEY is the BEST NOKIA TOOL
Member: 663671 Status: Offline Thanks Meter: 1 | help! hcu Access denied (for sharing dongle) i remove all usb share software ,and same dongle sn:01325E17 |
07-10-2020, 15:08 | #2 (permalink) |
Product Supporter Join Date: Sep 2013 Location: Lithuania, Kaunas
Member: 2023196 Status: Offline Thanks Meter: 1,892 | Your computer runs usb activity scanning/sharing service, therefore you got blocked. You must remove such service/software from computer before using DC-unlocker otherwise you will get blocked again. Block now removed. If you do not know what service/software on your machine causes this then can only suggest to use dc-unlocker from another pc. Note: receiving multiple blocks for same reason may end up with a permanent block. |
07-10-2020, 16:21 | #3 (permalink) |
Junior Member Join Date: Aug 2011 Location: Spain
Member: 1642153 Status: Offline Sonork: pablo_iz Thanks Meter: 10 | Hello, I recommend that if you have installed an antivirus (windows defender or another), add an exception to the folder where you have all the DC-Unlocker / HCU software. Way that ko parses or blocks access to it. Enviado desde mi EML-L29 mediante Tapatalk |
The Following User Says Thank You to Pablo_iz For This Useful Post: |
08-17-2020, 11:52 | #5 (permalink) |
Junior Member Join Date: Mar 2012 Age: 44
Member: 1740985 Status: Offline Thanks Meter: 4 | hcu gives this error when logged in. what is the problem 2020-08-17 13:50:41.650 Checking account huzurlum... 2020-08-17 13:50:41.650 Connecting to server... 2020-08-17 13:50:41.884 Connected! Access denied (for sharing dongle) Login iD : huzurlum |
08-17-2020, 16:13 | #6 (permalink) | |
Member: 2023196 Status: Offline Thanks Meter: 1,892 | Quote:
Block now removed. If you do not know what service/software on your machine causes this then can only suggest to use dc-unlocker from another pc. Note: receiving multiple blocks for same reason may end up with a permanent block. | |
The Following User Says Thank You to Namelocked For This Useful Post: |
