04-19-2019, 18:19 | #1 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 748456 Status: Offline Thanks Meter: 32 | How to remove huawei id on Lya-al00? I made TP but I am said to drag and drop my own oeminfo. I couldnt find it anywhere Found Phone : LYA-AL00 Model : Huawei phone in fastboot mode IMEI : 8611370464xxxx Serial NR. : S2D7N19327xxxx Firmware : LYA-AL00L 9.0.0.201(C00E200R2P1 IMEI1:86113704xxxxx MEID:A00000A7xxx FB LockState: LOCKED USER LockState: LOCKED locked Battery state: 0 |
04-24-2019, 10:30 | #4 (permalink) |
Registered User Join Date: Oct 2012
Member: 1822958 Status: Offline Thanks Meter: 45 | you cant flash oeminfo with this method, even if you have a file available the bootloader is not temp unlocked on the 980 chipset devices after test point flash so flashing a no matching image is not allowed (as are most fastboot commands) i believe in some cases however if you tick the remove FRP box to the top right side of the screen it will remove FRP however i cant personally confirm it nor do i know if it only removes google account or both google and huawei. your only solution at this point would be to pay for the key to remove it, thankfully theyre available fairly cheaply i believe |
07-19-2019, 19:47 | #5 (permalink) |
No Life Poster Join Date: Apr 2011 Location: Bulgaria Age: 53
Member: 1559599 Status: Offline Thanks Meter: 222 | I have HUAWEI Mate 20 Pro (UD) LYA-AL00 locked HUAWEI ID i tested the method with fastboot oem frp-unlock OXXXXXXXXXXXXX0P HUAWEI ID NOT REMOVE any ideas please share |
